Question about Refrigerators
Westinghouse virtuoso fridge/freezer has stopped cooling. How do we check the fuses etc? seals on the doors are all fine.
  • 9 more comments
  • Anonymous Oct 16, 2008
    alarm has been going every hour. All cooling fridge and freezer has suddenly stopped
  • Julie Brogan Dec 01, 2008
    Freezer alarm going off every 50 minutes - no obvious cooling problem. Air vents clear ????
    Same problem - Alarm going off every 50 min
  • Anonymous Dec 06, 2008
    same problem, alarm going off every 50 mins
  • willtcb5 Dec 18, 2008
    Westing House Virtuoso R J 523V Brand new 2 1/2 years old has stopped cooling
  • RobboCEEEE Dec 23, 2008
    Same problem. Alarm keeps going off for no discernable reason.
  • Anonymous Dec 28, 2008
    fridge and freezer fine but alarm goes off about every half an hour
  • rhkeighley Feb 26, 2009
    The fridge and freezer both have stopped cooling any suggestions?
  • dattopete Mar 08, 2009
    I too Have a RJ532 V fridge which has stopped cooling properly. Removed the freezer components and defrosted them, as I believed the airflow was being blocked between the fridge and freezer. But still no luck, freezer would be barely 0 degrees and the fridge isn't cooling at all. Any suggestions, faulty thermostat? Motor seems to be running.
  • Anonymous Apr 12, 2009
    My virtuos freezer is not cooling properly. There is no cool air coming from the top airflow vents yet compressor/fn is running..
  • dpartridge Apr 14, 2009
    The Fridge does not seem to be cooling.....nothing is actually cold.
    I placed a thermostat in the fridge and there has only been a drop of 2C from the original 23C when I placed it in the fridge.
    The Freezer seems to be working fine however.
    Any ideas?
I have the same fridge (stainless steel virtuoso) and when the fridge section stops cooling you have to turn power off. Then remove everything from the freezer including the shelf. Next get a pointy object and remove the two plastic screw covers located on the back inside plastic freezer panel, Next remove the two phillips head screws securing the panel in place. Next (and this is a little tricky) get two solid forks and lever the back interior panel off, thereby exposing the cooling system of the fridge. Next get a hairdryer and completely defrost this item, and then reassemble. Switch power back on and your fridge will be fixed, and cooling like a champion! plus you have saved hundreds by not paying ripoff "technicians" I have to do this every six or seven weeks because of the high humidity here in Darwin, the freezer is "frost free" but the cooling system still ices up, and this is what blocks airflow and stops the fridge cooling.
Posted on Dec 27, 2011
  • 2 more comments
  • melsie76
    melsie76 Jan 17, 2012
    Thank you sooo much Greg hutchings for this post! We have the same fridge and everything melted and went off over the weekend, googled to find your post and followed your helpful instruction and and now it's as cold as ice! And didn't lose a cent to a technician!!!! So grateful! Thanks again!!! :-))))
  • nikki401
    nikki401 Oct 27, 2012
    me too, thankyou so much :)
  • j_morrisonz
    j_morrisonz Jan 07, 2013
    Thanks Greg you fixed our fridge too Happy Kiwi
  • icon_bar_bri
    icon_bar_bri Feb 22, 2013
    Thanks so much for your info. We're in a real fix to put it mildly. We sold a business and the buyers didn't want any food which was incredible but we had to accomodate a lot of meat and frozen packs. A good friend with a s/h shop lent us a westinghouse virtuoso and we're wondering whether it's worth buying from him. Is it OK on power? We'll need a freezer anyway.
xalint1
  • 152 Answers
SOURCE: fridge not cold freezer ok
More then likely your problem is that its not defrosting correctly in the freezer and the ice has built up behind the panel and not allowing the cold air down into your refrigerator.
Posted on Aug 22, 2008
  • 178 Answers
SOURCE: Westinghouse Virtuoso Fridge - Circuit Diagram
If it is kicking the circuit breaker out in defrost mode, then the defrost timer is faulty. It would be best to just replace the timer instead of checking the wiring schematic. Look at www.partstoday.com for helpful illustrations on parts and identifying pictures.
Posted on Mar 30, 2008
  • 400 Answers
SOURCE: Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Posted on Mar 04, 2009
SOURCE: westinghouse virtuoso fridge freezer manual
where is filter located for water and ice block dispencer on a 2003 model
Posted on Sep 23, 2010
heatman101
  • 43501 Answers
SOURCE: i have a westinghouse virtuoso
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 29, 2010
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Westinghouse virtuoso fridge is freezing. adjusting temp on door panel doesn't work.
Is the fan operating in the freezer section? If not there is your problem. It the fan is working then it could be the damper or the temperture control.
Feb 14, 2014 | Refrigerators
Hi there, i have a westinghouse bj505sr. The problem i have is that the fridge and freezer are not cooling the way they wer until 1 week ago. I have checked the door seals and they are ok. The only thing i...
sounds like you have a blown defrost element on the back panal of the fridge if they blow then excess ice builds up and the unit stops chilling correctly have the defrost elements tested if you know how to use a mulitimeter try testing the elements as you would a fuse
best of luck
please remember to rank my reply
Dec 01, 2010 | Refrigerators
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Oct 13, 2010 | Westinghouse Refrigerators
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer door opens
its air pressure between the wo doors that cause it to open the freezer door.take some soapy water and clean the sels aroundboth doors to see itf thet dosent help use dish soap and a little water to clean the seals with it should stop it
Jan 07, 2009 | Frigidaire FRS3R5EMB Side by Side...
Westinghouse Fridge problem
-Try defrosting the unit. (force defrost)
- Check air vent if air is present.
- Check if the unit is not overloaded with stocks or air vent block with stocks.
- If no air is present in vents then check your blower inside if operating.
Feb 29, 2008 | Refrigerators
Refrigerators Logo
4,601 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
