Question about Symbol Motorola VC5090 Wireless Portable Terminal
How to restore the Symbol VC5090 flash persistant memory to factory defaults ?
2 Suggested Answers
  • 15 Answers
SOURCE: HOW TO RESTORE FACTORY DEFAULT
There is a program you can download from symbol/motorola and place on a sd card and follow the instructions with the card and program. Otherwise send it to me and I will do it for $100.00.
Posted on Oct 13, 2010
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
I Have Nokia 3110 C phone.. when i starting the Music Player no music file is not found is showing, but i inserted Memory Card (1GB), and default Nokia themes, are gone..
Actually the size of the memory card is higher according to the direction given by NOKIA.But, anyway reduce the data of the mmc,restore the phone by selecting "Restore Factory Setting".If the problem still persist,the final and the last solution is to flash / update the phone.So, contact mobile repairing shop or if you want to do it by yourself follow the procedure below
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
Aug 19, 2011 | Nokia 3110 Cellular Phone
A general: memory full close some applications and try again appears everytime i send a message
Hi....
Try the following... *Restore your Phone once (To restore Goto Menu>Settings>Restore Factory Settings>OK(default security code is 12345)
*Clear some memory of Phone and Memory
*Scan your Phone and Memory
If problem persists you need flash your phone
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
I hope this helps... Thank you have a nice day
Feb 03, 2011 | Nokia E63 Cell Phone
Nokia 6233 is automatically switch off battery change but same fault please soulution
check whether your battery locks perfectly or not(if not use a piece of paper to tighten it Put a piece of paper like this hjlava.jpg
) If problem persists Try the following *scan the phone and memory card from updated anti virus if persists *Restore your phone To restore Goto Settings>Restore Factory settings>Default code will be12345
At last.......problem continues..... You need to flash your phone
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank you Don't Forget to rate
Jan 28, 2011 | Nokia 6233 Cellular Phone
3110c says phone memory full with only 575 contacts. I used to have 1500 contacts. Upgraded the firmware to latest version. How can I get the unit to accept the 2000 contacts it is originally designed to...
If your able to switch on your phone then try this
To reset your Nokia phone please follow this.
Press 3370#
It would reset the phone to factory settings.
The default code is 12345
or
If your phone is not starting please press these buttons simultaneously.
onoff + + 3
If still the problem persist scan your phone for any virus.Your phone is affected by virus.If stilll problem persist you have to flash your phone.
Jan 11, 2011 | Nokia 3110 Cellular Phone
Changeing language with a VC5090
Hello Robert, you would need to install an localised OS to the VC5090 to change the language. You can do it by copying several files to the device and starting an exe file.
Available languages: English, French, Italian, German, Spanish, Chinese Simplified and Traditional, Korea and Japanese.
You can find the required files and instructions at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11700&sliceId=&dialogID=192108388&stateId=1%200%20192104411
Sep 09, 2010 | Zebra Symbol Technologies MC909X-G Series...
My nokia 5300 camera is not working.As soon as i open a camera mode it says camera on standby and operation failed
Switch off the phone, remove the memory card and boot again without the memory card. Now try accessing the camera, hope it's working now. I would suggest you to scan the memory card or format it (i recommend formatting the memory card so that it'll not fail).
If the problem persists even without the memory card, reset your phone's settings to Factory Default by going to the Settings > Restore Factory (open the settings, press up key once, you'll see the "Restore Factory") using the code 12345. Your phone will automatically restart. Now try again with camera.
If both the above methods don't help out, your only option is to flash the phone or update the firmware. But I don't recommend do these yourself, a small mistake or incomplete will damage the phone or will create more problems. You can visit any service center or any mobile repairing center and get it done with a small fee.
Good luck.
Thanks for using FixYa.
Aug 10, 2010 | Nokia Cell Phones
Default pin code Lexmark T640Problem
Turn off Printer
Hold down check button (center) and right arrow
While holding buttons in turn printer back on and continue to hold. You will see the memory and speed display come up. Continue to hold until you see the clock symbol. Then release buttons. When the menu comes up scroll down to Factory defaults, click the check button (center) and click again for Restore Base. This will restore the factory defaults and remove PIN
Jun 23, 2010 | Lexmark T640dtn Printer
During upgrade download my electicity cut causing
According to the manual if you press the( >>I ) button on the front of your unit for more than 5 seconds without a disk inside it will set everything back to factory. It say don't use it unless necessary. When the factory default settings are restored all the user data stored in the persistent memory will be deleted. If its not working I don't see what you have to lose.
Mar 02, 2010 | Samsung BD-P1500 Blu-Ray Player
Symbol MC9090 Unit
In order to reset the device you will need to perform a cold boot. This will erase all temp data and reset all settings to the factory default it will not however erase any applications which have been downloaded into flash memory cards(assuming they're installed).
Perform a Cold Boot:
1.
Press the primary battery release on the mobile computer to partially eject the battery from the mobile
computer.
2. On an MC9090-G, while the battery is partially released, simultaneously press and release the trigger and the
Power button.
3. Push the battery to fully re-insert it in the mobile computer. One audible click can be heard as the battery is fully
inserted.
4. The mobile computer initializes.
Once it has re-initialized all user data will be removed and all factory default settings will be restored, they should be ready to sell at this point.
Hope this Helps FixYa,
Chris
Apr 26, 2009 | Zebra Symbol Technologies MC909X-G Series...
Symbol Motorola VC5090 Wireless Portable Terminal Logo
1,051 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
