Question about Labtec Webcam Plus 0403
How do i get a clear image? what are the settings?
After reading data or scanning output is no clear
Hi Sunil
You can change the scanner setting and increase image resolution before scanning,after that your image will get clear. Download the mention below manual & read the software section para.
Download :Manual
Instruction :
  1. Go to the control panel and select the printer & scanner.
  2. Right click the Samsung scanner and select the properties.
  3. After that select the graphic tab and select the 600dpi and seve the setting
Now you can get the perfect image which one you need.
If my solution make you happy then give me thumb.
Jan 08, 2012 | Samsung SCX 4521F All-In-One Laser Printer
Toshiba estudio 351c error code ce40
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color.
(2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to
check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M
and C, and under 220 for K are defined as low-density pattern abnormality.
(3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to
check if the high-density pattern abnormality occurs for each color and identify the color which
pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality.
(4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "0" (Invalid).
(5) Perform "Enforced performing of image quality open-loop control (05-394)".
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(7) Replace the image quality sensor.
(8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid).
(9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
completed normally. (Error [CE40] does not appear.)
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Apr 12, 2011 | Toshiba Office Equipment & Supplies
BOTA ERROR CE40
1.Replace the image quality sensor
2.Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid). MEANING Shutdown the machine,press 0+8,while starting the machine, enter 556 then enter 1,confirm it,then press 557 then 1,confirm it.
Below are further instructions in the same way
3.Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
4.Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to
576)"
That is it
Jan 04, 2011 | Toshiba E-studio 281c Copier
How to restore to factory default settings ricoh
enter service mode then execute these service programs I would do an sp print
5990- 2 out first just in case
5801 Memory Clear
Resets software counters and returns modes and settings to their defaults.
All clear: Clears all data
Engine clear: Clears the printer engine settings
SCS: Clears the systems settings
PRT: Clears user mode system settings
NCS: Network control systems - Clears the items listed in the “Host Interface”
section of the Configuration page.
DCS: Delivery control system (e-mail settings)
MIRS: E-mail addresses
5801 1 Memory all clear
5801 2 Engine memory clear
Resets the following user tool settings:
Maintenance menu: Main scan registration, sub scan registration, image
density, curl control
Resets the settings of the following SPs: 1003, 1104, 1105, 1902, 1910, 2001,
2112, 2113, 2201, 2213, 2301, 2910, 3921, 3922, 3923, 3924, 5930
5801 3 SCS memory clear
Paper Input menu: Paper type, paper size, tray lock,
System menu: Energy saver timer
Resets the settings of the following SPs: 5009, 5812
Also resets the user code counters.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
I have sony cyber shot 5.1 megapixel camera, and images are not shot clearly there is always a blur image. Please show me the setting of image resolution.
this s bcoz of the image setting...bcoz there s two options one s landscape and portait..if u select landscape more memory will be used and the image clarity will be very gud...and if u choose the other the image clarity will be little bit low...so u jus check the image settings...if each photo holds a memory of 2mb...then the photos clarity will be very gud...if the image memory s of few kbs then the image clarity will be less!!!!
Jul 27, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Web pictures not clear
What version of IE are you running? How old is your laptop?
I had this problem before. Sometimes the settings are set so that images will download faster, the price is a lower quality image.
Pull up an image on IE and if it is blurry, then right click and see if there is an option to reload page at full quality.
Unless you have a fast processor and enough RAM to handle the download images. I would leave settings alone and just right click on images that you really want to see.
Feb 13, 2009 | HP Compaq Presario V2000 Notebook
Blurry picture
There is a focus ring around the lens of the WEB cam turn this ring until your image becomes clear, just like a camera focus knob.
Click on the WEB cam software, you will be able to go into an options or configuration, click on video setting, you should see an image of yourself, adjust the focus until the image is clear.
Jan 01, 2009 | Radio Shack VGA PC Camera Webcam
The screen is not clear
Grainy image = playing standard 480 cable or antenna on a high definition set
Double image - convergence ic's, or circuit
Green shadows - green crt coolant/tube issue
Since i haven't heard back, i'm going to clear this from my queue
May 23, 2008 | RCA Televison & Video
Adobe interface issues
We have also seen that Adobe Acrobat doesn't produce very clear scans (with a range of scanners). Adobe gives very good pdf file size but it downsamples images.
Aug 08, 2007 | Ricoh IS 330DC Flatbed Scanner
Labtec Webcam Plus 0403 Logo
Top Labtec Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
