Question about GE Spacemaker JVM1640SJ Microwave Oven
I need to replaace my plate for a GESpacemakerXL1800 xl1800
  • GE Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 21, 2011
How do you change the light bulb on the Spacemaker XL1800?
http://www.repairclinic.com/ try this site maybe it will explain it to you it's a pretty good site to check stuff like that.
Dec 26, 2014 | Microwave Ovens
My microwave GELX1800 is not heating... when the express button is pressed it opens the vent lid and the plate turns around but is not heating. The vent lid should not be open when the cooking buttons are...
Try a hard reset first: Unplug the oven or turn off its breaker for a minute or so, then set the clock & try it again.
If it still fails, did the cooktop lights go out recently?
It may need circuit board repair, which is usually economical.
Oct 27, 2013 | GE XL1800 1100 Watts Microwave Oven
Electrical arching between top metal plate and shell?
i would imagine its a shield but iam not completely sure without a good look
Nov 20, 2011 | GE XL1800 1100 Watts Microwave Oven
GE profile spacemaker XL1800 undercabinet microwave - how do you change the 2 lightbults under the microwave. I can't get the bulbs out.
There are several screws on the bottom panel that can be removed. After you remove them, the metal plate can be removed or just lowered at an angle. Using a flashlight, you will see the two bulbs that probably need replacing. Pull the wire down, and they can be easily removed and replaced.
Hope this helps.
Nov 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turnable plate isn't working
in order to be 100 % sure
you would have to check voltage to the motor while its suppposed to operate
take off the bottom 6 screws, you might need whats called a safe t, a torque wrench or star with a hole
most use phillips,
drop the bottom, you should see the turn table motor
disconnect the two leads and connect them to a voltmeter,,,
turn the unit on
you should read voltage to the meter
if not the problem is in your control board and will need to be replace
if you do read voltage and the motor is not turning
you will need to replace the actual motor
either way its a pretty simple repair and can be done without taking the unit dwon
Oct 24, 2009 | GE XL1800 1100 Watts Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need manual for microware GE Profile Spacemaker XL1800
Yes you can wus the racks all the time they are made for the microwave.
Also here is the manual
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40395-1.pdf
Good Luck and Please Rate FixYa!
Jan 11, 2009 | GE JVM1860 Microwave Oven
GE XL1800 JVM1870SF02
I have the same problem on a Jenn Air. Did you get an answer?
Oct 03, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL1800 Microwave
Your turntable motor is shot. It's simple to remove and replace. you don't even have to take the microwave out of the shelf. To remove it take out seven screw around the perimeter of the bottom. Lift up on back of bottom to get over clips on the back. Remove the two screws holding the motor in and detach the plug. Find a electrical repair shop for you make pick it up and replace it. When replacing it take out plate and hold plate key down and align flat side of shaft on motor with the plate key.
Nov 30, 2006 | Samsung MW1030WA Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
47 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
