Question about Car Audio & Video
Need to know what the four plug in wires hook up to got 2 black wires, a blue wire and a yellow wire
  • 643 Answers
2 black are normally grounds
blue is remote or pwr ant
yellow is either your acc wire or constant pwr...(acc being switched power)
Posted on Mar 21, 2011
Testimonial: "thanks perfect, i thought that was right but now im sure"
Where to connect blue wire on a 16 seer Westinghouse condenser unit. It has 3 low voltage wires a black a yellow and a blue.
If you have 3 wires hooked up to the indoor unit, you need to read the terminals to which they
are hooked to. On the outdoor unit you need to see on the electrical print where the low voltage
wires should go. However it is uncommon to have three wires, 2 wires is common..
For instance, on the furnace if Black is connected to Y terminal then black at the condenser
would go to one side of the contactor. If Yellow is hooked to C terminal at furnace, the
at outdoor unit Yellow wire would go to other side of contactor. If Blue is not Hooked to
anything, tape it off.
Sep 01, 2011 | Heating & Cooling
Tip
Trailer Wiring
Hello all,
For those of you that need to wire up a trailer or have to occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
A test light and a 12VDC power source can be handy for trouble shooting.
Best regards
Mike
on Jan 09, 2010 | Cadillac Escalade Cars & Trucks
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
This will show you how to wire trailers with seven, six and four pin connectors
Seven wire Trailer plugs (Large trailers with a battery and electric brakes):
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 2004 Dodge Ram 2500
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Which colour wire to use to hook up a trailer for a Kia Carnival 2000,trailer leads are yellow, green,black,brown,red,white and blue(no connection). just want to know which lead goes to which in the Kia?...
Here is a cheat sheet I compiled that you will find very helpful:
Columns are Color, Function, Mark on the plug.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
Oct 28, 2009 | 2000 Kia Amanti
Need to hook up stereo in 91 accord but its just open stereo wire
Below is the wiring setup for your car:
1990-93 Honda Accord Stereo Wiring
Constant 12V+ White/Yellow Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger Yellow/White Antenna Left Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White Best of luck,
Greg
Aug 01, 2009 | 1991 Honda Accord
I need a wiring diagram for a 2001 ford f150 trailer hitch plug in. i got a new heavy duty trailer connector and i need to know the color code of the wires
Hey Bryan
I've got them for Six and Four wire plugs
Six wire plugs:
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
May 02, 2009 | 2001 Ford F150 Styleside SuperCrew
Cb mic wiring
I have a browning golden eagle mark II. It has a two pin mic plug. I would like to hook up a astatic power mic to it. Anyone have an answer?
Oct 07, 2008 | Magnum DeltaForce CB Radio
Re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Apr 19, 2008 | Car Audio & Video
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
