Question about Sony CMT-GPX6 Shelf System
I have a GPX S7695 stereo system, and the record player no longer works. Is there a turntable belt that can be replaced?
  • Cassette_guy Sep 28, 2011
    Does the platter rotate?
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Using the speakers to listen to other componest of my stereo system
Yes, you could have two complete systems crossing over to each other but the sharing will only be in Stereo either way and you will have to decide which one you want to be the Home Base for the other. I would think the deciding factors would be 1) Do you want multiple channel sound; 2) Are your existing speakers far superior to the DAV-FR1's?
DAV-FR1 in charge: If your receiver has one unused Tape (*) or Line Out pair, run a pair of RCA cables to the DAV's SAT Audio In and when you want to hear its attached program sources choose SAT on the DAV. You could also leave the 4 speakers in place or arrange them to augment 5the DAV and hear them all.
* If you use a Tape Line Out pair DON'T select the Monitor on the source or it will de-select any non-tape source going Out to the other Receiver.
Your receiver in charge: Run the DAV's Audio OUT (L/R) jacks to any Line Level input on the receiver (AUX, Tape In).
If whichever direction you wish to use doesn't have a spare Line Input or Output get yourself a pair of RCA cable splitters of the appropriate gender (one male end / two female ends) and share the jacks. Just make sure whichever source you're NOT intending to hear has something inactive selected.
You could even have both. but you would have to take care to NOT induce a circular loop by having each selecting the other as a source.
Posted on Apr 28, 2009
  • 252 Answers
SOURCE: I have a GPX model
Your Electric motors are not getting enough power from your power suppy go in and make sure all the wires are plugged securly into their connection. This should solve your problem.
Posted on Aug 18, 2010
I have an old record player. It was made in the 80's according to my mom. I have recently started to use it( it hasn't been used since 86). With the exception of 45s, the record player will only play side...
I must say I have never come upon a record deck that will only play one side of a good condition record!
The only action I can suggest is to replace the belt if it's a belt driven deck. Please make a note of how it fits before removing the belt. But why any record deck would treat a new record any different on one side than the other will be a mystery to any good engineer.
The only exception would be if the deck played one side good then played up on every other record. Till it's switched off for a while, then repeats this action.
The cause of this fault would be a part overheating the longer the deck is left on. When you stop it to turn over, the system fails. This is however more likely to happen on a direct drive turntable, not a belt driven one.
Aug 24, 2014 | Audio Players & Recorders
Clarinette 107 stereo cassette 8 track and record player. stereo works, but record player will not work. how do i find the problem?
I'm assuming you have a belt driven platter. Lift up the rubber mat, turn the platter it to where the motor spindle is, and see if the belt is still on. For more information or further questions, please visit my website at audioserviceclinic.com. Thank you.
Dec 12, 2013 | JVC AL A158BK Turntable
How do I know if I need to replace the turntable belt?
Belts are like big rubber bands. If they wear out and begin to stretch with age, there is no longer enough tension to move the turntable. They may also start and then quit once it warms up and the belt gets warm and expands. See how loose it is once it has been running.
Dec 06, 2013 | Electro Brand Nostalgic Stereo CD Music...
Turntable starts out slow then seems to work fine
Just sounds like it's so old to the point that it's working on it's last legs...enjoy your time with it while it lasts.
Apr 30, 2012 | Audio Players & Recorders
I have a older model record player/8-track/cassette/radio stereo. It have been in an attick in the box for many years. The record player does not turn - it is very stiff. I can manually turn it with my...
A combination of heat and dirt is "public enemy #1" for electronic devices. Most people's attics are loaded with both.
A thorough cleaning followed by careful lubrication may bring the record player or "turntable" back to life - but it will most likely need to be done while at least partially disassembled. A few drops on the center spindle from above is no guaranty that the oil will seep underneath the platter - as most are solid parts. You didn't include a name and model number so I can only speak in generalities rather than specifically to your model.
Much of both the tape drive mechanisms rely on rubber drive belts. These belts look like simple rubber bands but are not (and will not work when replaced with rubber bands either - I know - I've tried). The drive belts, like most simple rubber bands will dry out very quickly and break in the extreme heat found in attics in the summer. Similarly, many turntables are belt driven, too. The belts for those, while longer and thicker, will suffer the same fate in those conditions. Inspection and replacement of these belts seldom can be done without some dis-assembly. The turntables that are direct drive do not have these belts. The drive motors for both types of turntables may benefit from one or two drops of sewing machine oil (or other light, thin oil) applied at the point the drive shaft meets the motor housing. Anything that turns or rubs against other moving or stationary parts can also receive a single drop of oil. Do not over do it - and wipe away excess oil as oil attracts dust and dirt.
I hope this helps and good luck! Please rate my reply - thank you.
Feb 18, 2011 | Audio Players & Recorders
I bought a sony hp 180 am fm stereo with a record player. Evertyhing works but the record player, how can I fix it? It doesn't turn or anything. The radio works just fine.
Lift up the turntable matt and see if the belt is off. There should be a hole to see the belt. Touching the stylus with your finger, will determine if the cartridge is working. The amp needs to be set to phono for this test.
Dec 21, 2009 | Audio Players & Recorders
Hi, I have a technics stereo system from 1986.
If the turntable is belt driven you may have a stretched and slipping belt that needs replacement. This seems most likely and is simple to fix. You will have to lift off the turntable to see the mechanism beneath. It may be held on by a nut or clamp. A web search for the model name and "dirve belt" may yield a replacement.
If it is driven directly by a motor without a belt, the motor is probably dying. Replacement more involved, expensive, and hard to justify, unless you're really into vinyl.
Aug 06, 2009 | Technics Audio Players & Recorders
Sony CMT-GPX6 Shelf System Logo
99 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
