Question about GE Profile PDW9880NSS Stainless Steel Dishwasher
I have a new GE Profile dishwasher and granite countertop. How do I attach it so it doesn't tip. I can't use the tabs at the top as the granite is right there. Any help?
  • 1,543 Answers
Open door and look for removable hole cover along left and right side, several inches down from the top. Use a wood screw to secure the side of the dishwasher to the cabinets there, then replace the hole covers.
Posted on Mar 21, 2011
Dishwasher was not installed but only slid under counter so now it topples over. I have no installation clips
Your dishwasher may have a "side mount" and you may be able to screw it into the sides of the cabinet, if not, you will need to find out how to attach the brackets to your dishwasher (they usually slip into a groove in the top of the dishwasher, bending the tab over once slipped in will prevent it from coming out again.) If the brackets are for another dishwasher, you will need to order the correct brackets for yours.
Oct 07, 2012 | Magic Chef Built-In Dishwasher -...
GE Profile cooktop JP360. Trying to remove cooktop to install new granite countertops. Also have GE built in oven JTP 15 below. Called G.E. Customer Service today and was told to just pry the top off...
Hi marilynmcdon,
You can do it yourself. These cook tops are not glued to the granite at all (Or is not supposed to be). Simply lift is up slowly, start from the side, and lift it slowly. If done carefully you won't damage anything.
Hope this helps
JEDEMEYER1
* If this solution helped you, please rate it.
Aug 09, 2011 | GE 30 in. Profile JP350 Electric Cooktop
We have a Bosch SHE45M06UC/50 in an island with a granite countertop. It is not attached and so moves. How do we attach it to the granite countertop? Or how do we attach it????
You glue on a wood strip, to the underside of the counter, then screw into that. Use construction adhesive. The wood strip needs to stick down no further than the counter edge treatment, so you normally cannot see this wood strip.
May 11, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
The brackets to hold the dishwasher back under the counter do not align with the holes that were drilled in the granite counter top for the old dishwasher. I do not want to try to drill new holes in the...
You could have a handy person make some new brackets which attach to the new dishwasher's brackets with bolts but are made so that they line up with the existing worktop holes. You can probably use strips of soft metal with holes to fashion these.The dishwasher may have to sit slightly lower.
Dec 30, 2010 | Dishwashers
Need to stabilize machine and have granite countertops
Ask a local granite fabrication shop to get you some dishwasher mounting clips. They look like a perforated disc of metal with a small nut brazed to one side. They come with a short screw that attaches through your dishwasher mounting tabs. Place your dishwasher where you want it relative to the cabinets and pick a hole in the mounting tabs that won't leave the clip protruding and attach the clip to the chosen hole. Use masking tape on the top of your dishwasher door, wipe the bottom of the granite and the top of the clip with acetone, then use a gel-type two part epoxy from your local hardware store to attach the clip to the granite. Use enough to make the epoxy push through the perforations in the clip as this is how the epoxy grips the clip. Push the clip to the bottom of the granite and close the dishwasher door, using a wood shim or two between the top of the door and the mounting tab/clip to push the clip tight to the granite. Pull the shims out once the epoxy has cured (check the instructions on the epoxy).
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Nov 20, 2010 | Siemens 24 in. SL84A305UC Built-in...
Mounting my dishwasher to granite counter tops. Granite Grabbers last about a week before they loosen up
Oct 21, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Just did a kitchen remodel, kept the Bosch dishwasher model SHU9955UC, contractor having problems will attaching dishwasher to granite. Any suggestions? Thanks!
Sep 24, 2010 | Bosch SHU9955UC Built-in Dishwasher
I'm having my kitchen counter tops replaced with granite. I have a GE Model GSD700 dishwasher that is now attached to the existing counter top. The granite counter tops will not accept having a dishwasher...
• Purchase and install the GPF65 side-mount
bracket kit if the underside of counter is granite
or a similar material that will not accept wood
screws. The GPF65 kit is available from authorized
GE appliance dealers.
Also note that any stainless steel tub models would be able to accomadate granite tops without a kit, and I beleive all Profile GE models come with the kit included.
Sep 27, 2009 | Dishwashers
Mounting brackets for granite countertop
This is the best way i have found. You must check this company out. Granite Grabbers www.GraniteGrabbers.com They are extremely simple mounting brackets secured with a very strong double sided adhesive. You do not have to drill you cabinets or deal with any expoy.
I have used them with excellent success, took 5 minutes to install
Dec 19, 2008 | Dishwashers
GE Profile PDW9880NSS Stainless Steel Dishwasher Logo
370 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
