Question about Admiral 24 in. DDB1501AWW Free-Standing Dishwasher
After finighing washing the dishes, there is stile water on the bottom of the dish washer.
  • Admiral Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Mar 21, 2011
Water in the bottom dw smells.It's not from wet dishes dripping.It just appears every few days.Would my disposal have something to do with it?I don't know how to take it apart to find out.
try washing without dishes with a cup of vinegar or get a product at the store call dish washer cleaner that you use it in and empty dish washer to clean and remove smell.
also could be clogged strainer in the bottom of DW then need to be cleaned out!
Sep 04, 2016 | Magic Chef Dishwashers
The water does not get hot enough. I think it's the reason why dishes are not coming out clean. In normal conditions do I need to wash the dishes (like the manager of this apt. complex suggests) before I...
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Feb 22, 2011 | Whirlpool Dishwashers
White film is all over my inside of the dish washer & dishes
This sounds like excess soap or not enough water. You may also have really hard water.
Turn on machine wait until it starts running see how much water is inside. there should be a 1/2 to 1" +/- in the bottom but not enough that the wash arm would be touching and not enough that the door would be leaking when you open it. This could also be a circulation problem set wash arms a certain way and observe that they have moved when you open after running for a minute or 2.
Please let me know if I can do anything else to help.
Apr 13, 2010 | GE Dishwashers
Upper tray dishes are not cleaned(washed) the bottom are OK, why?
replace the washer water from bottom of the unit up to the top arm water feed assy,they get worn and water leaks by the hub arm that pressurizes the upper wash arm,this is also true on the center arm if the washer has one
Mar 09, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Poor cleaning leaving deposits,dishes feel dirty
The problem for the spots is hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Aug 04, 2009 | Thermador DW44Z Built-in Dishwasher
Dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
Apr 10, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishes not dry enough & leak of water at sink vent device
HEATED DRY.Turns the drying heater on for fast drying.
ENERGY SAVER (no heat boost). Turns the drying heater off to save energy. Dishes will dry naturally over a longer period such as overnight. lf you need your dishes sooner, open the dishwasher door after the cycle is complete to reduce the natural drying time. Use of this option reduces the electrical energy used by this model approximately 7%. A rinse agent makes water flow off dishes quicker than usual. This lessens water spotting and makes drying faster, too.
Make sure inlet water temperature is correct.(SeePage6.)
Unload the bottom rack first.Water from dishes in the top rack may be spilling in to the
bottom rack.
Check for improper loading.Dishes shouldn’t nest together. Avoid overloading. Check the rinse agent dispenser to see that it’s not empty.
Inlet temperature....Good Dish washing starts with hot water, To get dishes clean and dry,you will need hot water.To help you get
water of the proper temperature, your dish washer automatically heats the water in the wash cycle. For good washing and drying , the entering water must be at least 120°E To prevent dish damage,
inlet water should not exceed 150”F. How to test water temperature: Check the water temperature inside your dishwasher with a candy or meat thermometer. Let the dishwasher run through
one fill and pump out cycle, then let the dishwasher fill with water
the second time. When you hear the water stop filling, unlatch the door and slowly open it. Measure the temperature of the water in the bottom of the tub this way: Remove the silverware basket and
place a candy or meat thermometer in the water towards the middle of the tub. If the temperature is less than 120”F,you will not get good washing results. Higher water temperature is needed to dissolve grease and activate powder detergents. If the unit is a long way from the DW you may need to let the water run in the sink until hot before starting the DW....or if is a cold day and water has not been used in a while the pipes could be cold....also if you have just used the hot water ( washer, shower...etc) give it time to recover first before using DW....All of the above mentioned material is straight out of the Users guide...but you may have an element that is going out also...so check the temp of your water and open it during the drying cycle to see if it is hot or at least warm inside...if not your element may need to be replaced...
I hope this helps...have a great day & good luck...please rate my effort.... the Fang.
Jan 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
White film on dishes
Experience : 30 years in dish washing as a professional instructing hospitals and restaurants.
It is not necesaasry to cover the heating element as long as sufficient water is present so as to not STARVE the water pump.
Listen to the sound of water serging with the machien running. If it is contant you have enough water if the sound comes and goes then the pump is serging . either lyou have a low water level or CLOGGED strainer in the bottom of the machine (inside).
you might also open the door real fast during the wash and check for water splashing and flows---- you might get wet but this way works .(wear protective eye shields)
water levels can be raised by BENDING the tab on the bottom of the float which controls water level...much like a toilet tank float.
Also finally if soap levels are too high the soap will not rinse off regardless of the amount of "rinse fluid you use.
Visit www.soapman.com
regards
soapman Bruce
Dec 30, 2007 | Dishwashers
No water is coming out of the spout in the dishwasher
I am experiencing the same problem on my kenmore dishwasher (model: 665.1702). there appears to not be enough water spraying out of the washers as the soap is still in the dispenser at the end of the wash and the dishes are dirty. I've tried removing the bottom washer but can't figure out how to remove it. Did either of you find a resolution?
Dec 02, 2007 | Kenmore 24 in. 17669 Free-standing...
Admiral 24 in. DDB1501AWW Free-Standing Dishwasher Logo
140 people viewed this question
Top Admiral Dishwashers Experts
Paul Bade
Oloyede Monsuru
Melissa Martin
Melissa Martin
Are you an Admiral Dishwasher Expert? Answer questions, earn points and help others
