Question about Cycling
I got a f-09 ryder comp. from a friend that got an upgrade for his bicycle, I now need to adjust the tire size and other settings on this unit. Can jou please supply me the settings for this unit? Thanks Eddie Engelbecht
    New Friend:
I can scan you the manual if you need it. Email me on dehaastc@yahoo.com
Posted on Dec 19, 2012
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: How do I program my bicycle computer? My battery
Just get the manual and keep it for the next time you need it...
A simple web search for "Vetta RT288L manual" finds it.
Posted on Sep 14, 2011
My bicycle tire is 29x2.00 what is the number that goes with my tire, i have a atom sl3.0
The 29 x 2.0 is a correct size. There also are some other numbers on the tire. They are the metric tire size. The format for this number is 590-32 both are needed to get the right replacement tire
Sep 06, 2014 | Cycling
Flat tire
A bicycle repair shop should be able to tell you the tube size if you provide the tire size markings on the sidewall of the tire.
Apr 07, 2014 | Bianchi Milano
What is result of tire size setting of 2.224 versus 2.233
The calculated size is more accurate, whereas the manual suggests a setting. If you cannot set the size accurately then use the suggested setting.
Apr 22, 2012 | Sigma Bc 906 Computer
When turning I can feel a catch, when returning the handle bars to the strait position. when riding it feels as though the front end is loose. I eecently did raise my handle bars. which way should the...
You messed with the stem which preloads the bearings in the headset. In other words, you fixed it til it was broke.
Hop on a search engine for "adjust threadless headset bicycle" or "adjust threaded headset bicycle" for videos that show you how it is really done.
The web is your friend. Ask questions of search engines before endangering your life with unqualified or misunderstood adjustments.
Arrows on tires have nothing to do with loose steering. Forward at the top, if you buy into directional tread.
Aug 09, 2011 | Cycling
Trying to figure out how to remove rear tire from 26" inch hyper shimano bike. Would help if i could get an online manual
Any search engine would take "remove rear bicycle tire" and produce many good answers. Involvement of Fixya experts is an unnecessary and delaying step.
Aug 04, 2011 | Shimano 09 Xtr M971lc Mountain Bike Rear...
Need to remove flat front tire on point beach bike what size is the bolt any hints?
Try an adjustable wrench. I think that the nut is 7/16th's or 1/2 (english units).
Use 2 adjustable wrenches to hold both sides.
Jul 12, 2011 | Schwinn Cycling
Schwinn Sidwinder gears need adjusting. The one with 3 gears doesn't stay where I try to set it.
Keeping a derailleur in a given gear is the shifter's job. If the shift lever/mechanism doesn't click and stay where you place it, something is wrong internally. It will need to be replaced if, for example, a SRAM MRX grip slid away and let the guts fall out.
Whatever your particular dilemma, look for a friendly local bicycle shop to see what they can do for you. I replaced the entire MRX shifter set for a friend using an upgraded and better designed Shimano setup for under $25 and my own labor. But then, I'm an old hand at working on bikes.
For DIY:
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
http://www.parktool.com/blog/repair-help/shift-levers-shifters
May 10, 2011 | Cycling
How do i know what size to set the tire to in the comp
if i understand right , you need your tire size on the front tire and in the instructions there should be a chart with
codes for different tire sizes. Enter in the appropriate setup menu
Dec 01, 2010 | Sunlite Cycling
I have an otero mongoose bike how do i take the front tire off
The front wheel is removed by releasing the quick release located at the bottom of the fork. The tire can be removed by deflating the tire and then levering off the tire itself using a set of special removal tools.
Jun 04, 2010 | Mongoose 2009 Otero Comp Mountain Bike...
Cycling Logo
1,063 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
