How to put a password on linksys router to stop others from seeing what is on my computers
  • 255 Answers
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
Read more: How to Set up a Linksys Wireless Router ' eHow.com http://www.ehow.com/how_2091718_set-up-linksys-wireless-router.html#ixzz1HFuc1pwt
Posted on Mar 21, 2011
  • 98 Answers
You will need to log in to your router and set up the security settings. For specific details on the model you have, you should be able to go to linksys support, pick your model and look up the FAQ's or find an online manual. Often the back of your router will also say something like "unsername" and "password" with some details of the default settings to login and and start making changes.
http://homesupport.cisco.com/en-us/support
2 Suggested Answers
SOURCE: hi i have the linksys
wusb54g is linksys wireless adapter that connects to a wireless router. Are you using a linksys router? If yes, open a browser, type in the router's ip (ex. default ip is 192.168.1.1 note: don't put www or http just the numbers - if you wan't to check the default gateway go to the command prompt type in ipconfig and look for the default gateway). it willl ask for a username and password, leave username blank and the default password is admin (note: it's case sensitive - all lower case). Once you're in the router's user interface, click on the wireless tab. First tab is basic wireless settings, just change the ssid or the network name to any name you want then svae the settings. Then click on wireless security tab(one of the sub tabs under wireless). If you select wep just use 64 bit encryption then just type any key word under passphrase then click generate, write down the code under key 1, that's your security key. or if you're going to select wpa for you're security you can type in alphanumeric code (atleast 8 characters, just make it all lower case, no space, no special characters) then save it. That's how you secure your network using a linksys router.
Posted on Jan 06, 2010
Forgot user id for router
Look on the back of your router for a url (numerical Web address) that is the format of 123.456.7.8 In your PC Internet browser put said url in address bar and connect to your router. Your user id should be on the first page. If you have forgotten your password contact your service provider to reset.
However your user ID and preset password should be on the sticker on the back of your router. If none of this works contact your service provider.
Sep 25, 2011 | Linksys Wireless-G WRT54G Router
I've forgotten my security password for the wireless and want to allow another computer access. as i'm not very technical is it difficult to reset andstart again?i don't want to be without the...
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and configure it again.
To reconfigure your LinkSys, connect a PC to one of it'sEthernet ports, load a web browser, and go to the URLhttp://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." While newer models, both the default username and the default password are set to "admin."
Once you go past the login screen, you should be able to reconfigure the LinkSys router.
Here are some of LinkSys Router models along with its Default usernames:
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys WRT54G, BEFW11S4: admin
Linksys Comcast routers: comcast
All other Linksys routers: {none}
Here are some of LinkSys Router models along with its Default passwords:
Linksys Comcast routers: 1234
Linksys BEFW11S4: {none}
All other Linksys routers: admin
For those [none] username/password entries listed above, no name or password is required. Just skip or press the Enter/Return key when prompted for those settings.
Jul 18, 2011 | Zyxel (91-004-361002) Wireless Router
Forget my password
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 18, 2011 | Linksys Wireless-G WRT54G Router
Where do i put hinternet connection cord at?
1. Go to Best Buy. Get a Linksys wireless router. Hook up your internet to the slot in the back that says INTERNET. Then attach an internet wire into slot 1. Plug the other end into your computer. Repeat with any other computers. Put the CD in any computer hooked up with the Linksys. Set it so wireless connections are allowed and set a password. Use the internet channel, wait until your Linksys pops up, and enter you password. You're good to go.
Note: I was talking about this Linksys: http://www.linksysbycisco.com/US/en/supp...
2. Get a $40 Wi-Fi adapter and hook it up to your computer (assuming it has internet). After setup, You will have Wi-Fi, but it has a tiny range. I recommend the router. The router has a MUCH larger range and costs $20-$120 depending on how fast and how large of a range you want. Any router will work as long as it's wireless.
Feb 26, 2011 | Nintendo Dsi Pink Console
I have two computer set up on my linksys one
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then enable DHCP in both computer's network adapter tcp ip property so you not need to set manually ip for network.
Then save settings and restart router.
Then you can share files between computers.
Let me know if you need further assistance.
Thanks for using FixYa.
May 08, 2010 | Linksys Wireless-G Broadband Router
Trying to connect a new laptop to my linksys wireless setup and I enter the WPA key and it says it is aquiring network address, but never does. What am I missing.
Stop and start over with Router Setup by using a paper clip to press router reset button. Now, with router connected via CAT-5 cable to a computer's NIC. On this computer, using IE or other web access, go to http://192.168.1.1 to access router web setup. Set the Wireless properties, such as SSID (Network Name) and Security properties, like WEP/WPA passwords. This password will be needed by all computers accessing this router's signal. At this point, your router should be putting out a signal identified by the SSID name, all other settings for the router should be set already to the point where it will work, like the IP addresses declared in the router setup. Best left alone, at least till it is up and running. It gets the network address from your Internet Provider, and they are the only ones that can give you an IP address.
Dec 15, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
I put the password admin on my linksys model n. WRT54GS and after it checks my computer settings and its always asking for it
For linksys router by default there's no username and password is admin, and if that is not working try some of your commonly use password and see if that will work, if still no password is working the only to correct everything is to reset the router by pressing the reset button of the router for 10 seconds using a pen while power is ON and then after resettnmg password will be back to admin so you can reconfigure it back...
Dec 09, 2008 | Linksys Wireless-G WRT54GS Router...
Password problems with linksys router model n.WRT54GS
How To Set Up PPPoE DSL Connections with a Linksys Router
This article describes how to manually configure a Linksys Router for broadband DSL that uses PPPoE (Point-to-Point Protocol over Ethernet) for authentication. For automatic configuration options, please try: 1. Linksys Easy Connect (see Answer ID 1650 for more information), or 2. The Linksys Setup Wizard CD-ROM software that came with your Linksys Router. Simply insert this CD-ROM into an online computer before connecting your Linksys Router, and the Wizard will provide step-by-step instructions on how to install and configure your router. If you are unable to set up your Linksys Router by using one of the above options, use the steps below to manually configure your router. NOTE: It is recommended that you print this article for offline reference. STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Computers & Internet Logo
158 people viewed this question
David Payne
David Payne
