What network intercace card would work with an old HP Omnibook 800 Ct? I'd like to put it on my lan.
  • 449 Answers
I would recommend a PCMCIA Xircom ethernet card, probably very cheap on eBay. (But not a REALPORT model). A 3Com Etherlink PCMCIA will probably work as well. Make sure there are drivers for your OS. Make sure it comes with the "Dongle."
Posted on Mar 21, 2011
Intel EXPI931CTBLK Gigabit CT Desktop Adapter Card - PCIe Network Adapter - Cannot find file
Dring boot up go into the bios settings (usually the delete key) and make sure the "use onboard lan" or somthing like that is diabled
Jun 14, 2012 | Intel EXPI931CTBLK Gigabit CT Desktop...
I have a HP Compaq 6810s laptop and I have a 1gbps network connection for all other PCs in our office but this laptop. I am guessing that the laptop only has a 10/100 network cable port. Is that correct...
a 10 year old laptop. 2007, with XP or vista the DEAD OS.
siddiqui is wrong, there are zero chances this intel chip can go 10 time faster ever. why not look it up first , then answer>?
https://www.intel.com/content/dam/doc/datasheet/82562g-10-100-mbps-plc-datasheet.pdf
nor is second answer right, USB ports, do work. and are faster that 100....MB/S
wlan is upgradable. in all cases. even by country RF rules.
the full service guide is here
http://h10032.www1.hp.com/ctg/Manual/c02014623
no PCMCIA (PCcard slots) HP uses express card slots 2004 and newer LT.
no mini-PCI slots, for LAN.
yes, old PCs do not have Giglan ports, Ethernet 1000)
compaq 6810s you meant 6820 right? cant find anything on 6810s
zero.
the 6820 has Intel 82562G chip for this.
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
the main board has wireless module but no wired, module
the intel chip on board does all that. Ethernet slow.
to upgrade , the only path on stinky laptops is USB ports.
a USB /LAN dongle and express card slot.
the problem is getting USB to fast enough,
it has 3 x USB2.0 (not usb 3, that came out 2 years later)
usb2 is 480Mbit/sec rated ports.
1000
so what can you expect from a USB 2 /lan dongle?
ego this. (ive never tired it on my old LT (cache)
http://www.ebay.com/itm/V-TOP-3-Ports-USB-3-0-Hub-with-10-100-1000-Gigabit-Ethernet-RJ45-Converter-LAN-/263162996726?epid=1674717381&hash=item3d45bca7f6:g:EawAAOSwzPBZnXgT
you can not get 1000 mbit/s speed of any 480port. USB2
1 gigabit per second, (or gigalan speeds)
but try it, see how fast it can go on USB2.
be fun to try and some are only $10 cost, search find, try./
this PC has an Express CARD port.
if luck this might work but are not cheap
http://www.ebay.com/itm/StarTech-EC2000S-StarTech-com-Dual-Port-ExpressCard-Gigabit-Laptop-Ethernet-NIC-/182211847012?epid=691202531&hash=item2a6cac2364:g:kv4AAOSwRgJXj1tC
i can not tell you it works in the HP, at all, why not ask HP
we are not HP here,at all.
this is HP. real.
https://h30434.www3.hp.com/
here is your express slot hiding here. see it, learn about it?
#2 is it. in your service manual, its seen., minehave filler cards there, dummy cards, you remove that and slide in any express card you can find,for version level matched.
finding drivers for XP will a BEACH.
Oct 03, 2017 | HP Compaq Network Adapter
Dose the hp omnibook xe4100 have wirless or do i need a wireless card
You could do with the instruction manual, download from here:-
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/lpi06480/lpi06480.pdf
On page 14, it shows where the wireless on-off button would/should be
on page 67 it states:-
If your computer includes a wireless on-off button-located on the right side of the front
of the computer-you can connect by radio to a wireless local area network (LAN) and
access computers and other resources on the network.
A wireless network provides all the functions of a typical "wired" network, but also
provides for "roaming." Since your computer connects to the network by radio rather
than through cables, you can move from place to place within the network-from your
office to a conference room, for example-and remain on the network the entire time.
Dec 31, 2010 | HP OmniBook XE4100 Notebook
HP ProLiant ML350 G4 72.8 GB Network Storage Server i have used this working good but having lan card problem
usually that means the card is busted, a new lan card can be found for as little as usd 10$ and it is a plug and play installation
Sep 26, 2010 | HP ProLiant ML350 G4 (375638001) 72.8 GB...
Wireless set up with Omnibook XE2-DB Windows 98
there is no support for PC that old at all. and for sure windows 98
heck goodWill stores , throws those in the trash help,
they are no longer viable. period
same store sells $10 laptops that are 10 years old with Windows 7
and 100000 better than that old hunk of junk,
sorry but that is a fact.
RadioLan 140 PCMCIA (now called PC-card, i like the old name too)
what make you think they still in business or even sell driver for it.
company from 1999 , the book on it says
that card came with a Disk to install the driver, lost that.
good luck finding THAT. (omg, so rare... )
http://manualzz.com/doc/769802/radiolan-140-mobilink-user-guide
this old note book , no longer supported by HP or MS
has 1 USB port , no wifi, no ethernet, yes, dial up modem.
if USB works (test it , i bet it dont")
they try to buy a USB,wifi dongle that has windows 98
drivers with it. Be hard to do and the software if downloaded
will be rife with viruses...
The choices are , again.
1: that dial up port, there called the modem jack.
2: PCARD that has drivers for wifi, seems your are (rare to none)
3: USB wifi with win98 drivers.
4: USB with ethernet port, and win98 driver (most dont)
or get a real PC> from Goodwill for like $10 ,
or 2010 and newer PC of any kind from anyplace.
get one with W7 and newer OS for full support.
this thing you have is like finding parts for a Dueseberg car.
these old laptops are seen in garage sales for $1
due to the lack of support. and the fact that putting say
a new HDD is 100x more.
May 27, 2017 | HP OmniBook XE2 Notebook
Internet link
No, you need purchase PCMCIA or USB external wireless card, because Omnibook 6000 not have internal wireless card included
Feb 22, 2009 | HP OmniBook 6000 Notebook
Upgraded to vista and lost my sound card driver
Download sound driver and install it:
Click here
post back if anything changes and vote all answers.
Good luck
Feb 07, 2009 | HP OmniBook XE3 Notebook
Re: Hi :) plese help
try to refer this problem to your manufacturer/ store owner of your laptop because most probably its either your memory(RAM) or your video card needs to be reset.it may have loose their connections.
because in the desktop PC's, these are the common problems especially upon booting up your computer.
Jan 16, 2008 | HP OmniBook XE3 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
