Question about Whirlpool Washing Machines
Can I use color safe bleach in my new cabrio, and if so where do I put it?
    Sniper:
  • 68 Answers
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Posted on Aug 04, 2008
How to unclog Whirlpool Cabrio Washer Bleach Dispenser Full of Water?
hot water will be safe yes u can remove the dispenser but may be a bit difficult to figure out it should just snap and pull out once disconnecting the hoses
Mar 17, 2015 | Whirlpool Dryers
I have deep rust appearing around the bleach port. machine is only one year old. WHY is it rusting ?????
Samsung does not recommend the use of chlorine bleach in this machine. The bleach port is intended for color-safe bleach only. Chlorine bleach is an oxidizer that will accelerate the corrosion process of the drum, which is what you are probably seeing. The users guide for your machine states specifically that you SHOULD NOT put liquid chlorine bleach into the bleach port.
Aug 13, 2014 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have purchased a kenmore Front-Loading washer model #796.4044. The instructions state that I can mix some colour safe bleach in with the high efficiency (HE) detergent. Is there such a thing as HE...
This is not a technical answer, but we have the same appliance and have not found any HE Color-Safe bleach. We use the Clorox Color-Safe and just use less-- and mix it with the detergent. I've seen other feedback saying to put it into the bleach tray, but we have not done this-- just put some in with the detergent.
We make sure the entire tray area and inside the rubber rim of the door (under it) and anywhere else there's water is totally dry before closing the tray and door, and we've had no problems at all. We also occasionally run a 'clean' cycle through with regular bleach only.
Hope this helps somewhat at least-- Best of luck!
Jan 20, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Can you put color safe liquid bleach in the bleach dispenser.
Their is no mention of a problem in anything I have come across so far that indicates their would be a problem with using any type of bleach.
As long as it is placed in the correct dispensing tray and the correct amount.
Apr 19, 2010 | LG WM2101HW 4.0 cu.ft. Washer
Bleach???
Yes that is where you put it - and NO - it does NOT need to be He if you adjust the amount.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Dont' know where to add bleach alternative
yes clorox 2 or "dry type" bleach should be put in with the detergent. only liquid bleach will go into the bleach dispenser.
also be sure to use soap that is "HE" type or you will get too many suds and a washer that will smell from not rinsing out.
Mar 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Bleaching subsequent loads
I'm no repairman but here's a coupla thots:
1 - try running an empty load after bleaching. Save money and just use cold water. First add a few cups of water to the bleach dispenser to help flush out the old bleach that might remain, then run it.
2 - lemon juice is naturally acidic and should neutralize the bleach. You could add some to the bleach dispenser and do the above. Maybe mix a half-cup with a few cups of water and put in the dispenser, then run it. (Lemon juice [or vinegar] is good thing if you get bleach on your hands, too.)
OF COURSE -- Test to see if this works with a couple colored rags before running any good clothes through.
3 - How about using oxygen bleach alternatives (color-safe bleach) instead of regular bleach?
I suppose there could be a problem with your dispenser, idk....
Feb 20, 2009 | GE WBSE2090A Top Load Washer
Automatic bleach dispenser
Using too much detergent could cause a baring effect that looks like it has been bleached.
Aug 20, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
643 people viewed this question
Dan Webster
Dan Webster
Sal De
