Question about DEC VT520 Terminal Network Terminal
I used vt520 to connect to sun 890 server how to break the OS to ok prompt?
  • 449 Answers
Send a BREAK signal, if the Sun server allows that. If will be F5 on a VT520 keyboard or CAPS LOCK+PAUSE on a PC keyboard attached to a VT520.
Source: http://www.carnagevisors.net/dec94mds/vt520ina.pdf
Some Sun Servers require a special sequence to get into the ROM "OK" prompt, namely +~+^B (in a 5 second window)
Details: http://www.freebsd.org/doc/en_US.ISO8859-1/articles/console-server/solaris.html
Posted on Mar 21, 2011
  • soheirm Mar 21, 2011
    it doesn't look like it wants to break at all
  • Phil
    Phil Mar 23, 2011
    Ok, then I will need more details if you'd still like help. It could be that the server is set never to break. It is a sophisticated topic and requires some knowledge of your Sun setup.
    More tips on break:http://sysunconfig.net/unixtips/solaris....
How to get an image with a KVT100A Black Box?
You need to run the KVT100A software on your laptop and the VGA has to connect to the KVT. You dont know whether there is video on the vga, connect a monitor to the vga port on the server and have a look. If not check server bios.
May 14, 2014 | Sun Microsystems SEUPDPE2Z Sun Sparc...
What does Media boot failure on a sun server v210 mean
Either the hard dive with the OS is defective and should be replaced or the boot ROM is no good and needs to be replaced.
Feb 11, 2014 | Sun Microsystems SUN V210 Server 2x1.34GHz...
Network driver download
sunfire v20z linux broadcom driverAccording to the following PDF: http://docs.oracle.com/cd/E19121-01/sf.v20z/817-7183-12/817-7183-12.pdf
, a .zip file containing Windows drivers, including a Broadcom Device driver is located at http://www.sun.com/servers/entry/v20z/downloads.html
For Linux and other OS drivers, you need to specify the version you're running, or add it to these Google search parameters:
sun fire v20z linux broadcom driver
(Broadcom came from the available Windows drivers. It's possible that another NIC device is installed.)
Oct 29, 2013 | Sun Fire V20z Server
My sun microsystem server can not boot device
Boot Sector is compromised. Needs OS re-install.
Sep 24, 2013 | Sun Microsystems Fire V1280 Server
How can i get an ip address
Firstly, what operating system are you using?
applicable for windows xp or windows 7. press Windows Key + R
select the appropriate network connection (e.g. Local Area Connection). Right click the Local Area Connection choose Properties. For windows xp, doble click Internet Protocol. For Windows 7, double click Internet protocol IPv4. choose Obtain an IP address automatically. press OK. right click again the Local area connection then choose Status. there tou can see that your computer is negotiating for an IP address from the dhcp server. if still cannot obtain an ip address, press Windows key +Run then type "services.msc". scroll down and find DHCP client. ensure that this service is running.
Please also try to check if the network you are connected does have a DHCP server.
Jul 01, 2013 | HP Compaq nc6220 Notebook
Sun E450 Will Not Power Up
dear sir plz sot out my problem
problem is sun ultra e450 server dc fale error how to solve
Jan 06, 2012 | Sun Ultra Enterprise 450 Server
Local area connection doesnt have a valid ip connection
1. Powercycle you equipment ( Unplug power for 15 seconds and plug back in) make sure that you are directly connected. 2.Open your network connections to do that depending on your OS operating system. Windows XP: Start/Run/Type ncpa.cpl and hit ok Windows Vista/7 Start/Search Bar/Type ncpa.cpl and hit Enter. 3.Windows XP: Double Click on Local Area Connection and hit properties, Click Internet Protocol and hit Properties once again. Ensure Obtain an Ipaddress automatically is checked as well as Obtain DNS server automatically is checked as well if not check them both. Close out of Network Connections. Windows Vista/7: Right Click on Local Area Connection and hit Properties, Uncheck Internet protocol Version 6 IPV6 and Click on IPV4 and hit properties. Ensure Obtain ipaddress automatically is checked as well as Obtain DNS server automatically is checked if not check both. 4.Restart Computer 5.Open Command Prompt: Windows XP: Start/Run/Type CMD hit ok Windows Vista/7 Start/All Programs/Accessories/Right Click Command Prompt and hit Run as Administrator then hit continue. 6. In Command Prompt Write the following commands remember to hit Enter after each command. netsh int ip reset reset.log netsh int ip delete arpcache netsh winsock reset ipconfig /flushdns 7.If unable to renew ipaddress scan for Viruses inside your computer using a security software and if you are still having the issue refer to manufacture. Good Luck 7. Restart Computer
Jan 13, 2011 | D-Link (DI-711) Router
Hello, I have a SUn Enterprise 420 server which dose not have a video card nor are the seral consoles working. Is there a way to reset the console? S.
Dear,
Which console your are using. 25pin port or RSC PCI card port. If its 25pin port, no way to reset other than power off and poweron but, in case of RSC card, you do a resetrsc from OS also,
Sep 29, 2009 | Sun Enterprise 420 (RA33-ULD2-9S-002EJ)...
Sunfire v480 when powered on not showing anything on monoitor server was working last 4 years without any problem
Dear,
If your server came up without key board and monitor on last boot, you wont get anything by connecting monitor. you have reboot the server by making user, input device=keyboard and output device=monitor you can see this value by using eeprom command from os you set this value eeprom input-device=keyboard eeprom output-device=monitor
Jul 13, 2009 | SunFire V480 UltraSPARC III...
Redhat es5
This model was found not to be 64bit but 32bit.
May 18, 2008 | HP Compaq ProLiant DL380 G4 Server
DEC VT520 Terminal  Network Terminal Logo
172 people viewed this question
Top DEC Computers & Internet Experts
gary433
ugeeks
Level 1 Expert
Are you a DEC Computer and Internet Expert? Answer questions, earn points and help others
