My pilot keeps going out - Heating & Cooling
    Brigadier General:
  • 4,736 Answers
It would really help to know what type (Manufacturer & Model Number) this gas appliance is?
Posted on Mar 21, 2011
Why doesn't the pilot stay lit?
Why Does My Gas Furnace Pilot Light Keep Going Out?
santafeair.com/blog/.../why-does-my-gas-furnace-pilot-light-keep-going-...
Jan 10, 2014 - The thermocouple is the copper rod you see the pilot flame hitting. It's a safety device that controls a small valve to shut off gas going to the pilot ...
Aug 11, 2015 | Kitchen Ranges
Pilot goes out
The pilot may no be strong enough to keep the thermocouple active . check to see that the pilot is engulfing the thermocoupler completely.
You may have to adjust the pilot for a stronger flame or you may have to clean the pilot orifice if it is dirty. Hope this helps.
Dec 30, 2013 | Blodgett 1060 SINGLE Gas Pizza Deck Oven...
After oven reaches desired temperature, it has late ignition that turns off the pilot AND OVEN WILL NOT STAY ON.
Sounds like the pilot is mounted to far away from the burner. I have seen it happen before where the pilot has detached and the main burner will just keep pumping gas in until it hits the pilot flame and just flash flames and everything goes out.
Or it just could be a bad thermocouple that is going out all the time.
Mar 01, 2013 | Southbend S36D 36" 6 Burner Gas Range,...
What would cause the pilot light on a gas heater to keep gooing out
Make sure you have a clean and strong pilot light. Take a rubber tube and blow the pilot head to make sure something didn't partially block your pilot when it was off reducing the heat to the thermocouple or thermopile.
Dec 31, 2012 | Desa International Heating & Cooling
Remeha boilers - pilot light keeps going out
You Need to replace the Thermocouple. You can get them at most hardware stores take the old on with you
images?q=tbn:and9gcs197mmasu0-olkj-42wttmbnfimgyu0r1wy_jdi-wq-_xsajtbwq
Nov 22, 2012 | Water Heaters
Pilot LIGHT KEEPS GOING OUT OUT
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. If the pilot light has only a weak flame, the whoosh of the main burner igniting can quite often blow out the pilot. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If pilot flame goes out for any reason, it shuts the gas off to the pilot jet to prevent unburned gas collecting and causing a safety hazard. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced.
Oct 29, 2010 | Heating & Cooling
Water heater pilot and burner keep going out.
If this is a common occurrence, then it may be time to replace the thermocouple that controls the pilot part of the gas valve. If it still keep going out, gas valve may be faulty.
Jun 29, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Why does the pilot light keep going out?
Make sure your pilot flame is hitting the thermocoupler. If not then use air to clean pilot port and try again.
May 05, 2010 | Water Heaters
Pilot light keeps going out! difficulty lighting
Dirty pilot, you may need a contractor.Tom
Jun 18, 2009 | Heating & Cooling
Pilot keeps going out
The pilot assembly, pilot oriface, and pilot burner should be cleaned and the thermocouple replaced.
May 01, 2009 | Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
