Question about Bosch PGL985UC 36 in. Gas Cooktop
Can't find replacement burner knobs for my PGL985UC Bosch stovetop gas stove
  • Bosch Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 21, 2011
I have bosch pgl985uc burner problem. The center burner will not stay lit. Seems other have had this problem. I ordered all new thermo-couplers. Installed, since Bosch changed them to a new part number...
If The Burner lights and stays lit as long as the knob is depressed, but goes out after the knob is released then there is a failure with the thermocoupler or the valve itself. The thermocoupler can be tested once removed from the cooktop - as follows
Heat the tip on the thermocoupler with a match or lighter and measure the electrical connection (other end) with a voltmeter - it should read about 15 mV or slightly more with in a few seconds. If no voltage is read then the thermocoupler is faulty and should be replaced.
The valve coil can also be tested for continuity at while the unit is disassembled. If no continuity is found the valve is faulty and should be replaced
The small voltage created from heating the thermocoupler energizes the coil in the valve which in turn keeps the gas turned on while there is heat at the thermocoupler.
Some units actually reignite the burner if the heat is lost and the control knob is in the on position.
Hope this helps ....
Dec 14, 2013 | Bosch PGL985UC 36 in. Gas Cooktop
Igniter stays on on the center and back right burner
If there is a relay it could possibly be sticking.
Oct 14, 2013 | Bosch PGL985UC 36 in. Gas Cooktop
The burners light, but it takes an inordinate time for them to stay lit. One of the burners will not stay lit when the knob is released, regardless of how long you depress the knob.
Need a new fsd ( looks like a small brass pencil) for the burner that won't light. The alignment of the ignition electrodes needs looking at and there over all condition I. E broken , worn , misaligned ect
Jul 13, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
I have the same problem especially with the center burner, but now am having increasing difficulty with two other burners. Those will eventually stay lit if I depress the knob for 20 - 30 seconds. The center burner will not stay lit, even when keeping the knob depressed for 2 - 3 minutes!
Mar 19, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
The stovetop keeps throwing the breaker box and when i had my finance to turn it back on and i was looking at the stove it sparked from the knob area. can you you tell me what i can do to fix this problem
Replace the switch and the burner. You probably have a loose wire ... it is just a little more work and safer to replace both the switch and burner.
Get replacements from FixYa.com advertiser or at your local appliance parts place ot visit www.repairclinkc.com
thanks for your interest in FixYa.com
Please vote
thanks
a
Dec 01, 2009 | Brown Stove Works 23 in. EL03 Electric...
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
Recived spark module for 6 burner gas stove on DCS gas oven/
I want to gas geyser using sparking unit (ckt Diagram)
Feb 28, 2009 | DCS Cooktops
Bosch PGL985UC 36 in. Gas Cooktop Logo
221 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
Narinder Chhina
Narinder Chhina
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
