Question about Microwave Ovens
Need to know amps for installation, please. thank-you
    Brigadier General:
  • 8,909 Answers
USA (110 Volts) requires 20 Amps available and UK (240 Volts) 13Amps.
Posted on Mar 21, 2011
  • 591 Answers
Look for the sticker in the back you should have the Amps, the Volts, the Power, if you have the Voltage and the Power than you have to do a litle math... the Amperidge is obtained from deviding the Power from the Voltage ex:
Voltage is 120 volts, Power is 90 Watts than the Amps would be 0,75 Ampers (90W / 120V = 0,75A)
Cheers!
  • Tommy
    Tommy Mar 22, 2011
    By the way I'm not talking about the microwave oven's wattage (heat capability), but the electrical wattage (what it consumes) if it is a standard counter top model a 15 amp circuit should be more than OK, but if it's a range combo unit, then it would take much more...
The microwave trips the breaker when used twice in a row.
First, verify that the appliance is the problam or not.
Get a clamp-on ammeter, such as this one: https://www.walmart.com/ip/Digital-Clamp-Multimeter-AC-DC-Voltmeter-Ammeter-LCD-Ohmmeter-Tester-Meter/272114348?wmlspartner=wlpa&selectedSellerId=7754&adid=22222222227092377675&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=213509462359&wl4=pla-346089952276&wl5=9001910&wl6=&wl7=&wl8=&wl9=pla&wl10=115794707&wl11=online&wl12=272114348&wl13=&veh=sem
This can tell you right away if the appliance is drawing too much current.
A loose connection in the screw terminals on the outlet can cause the appliance to draw excessive current. If you house was built in the 70's, you might have aluminum wire. Sell the house and move since aluminum wiring is no longer legal to install due to the extreme fire hazard aluminum wire presents. Seriously, if you have aluminum wiring, then every junction needs to be checked. Every screw terminal, every wire nut.
Finally, you could have a bad circuit breaker. If the clamp-on ammeter says your appliance is drawing 10-Amps and the 15-amp breaker trips, then replace the breaker.
WARNING- If you don't know what you are doing around lethal voltages, hire an electrician.
Oct 28, 2017 | Frigidaire Microwave Ovens
I have an old GE Microwave jvm240av001 and would like to know the specs so I can replace it. It is so old (1995) I can not find anything on line. Please let me know if you can help. Thanks so much!
Hi and welcome to FixYa, I am Kelly
(trim kit required)
For all newer units the dimesnions are
15 & 3/4" high 16 & 1/2" high hole required for vent connection in rear
15" deep
Needs a 30 inch wide hole for installation
or call GE 1-800-626-2005
Use this link for all models OLD and NEW:
http://www.geappliances.com/service_and_support/literature
To get dimensions you look up installation manuals for each model.
Your manual cam up here: (1.51 Mb)
http://www.geappliances.com/search/older-pdfs/49-8621.PDF
Your microwave is not vented externally but your replacement microwave will be capable of being used in a non-external vent and an external vent cofiguration. Personally.... I would recommend the external vent installation. Either will work.
Thanks for choosing FixYa, Kelly
Sep 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
We have problem to remove our microwave from the wall brackets- Whirpool model MH7140XFZ-year 1999. Please give us advise how to do this?
Whirlpool maintains a library of free downloadable literature for nearly all of their products. Your MH7140XFZ microwave oven is no exception. The site contains owner's manuals, installation manuals and parts lists. Your answer will be found in one of the two installation manuals. You should review both to determine which best applies for your particular installation.
Referring to manufacturer's literature is always the best source for information - so I did not want to paraphrase anything in it - especially since it is readily and freely available.
I hope this helps & good luck! Please rate my reply - thank you.
Feb 17, 2011 | Whirlpool Microwave Ovens
I need to know how to linstall it as I lhave no
You can download the complete installation manual in PDF format from GE XL1800 support website by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Jul 09, 2010 | GE XL1800 1100 Watts Microwave Oven
New smart board installed in microwave, still doesn't work
It sounds like he "shotgunned" and blamed the board without experience enough to know the difference or to test it.
We would need to know what exact problem you're having and what your full model number is.
Feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 25, 2010 | GE Microwave Ovens
INSTALLATION INSTRUCTIONS Want to know the proper height above the range to install it. thanks wayne
If the model number you have this question listed under is correct, your manual is available in a .pdf (Adobe) format that you can download or print for FREE. Just go to managemylife.com and type in your model number under the "Manuals" link. Then, narrow your search to the Installation Guide link. If you need further assistance, please let me know. I hope this helps you.
Jan 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our handle broke on our GE Microwave convection ove need a new handle or door Model no JVM1190BY 002
Here is a link to PartSelect.com, I have used them for my microwave repairs in the past and they usually ship the items fast.
I have put in your Model number, but the closest that I could find was JVM1190BY003. You can look at the picture and determine if the parts look the same and the picture will show you that you will have to take the entire door apart, (You may already know that).
http://www.partselect.com/ModelFrames.aspx?ModelID=386757&ModelNum=JVM1190BY003&mfgModelNum=&ManufactureID=2&Selected=00110600i01&Position=1&mfg=GE&Type=&Mark=1
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Oct 26, 2009 | GE JVM1190 Microwave Oven
It does'nt any thing, the screen is off
you dont need schematic.......If micro is dead ,you more than likely...have a blown 15. amp ceramic fuse inside.....MAKE SURE PLUG IS OUT....open the unit and look inside...you should be able to find,,,,,If problem is other, let me know.
May 21, 2009 | Microwave Ovens
I don't have a problem, I would like to know if it is possible to purchase parts for the toastmaster #287 waffle iron? We have a toastermaster#287 & we love it. I took it apart, cleaned it inside &...
For Toastmaster residential consumer products, please visit Salton here or here or e-mail to consumer_relations@toastmaster.com
Oct 07, 2008 | Microwave Ovens
Have a microwave model NNSA616W, sre 6C37231152 purchased in 2007. Am aware Panasonic has sent memo to distributors to install 20 amp fuse instead of the 18 amp that was in this model when it was...
PANASONIC BELIVES SERVICE IS THE INTEGRAL PART OF ANY BUSNESS. SO YOU CAN INFORM YOUR EXPERIENCE TO THE SERVICE DEPARTMENT OF PANASONIC IN YOUR COUNTRY.
Apr 07, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
