Question about Gestetner DSc332 Copier
Hello I have 232 Aficio copier.I have error SC 221 Thanks When I run the machine red lit lamp maintenance and gives me the error code SC 221
  • 255 Answers
SC221: Scan Length Error Detection". For further help regarding this problem,refer to http://www.copytechnet.com/forums/ricoh-savin-gestetner/42342-mp5000b-sc-221-a.html
Posted on Mar 21, 2011
Error sc542
SC542 is a fuser related error code, this will need to be reset.
Probable causes are:
• Defective thermistor
• Incorrect power supply input at the main power socket
• Defective fusing lamp
Corrective actions :
1. Check the voltage of the wall outlet.
2. Replace the fusing unit
3. Replace the fusing lamp.
Resetting the code:
Execute "Fuser SC Reset" with Some (printer models) or "Engine Maintenance Menu" (MF model) to recover the machine after completing the recovery procedure. Otherwise, the machine continues to issue this SC code and cannot be operated.
Sep 02, 2014 | Ricoh Aficio Sp C320dn Laser Printer -...
Copier error code 221
We are assuming that you are talking about Error Code SC 221
This code is a Scan length detection problem.
1.Disconnected Sychronization Detector
2.Bad LD-Unit/BICU Board
SOLUTION: Replace the Laser Diode & Laser Sync detect board
Hope helps (remember to rating this free answer).
Oct 12, 2011 | Ricoh Aficio 1232C Color Copier
Ricoh aficio 1018d sc 544
Hello!
This code is related to a Fusing low temperature error.
You probably need to change Hot roller (or fusing rooler) and thermistors.
You can reset this code but it will pop-up again sooner or later.
The best advise i can give you is to call a technician (if you do njot have technical knowledge)
If you still want to reset the code tey this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Exit all the way out.
Turn the machine off and on.
Hope this helps you
Aug 03, 2011 | Ricoh Aficio 1018D Copier
Error sc 452 shown on my aficio 452 color copier how to rectified
sc 452 is a thermistor error code for the fusing unit of the copier. Try pressing these buttons in sequence. (yellow key) (1).(0).(7) (red Clear/stop key) and hold the red key down for 5 seconds. When the 3 or 4 boxs appear, turn your copier on and off with the main power switch. If the error code comes back then contact the seller of your copier and ask for technical service.
Oct 12, 2009 | Ricoh Aficio Colour 3006 Color Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Error code sc 306 aficio 1022
I don't show a "306"....please re-check the code.
Have you tried turning off the main power (red button on front), and/or unplugging the machine to try to reset it?
Mar 18, 2009 | Ricoh Aficio 450e Laser Printer
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Error message sc 172 on ricoh aficio color 2103
You'll need a tech on site for this one, but it may be difficult to source parts if required for this old box. One of the following situations has occured:
• Poor connection of CCD
harness
• Dirty optics
• Defective lamp regulator
• Defective main scanner IPU board
• Defective CCD
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
559 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
