Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Convergence problem with 53tw53tg
Changed stk110s still seeing double convergene on remote is not working
  • maobreezy Aug 03, 2008
    how would i know if resistor are bad what do they look like
    seeing double cant convergene with remote wont move at all
  • Panasonic Master
  • 8,617 Answers
Did you check the convergence feed resistors? its not uncommon for a few of those to go open when the ICs go out.
Posted on Aug 03, 2008
  • Sonny Berry
    Sonny Berry Aug 03, 2008
    You will have to lift up one side of the feed resistors and check them for resistance with a ohms meter. Do you have the service manual for your model? You will need that to locate the low ohm feed resistors.
The remote does not work the TV have put in new batteries
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
Jan 12, 2017 | Televison & Video
The remote has stopped working so the only way I can change channels is on the actual tv
Easy way to test an infrared remote is to point your camera at it and then push a button on the remote and look for the purple color on the camera, If you don't see the color AND the batteries in the remote are new AND installed correctly, it is time for a new remote.
Why will the volume on my remote control for my tivo box not work when everything else does
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Jan 12, 2017 | Tivo Televison & Video
My Toshiba remote control se-r0077 sometimes works to control the DVD player and other times it doesn't. I've tried new batteries and the problem still persist s
One of the best ways to check if an infra-red remote controller is working properly is to look at it using a camera. (a webcam or phone camera will work) The camera will see the infra red radiation as visible light. If the LED lights up (on camera) consistently when buttons are pressed, then it may not be the remote at fault, but rather the receiver in the DVD player. Most of the time though, it IS the remote control at fault, and these are usually easy to get working again.
Couple of things to check are:
1) the battery terminals...
Batteries can leak and corrode the terminals in the battery compartments. Signs of this include rust, green coloured contacts, or a crystalline deposit. If you see any of this then clean the contacts using metal cleaner or some methylated spirit and cue-tips.
2) Broken wires connecting battery terminals to the circuit board...
The soldering in some remotes can be rather poor, and wires can sometimes come loose, especially if a remote has been dropped or bashed about a bit. Unscrew the remote and check everything is connected properly
3) Dirt under the buttons...
This can prevent a button from making contact with the circuit board properly. Unscrew the controller and separate the rubber button pads from the circuit board check for dirt both underneath the pads AND on the metal contacts on the circuit board. Clean as required with methylated spirit and cue-tips and then reassemble.
Hope that helps!
Jan 07, 2017 | Toshiba Televison & Video
I've tried to set up a Bose remote to my TV and B Ray player. I can get the programme change, menu and the channel guide working but not the volume + or - .I've tried other codes as instructed.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jan 06, 2017 | Bose Televison & Video
My UR5U -9020L remote won't change channels or pull up the guide?
how long have have you had the remote and is this the first time this has happened and when was the last time you changed the batteries?
Nov 26, 2014 | Televison & Video
Can i buy remote control
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchased a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier. Or type in the brand name of your device in the search box, and press "Enter".
Universal remote controls are available at most of the electronic spare part selling shops.
Jun 23, 2014 | Televison & Video
Hitachi 43fdx01b lost remote and somehow audio is change to second output and I need to change it to audio how do I do this without the remote.
well it may be a silly solution " i don't know this T.V but if i were you i would played in everysingle button in that screen ... it won't get worst i wish you could solve it or you maybe buy a universal remote i tried it and it works it signal is week but it is better thatn nothing
May 17, 2014 | Televison & Video
Blu Ray - DVD player does not respond to remote
Did you check to see if remote pickup on player is cleal and not being blocked?
Dec 15, 2013 | Televison & Video
Devant ER 31951D remote
Aug 23, 2013 | Coby TF-TV3217 32 in. LCD TV
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
22 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
