Question about Whirlpool WED6400S Electric Dryer
Have a whirlpool electric dryer. My wife said that she noticed a burning smell from the back of the dryer while it is running. The clothes are still being dried though. Any suggestions? We have had this dryer for a number of years. Thanks. Eugene Joseph
  • 4,350 Answers
Usually, lint has found it's way into the burner chamber. This is often evidenced by small brown spots on clothes. To resolve, unplug the machine and open it up and investigate the burner area.
When finished cleaning, remove the outlet hose, turn on the unit and form an opinion about air flow.....Hook hose back up, turn machine on, and go outside the building, and verify very similar air flow volume. Any restriction will slow drying and allow more lint to get drawn into the air inlet.....
Posted on Mar 21, 2011
Dryer shutting off too early. Faint smell of something burning?
Check the vent for clogging condition that will turn off unit and cause it to overheat. If vent goes up to roof check up there also - that is where mine was clogged with a sort of paper mache clog!!!!!
Sep 02, 2017 | Whirlpool LER4634J Electric Dryer
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
Initial gas burn does not reignite
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE;
Jul 26, 2008 | Whirlpool LGR7646E Dryer
Duet Dryer
burning smell would be coming on the coil of an electric dryer. the coils could have catch some lint that produces that distict burning smell..
i hope i was able to solve you problem..
pls rate me.
tnx
drcool
Jul 15, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer smelling hot and smoke detector goes off
clean the venting going to the outside and the dryer really ahould be taken apart and delinted to avoid a fire if the unit is older
Mar 21, 2008 | Whirlpool LER5636P Electric Dryer
Dryer smells hot
hi ,
run a load in fluff no heat and see if the smell develops again, if it does then I would suspect the motor or belt. generally most dryers are serviceable from the rear, the whole back panel usually, make sure you unplug it of course. make sure your not overloading your machine with clothes. It should never be more than half full ever. a slipping belt causes a burnout smell like when a car spins its tires at the races, if thats it you might need a new belt or your idler pulley may need to be bent a little so the belt runs tighter, study it
J
Jan 23, 2008 | Whirlpool LER5636P Electric Dryer
My Duet Whirlpool Dryer (had this #8519498) has burning smell
I am not the Dryer fixin' trade...but I have this dryer. To me, it sounds like it overheating or the heater unit has become lose from its hold rack. I would MOST definitely have a pro look at it and do NOT leave the dryer unattended...It may be a possible fire hazzard
Take Care
Wayne
Jan 03, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool WED6400S Electric Dryer Logo
145 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
