Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Doesn't **** up water - Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
My bissell proheat 2x mutisurface turbo model T doesn't suck up the dirty water
take water container off and when you put it back on make sure it seals
May 20, 2014 | Vacuums
My Bissell proheat2x leaks water from bottom of machine, if you have the water tank full and cleaner and leave it sit it drains out onto the floor, it leaks when you are using it to, is this a seal or...
Nope, not a seal problem, just natural good old fashioned natural gravity. I know it doesn\'t take long for it to start leaking after use but Bissell covers this in the manual. Thoroughly clean the unit, run clean rinse water through every cycle and empty all tanks and cavities after use. Do not leave water in any of the tanks when not in use. What doesn\'t leak on your floor (which doesn\'t take long) could cause permanent blockages in the lines. It\'s a pain, I know, but I use the garage or back deck to park and prep mine after use.
Aug 15, 2013 | Vacuums
My lightweight hot tap water bissel carpet shampooer will not stop dispensing water. The trigger doesn't seem to be able to close the nipple like cover. I cleaned my machine well. Is there a cable...
Hi Sue. Sorry to hear about the difficulty you're experiencing. You may want to have one of our Authorized Service Centers inspect your machine.
Here's a quick link to help you locate one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
May 04, 2013 | Vacuums
Doesn't pull water from clean tank.
Hi Teri. You may want to have one of our Authorized Service Centers inspect your machine.
Here'a a quick link to help you locate one in your area:
Mar 27, 2013 | Bissell 1200A SpotBot Pet Robotic Vacuum
Hoover f7411-900 steamvac dual v, water heating unit repair
The element is burned out or the sensor is shot. When there is no water present a sensor is supposed to turn off the heating coil. This sensor is most likley fail safe, meaning if it is broken it wont turn on the heat because it doesn't know if there is water or not. Or the coil itself is fried. Somtimes running it for too long, or on a long extension cord will cause them to fail.
Oct 08, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
How to fix shark vac then steam that doesn't emit steam
Replacement parts can be found on amazon, take a look: Amazon com shark vac parts . Have a nice day
May 08, 2012 | Vacuums
Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
I am at my daughters trying to clean her carpets and i want to know if i set it up right to shampoo her carpets . i only put water and solution in the small container in the back,but i didn't add it...
The smaller container in the back under the release handle it the cleaning solution resevoir. The larger one in the front is for the hot water. It has an internal bladder that holds clean water in this larger container, while returning the dirty to the outer bladder chamber. Both need to be filled with water at the very least in order for the machine to work. If either goes empty, the machine will stop working.
Sep 01, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
My steam vac is leaking water. It still works, but how do I fix it from leaking out the bottom?
It cost me $65, had to buy a new clean water bucket. If you shine a light on the bottom you will see a shatter effect much like broken shatter proof glass in car windows, apparently it is cheap and doesn't last. Who knew?
Jun 10, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
54 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
