Question about Homelite Gas, 20 In. Bar, 46 CC, Chain Saw, UT10520
My Homelite UT10526B Chainsaw is brand new. It has only run for about 1 1/2 hours. It just stopped and won't start back up. It has fresh gas and it seems as though I'm not getting spark even though I put a new spark plug in it.
    Master:
  • 403 Answers
Return it, any repairs from you will void the warrenty
Posted on Mar 21, 2011
On the homelite DM 50 model 05020 what is the fuel mixture ratio?
What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Oct 25, 2015 | Homelite Garden
Homelite Timberman 45 chainsaw runs fine but will not idle. Ideas?
dirty carb specifically in the idle jet turn it in till it bottoms . do not force more then return to the same place it was set if 3/4 turn in turn out 3/4 see if it works better .
Feb 16, 2015 | Homelite Garden
Zama carb pulls gas when not running
throw the carb out and buy a new one. there is an internal issue that can not be fixed
Mar 20, 2013 | Homelite Garden
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
HOMELITE 4618C CHAINSAW WON'T RUN
How long has the chainsaw been sitting? How long has it been sitting with the same gas in it? Typically, most chainsaw and weedtrimmer repairs are fuel related. More times than not, simply draining the old gas, and putting brand new fresh mixed fuel just purchased from the gas station will fix most non start problems. Many people will not believe me, but after 20 years of fixing small engines, i've fixed 70% of the chain saw and string trimmer and related sized engines by putting in new fuel. Fuel goes bad now a days in 30 days. So if the fuel in the gas can sitting in the garage is older than 30 days it is old when you are considering trying to use it in a small engine. Fuel in a car will not cause the same issues as quickly for several reasons. If the fuel in the gas can is older than 30 days get rid of it. If after changing the fuel out completely doesn't fix your problem, feel free to contact me and I'll see if I can help you out.
Sep 02, 2012 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I was using my Homelite 330 and it quit running.Now when it starts it runs at a high rpm for 5 seconds or so then winds down and stops running. I've checked fuel. The local repair shop won't even...
dO  tune -up.Here is a link : www.ehow.com/how_6971799_homelite-chainsaw-tuneup-instructions.html also visit www.homelite.com/ for more.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 07, 2011 | Homelite ZR10926 16 Chain Saw
Homelite 240 will not continue running
Check the fuel filter stone in fuel tank. Replace it with new one.
Apr 21, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
My homelite 16 dies constantly
Does it suddenly stop running? (probably electric) Do this while still hot:
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
Or sputter and slowly quit (like out of gas).
Try loosening the fuel cap (rotate the saw if necessary). If it smooths out, runs and accelerates correctly you have a plugged fuel vent. HTH
Lou
A local chainsaw seller/mechanic (Stihl best mechanics in my area) can diagnose for about $10. A repair and tuneup usually $40 - 60. Your starter arm will thank you. If tuned ask what fuel mix they used (should be 50:1) and affix a tag or label to your saw.
Nov 09, 2009 | Homelite Garden
What is the oil-gas mix for a homelite superxl chainsaw? For 1 gal.
16:1 ratio for most 2-stroke oil brands. A service manual recommends tro check the ratio marked on the bottle if using Homelite brand 2-stroke oil. For other oils, 16 parts of gas to 1 part of oil.
For 1 gal of fuel, that is 270cc of oil required to meet the 16:1 ratio.
Please rate this solution on FixYa!
Jul 16, 2009 | Homelite Garden
Homelite Gas, 20 In. Bar, 46 CC, Chain Saw, UT10520 Logo
265 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
