Question about Clickfree(TM) C2N Network Backup Drive 750GB (727NCR)
My Clickfree C2N 1tb isn't working. Won't start up on my mac and on windows 7 it says Clickfree is unavailable
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: Clickfree C2N Won
IF IT DONT WORK MAYBE YOU WILL NEED TO REFORMAT IT.IN THE PROCCESS YOU WILL LOOSE ANY DATA ON IT.
PLUG IN AND FIND IT THEN RIGHT CLICK AND SELECT FORMAT
Posted on Apr 11, 2012
Data on clickfree is from my old XP, when i connect to my newer windows 7 computer, it wants me to format.
Win 7 doesn't recognize the format of XP drive. Put the Click drive on an XP machine on the network and copy files you need then format on Win 7 machine.
Mar 29, 2014 | ClickFree HD535 hard drive 500 GB USB
I need to know what power supply is needed for my C2 HD 1037 external hard drive.
I would start by contacting them on their website.
I don't see anywhere where you can but just the power supply but it wouldn't hurt to ask them about it.
http://www.clickfree.com/page/support-main
Oct 13, 2013 | Click Free 1tb C2 35 Desktop HD1037...
Why isn't my clickfree C6 backing up my files on the second time I needed to backup my files it just keep saying that it is backing up but all colums saying 0
It would appear that your Clickfree C6 is stuck on searching when attempting to backup. If you find that the backup is stuck at this phase, where 0 files are backed up and the status reads "searching for files": you should be able to resolve this issue by applying an update from Clickfree's website.
Pre-requisites:
-Administrator rights
-A computer using Windows XP SP3, Windows Vista, or Windows 7 (32-bit, or 64-bit is okay)
-The C6 must be detected correctly by the computer (where both CF_Storage and Clickfree_System appear in Computer/My Computer)
Try the following to resolve the Stuck on Searching issue:
1. Ensure that your Clickfree device is plugged into USB
2. Close any open applications that may be running
3. Using a web browser, navigate to the following address: http://www.storage-corp.com/customerservice/C6_Updater_search_issue.exe
• The website will prompt for a username, use: cssupport
• The website will prompt for a password, use: cssupport
4. When prompted, save the file to your desktop
5. Double click on the file named "C6_Updater_search_issue.exe"
6. The update will take place automatically. Do not close the update application until completion.
7. When the update is complete, click on the OK button
8. Disconnect your Clickfree from USB
9. Plug the Clickfree back into USB
Attempt another backup to see if the issue persists.
Jul 29, 2012 | Click Free Automatic Backup C6 1 TB USB...
Clickfree C2N Won
Apr 10, 2012 | ClickFree 500GB Clickfree C2 Portable...
Is this external drive compatable with mac?
It should be but may need to be formatted as GPT on the Mac after which it can only be used with Windows Vista, Windows 7 or later as XP and earlier versions of Windows cannot read GPT drives.
Nov 09, 2011 | Western Digital My Book Essential 1TB...
I need to format my HD325 click free for mac
I'm sure the OP no longer needs to format their Clickfree C1 HD325 for use on Mac OS X, but I'll answer this question for anyone else who may need a solution.
Before you begin, there are a few things that you should know about Clickfree C1 and Mac OS X compatibility:
-Most Clickfree devices are compatible with Mac OS X 10.5 or higher, but there are some Clickfree C1 devices that aren't compatible with Mac OS X. If your Clickfree C1 was manufactured prior to 2009: your Clickfree C1 won't be compatible with Mac OS X.
-Take a look at the label located underneath the Clickfree C1: if you see WD08xxXM (WD08 is what's important here, you can ignore the rest of the numbers/letters that follow), your Clickfree won't be Mac OS X compatible.
-Formatting the Clickfree C1 using HFS+ will prevent any Windows operating system from detecting the Clickfree correctly. Try formatting the Clickfree in NTFS from a Windows computer for compatibility with both Mac OS X and Windows.
Pre-requisites:
-A Mac using OS X version 10.5 or better
Try the following steps to format your Clickfree C1 for use on a Mac (note that this will erase the contents on your Clickfree C1):
a. Using your keyboard, press the option key + command key + spacebar at the same time; a finder window will appear
b. In the search field located at the top-right of the window, type: Disk Utility
c. Finder will perform a search, and will display the Disk Utility application icon; double-click on the Disk Utility. The Disk Utility application will start
d. Plug your Clickfree into USB, wait a few moments for the application to recognize the Clickfree
e. Click on Clickfree Backup Media from the left side of the Disk Utility window
f. Select the Erase tab
g. Click on the Volume Format drop-down, select: "Mac OS Extended (Journaled)"
h. In the Name field, type: CF_Storage
i. Click on the "Erase" button.
j. Once the erasing is complete, close the application
k. Unplug your Clickfree from USB
l. Plug your Clickfree back into USB
Sep 03, 2011 | ClickFree HD325 320 GB USB 2.0 Hard Drive
The WD My Passport 1TB won't work on Windows after I formatted it for Mac.
You need to reformat it on windows. Plug it up then find it on your computer and format.
May 09, 2011 | Western Digital 1TB My Passport Essential...
Clickfree starts but after about 10-15 seconds dies. Using windows 7 but had previously backed up with Win XP/Vista.
Dave-
I'm having precisely the same problem. CF works on both of my Vista macines, but won't do anything on my Windows 7 netbook. It loaded the driver, but when I start it up it runs for a few seconds and then NOTHING.
Did you ever find a solution?
Thanks,
Ken
Sep 09, 2010 | Computers & Internet
Use my drive on Mac..
Both OSs have different Security Architectures. NTFS for Windows and HFS+ for MAC. So if you modify these permissions (you could) your MAC OS might not be able to access it properly. But MAC will read NTFS permission (But not write onto the disk).
Jul 11, 2010 | Fantom Drives 300 GB Hard Drive
Clickfree(TM) C2N Network Backup Drive 750GB (727NCR) Logo
750 people viewed this question
Top ClickFree Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Joseph Wright
Are you a ClickFree Computer and Internet Expert? Answer questions, earn points and help others
