Question about NAD C320 2-Channel Amplifier
Amp : sansui au11000 blown transistors on driver board
I recently replaced my amps output transistors. i couldnt souce the originals so i used mj 15024 & mj 15025 .i checked for any shorts with 40 watt bulb in series with power input . checked dc offset ok!.i then took it to repair shop to have bias set (i dont own an occiloscope) the repair guy used a steel screw driver & subsequently burnt out 8 transistors on the side of the driver board he was adjusting.(all around the trimpot) here is my question! he sez that the amp shorted out because of a pre-existing condition i know its a stupid question to ask but what do you think happened? regards ross
  • redrooster Jan 16, 2009
    hey thats uncanny that is exactly what i ended up finding what was wrong! there was another transistor on board f-2568 tr06 that was a bit wonky that i replaced, it made it go into protection.
  • aircraften Mar 18, 2009
    denon pma630 neg.output tr.brakedown.i tried to repl.o/p tr.driver tr.but still valid
Sometimes just replacing the outputs that have shorted are not enough to complete the repair of a main amp...this is because sometimes there is an intermittant or full failure in the bias circuit. Typically the Bias POT is the culpret.....when these pots get dirty or fail, the bias current ramps up way too high and then the Output transistors blow.......always replace the POT as part of the repair.....also check the bias varistor (Diode Stack) as these can open up after the first failure. Always pay attention to the bias circuit as this is critical to completing the repair properly....bias current adjustments can be made by measuring the voltage accross the Emitter Resitors connected to the Power Transistors...should read about 10 millivolts. The MJ15024 and MJ15025 Outputs are perfect replacements for Your Power Amp...I use them as well. Your tech probably just touched the bias pot, and that was all it took to make it fail (Open up)..If he was savvy, he would have replaced that POT before Touching it.
Hope this info helps....
Eric
Posted on Jan 16, 2009
  • 682 Answers
May i ask you did you put silicone grease in your transistor and apply a good mica insulator in all of your transistor---------look for any burnt resistor or explosive capacitor -----check for scew tie your supply voltage to earth by wrong.
Posted on Aug 03, 2008
Determine if an analog receiver has blown a channel
When you need to replace the output transistors, do them both at the same time with a matched pair. That way you won't unbalance the power supply and will be assured of the same power out is available on both channels.
Feb 18, 2016 | Sansui Audio Players & Recorders
Transistors burn out on one side of driver board f-2580 at switch on of signal sansui au11000
If it keeps burning out check the wiring section of the board that is powering the transistor.
A contact or a bad diode for example can cause the transistor to blow recurrently.
Aug 31, 2008 | Sansui Audio Players & Recorders
All the lights are not working found 2 blown fuses / replaced still not working the power lite flashes red then turns to green
When a fuse blow suspect an overload. In an amp this old it will certainly be one (or more) of the main output transistors that has shorted.
Sep 25, 2013 | Sansui 1976 9090 Receiver Amp Vintage
I own a Aragon 4004 mkII. Recently the the banana plugs on the right speaker output touched bridging a contact. The amp had been turned on and left on for up to 10min with this short occuring. Now the...
Tough one. I repair these for a living. A number of possibilities exist. Likely output transistors are blown on the bad channel. Fuses are likely blown. If the fuses are BLACK inside, don't just put new fuses in, more damage WILL occur. This is a bit more than 'good with a soldering iron' will fix. You need to know how to test an output transistor. You need to look up the transistor type so you know what it is. A service manual will be a big help (I could not find one online.) If more than two outputs are gone on the one side, all should be changed, they are supposed to be MATCHED. Remove and replace all damaged outputs, or replace them all if two are blown. Find the driver transistors and check them for short circuits. After repair, start the amp on a dummy load of a 250watt light bulb to prevent destroying the amp if there is a problem. If you are unsure of any part of this, find an electronics technician to help.
Feb 20, 2012 | Audio Players & Recorders
Pioneer GM-5200T problem
i dont think transistors are bad . you should check the amp controlls they may need adjusting
Jan 20, 2009 | Pioneer GM-5200T Car Audio Amplifier
Amp turns on just fine but no sound comes out
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
Seems as you have blown an output. Seek repairs.
Dec 29, 2008 | Power Acoustik A3000DB Car Audio Amplifier
SANSUI AMP AU-D11-II
It is possible, but nlikely that the protection circuit is bad. More common are shorted output transistors or defective driver stage transistors. This should not be a difficult repair for anyone familiar with audio amps. Unsolder/remove Q22 and Q23 and measure the voltages at each of the 3 pads per transistor and post them here.
Thanks,
Dan
Nov 04, 2008 | Audio Players & Recorders
Sansui amp au11000
Without seeing the amp nor having the service manual in front of me, it sounds like you have a severe offset problem. There is either an open resistor or transistor in the early stages. With the output transistors removed from the unit, look around at voltage levels to determine where the fault is. I will try to locate the service manual. Can you post the parts that you have replaced?
Thanks,
Dan
Sep 04, 2008 | Audio Players & Recorders
Channel short
Hi there, sounds like you may have a short to ground on the output transistors. Does it have transistors or an IC output. It is most likely that you have not replaced a mica washer or insulator. Check to ground with a meter from the case of the output devices.
Aug 24, 2007 | NAD S300 Amplifier
NAD C320 2-Channel Amplifier Logo
1,998 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
