Question about Garden
How can we get the mower C500H out of gear to push it? Battery is flat so need to push it near car to jump start with leads from car to mower.
    Master:
  • 403 Answers
Should be a handle of sorts at rear bottom of unit to disengage the tranny,, pull out and secure with a small nail.
Posted on Mar 21, 2011
2006 Suzuki Boulevard c50. Main 30 amp fuse blows as soon as the start button is hit.
sounds like the starter is shorted out or the bike was tried to start when battery was near dead and the starter is engagaed if starter is engagaed put it in gear and bump(push the bike ) it a few times forward and back this should disengage the starter if it still blows fuses the you may have a shorted windings in the starter and it will need to be rebuilt
Dec 01, 2014 | 2006 Suzuki Boulevard C50
Tip
Jump-start Jaguar X-type? it's more complicated than you think.
Jump Start of Vehicle Battery
IF THE BATTERY YOU ARE USING TO JUMP-START THE VEHICLE HAS RECENTLY BEEN CHARGED IT MAY STILL BE GASSING, COVER THE VENT PLUGS OR COVERS WITH A DAMP CLOTH TO REDUCE THE RISK OF EXPLOSION SHOULD ARCING OCCUR WHEN CONNECTING THE JUMP LEADS.
Turn off all electrical ancillary circuits such as radio, lights, indicators etc. If the reason for a flat battery is unknown the condition may be as a result of an electrical short circuit, so care must be taken during the Jump-start process and subsequent to connection to ascertain if this is the case. A short circuit or un-isolated ancillary load can cause arcing when the jump leads are connected, a small 'crackle' is normal but any spark or flash is an indication of a problem that should be rectified before attempting to Jump-Start the vehicle.
Jaguar do not recommended that the vehicle is jump started, and If at all possible it is preferable to replace the flat battery with a suitable fully charged unit rather than jump-start the car. However if it is done it should be carried out by suitably qualified personel. Garage services and services like AA and RAC homestart should be used whenever possible.
Obviously there are occasions when carrying out this proceedure yourself is the only practical way proceed.
If there is no option but to jump-start the discharged battery should be removed and recharged immediately after jump starting to avoid permanent damage.
High quality, heavy duty Jump leads must be used as the current consumption during starting is very high, and a voltage loss will be
exhibited though the jump leads, increasing current requirement.
Make sure that the Jump Start battery is of the same voltage as the vehicle, and suitable to provide the required starting current.
MAKE SURE THAT THE ENDS OF THE JUMP LEADS DO NOT TOUCH EACH OTHER OR GROUND AGAINST THE VEHICLE BODY AT ANY TIME WHILE THE LEADS ARE ATTACHED TO THE BATTERY. ARCING AND VERY RAPID DISCHARGE CAN CAUSE THE BATTERY TO EXPLODE.
Connect the jump leads in the following sequence.
Connect Positive Jump Lead to Jump Start battery positive terminal.
Connect Positive Jump Lead to Vehicle battery positive terminal.
Connect Negative Jump Lead to Jump Start battery negative terminal.
Connect Negative Jump Lead to a suitable vehicle ground point at least, 300 mm (12 in) from the battery terminal e.g. engine lifting bracket, do not do not connect directly to the vehicle battery terminal.
Start the vehicle and rev to 2000 rpm, then allow tickover for 5-10 minutes.
Do not attempt continued repeated starting of the vehicle, this will cause heat build up at the terminals and though the jump leads degrading the leads performance and adding to voltage loss.
Allow 3-4 minutes recovery time for the leads and Jump Start battery between attempts to start.
Before disconnecting the jump leads, switch on the heated rear screen, to reduce the alternator voltage peak when the leads are removed, as this can damage electronic equipment.
Disconnect the jump leads in the reverse order to the connecting sequence taking great care not to short the ends of the leads.
Do not rely on the alternator to restore a discharged battery.
Ensure that the battery is recharged or replaced with a fully recharged unit
as soon as possible.
Following Jump-starting of a compleately discharged battery, you may need to carry out a Green ECM drive Cycle, this will allow the powertrain control module to 're-learn' idle values, and most likely need to re-enter your radio code, details of these can be found at. http://www.bluejag.co.uk
on May 31, 2010 | Jaguar X-Type Cars & Trucks
Can you jump start a toro zero turm mower with a car battery and jumper cables?
Better to not jump them can burn the leads up. Pull it out and slow charge it
Jul 17, 2014 | Toro NEW 42 TIMECUTTER 21.5 HP KAWASAKI...
1997 jimmy won't start just clicking noise
It could be:1. the battery is flat, in which case recharge the battery OR jump start the vehicle OR, PROVIDED YOUR CAR DOES NOT HAVE AUTOMATIC GEARS, get somebody to push the car while the driver is in the driving seat and the car is in second gear and the ignition is turned on ---- ; OR2. there is a loose connection from the battery to the starter motor OR a loose connection between the battery and the earth (where the lead from the battery is connected to the body of the car) OR there is dirt at one of these connections which is inhibiting the current. Solution in these cases is to check the connections, clean them and reconnect.Best of luck!
Dec 04, 2011 | 1997 GMC Jimmy
How to jump start my bmwk75s
put it in 2nd holding your clutch in pick a fast walking pace up ease off the cluth hope fuly this wil start bump start your bike
Aug 31, 2011 | 1990 BMW K 75 S
When i try to start it jsut makes a ticking noise near the front of the engine and an amber light flickers on the dash the car also locks funny?
Your battery is flat!! get some one to jump you or give you a push. You need go to a garage to see if your alternator is charging. Your battery may be to blame. Check the alternator 1st as it will cost nothing or next to nothing as a battery is quite expensive. Hope this helps. If it still clicks with a fresh charge or jump leads then give the starter motor a tap wit a hammer while trying to start it.
Aug 13, 2010 | Peugeot 405 Cars & Trucks
My john deere LA120 will only start with a jump, battery fully charged changed battery.
Your starter may be nearing the end of its service life.
If it is worn down it may require more amperage than your battery can deliver to crank. That is why the extra battery helps. More amps!
You can start your tractor and check the wires to see if they are hot to the touch. That would be proof the starting system is drawing more amps. If it isnt hot then you might have connection problems or corrodes leads.
You can try replacing your battery wires to lower resistance and improve power transfer to the starter. Leads are cheap and available at most car parts stores.
Jul 07, 2010 | John Deere Garden
Is it good to jump start a car with a new vehicile
Yes it is ok to jump start a car with new car
Feb 22, 2010 | 2008 Jeep Wrangler
How do i jump my battery in a 1991 bmw 740il
red is postivie,black is negative, make sure where you are jumping it from is the same, make sure the other vehicle is running
Dec 17, 2009 | 2006 BMW 750Li
Our cars battery was run flat. We jumped started
First check you have the main ingredients,
Power, Spark, Fuel, as if you have these it should start, Second, make sure you have replaced the dis cap on the right way and the leads, then take number one plug out and push it back into the lead and then rest it on the side of the engine, but dont hold it there, just rest it there, and then turn the key and check you have a nice blue spark, if not checkk the lead is secure between the distributor and the coil, i will try to help you further if i can, just email me on butcher960@btinternet.com Colin.
Sep 29, 2009 | 1995 Honda Odyssey
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
