Question about Ld Asus P5LD2-VM/SI Intel ICH7R Chipset 1066 MHz FSB DDR2 400 / 533 / 667 Socket 775 Micro ATX Motherbo... (MB77ASP5VMSI) Motherboard
For P5LD2-VM/S I want to find bios P5LD2VSI.ROM
    New Friend:
Ftp://ftp.wortmann.de/TERRA_Computersysteme/PCs/Mainboards/ASUS/P5LD2-VM_S/bios0405_rev1.zip
ftp://ftp.wortmann.de/TERRA_Computersysteme/PCs/Mainboards/ASUS/P5LD2-VM_S/bios0705_rev2_rev3_rev4.zip
Posted on Jan 11, 2014
5 Suggested Answers
SOURCE: p5ld2-vm problem
go to "bios settings" by pressing "delete" key or F2 at the system start up time .. after going in to bios then search for the options load optimal defaults ....then save it and exit ..
after that restart ...
now have a check if your problem persists then the processor which you have choosed might not support the motherboard specification the frequency of the processor is higher than the specified rate .. check here for the details of the processor which supports your motherboard
Intel Core 2 Duo HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.L2 1102 2.00G HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.L2 1202 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0492M BX80557E4500 E4500 2.2GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0562M BX80557E4600 E4600 2.4GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0642M BX80557E4700 E4700 2.6GHz,800FSB,L2:2MB,revG0 1401 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0364M BX80557E6320 E6320 1.86GHz,1066FSB,B2:4MB,rev.B2 1202 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0464M BX80557E6420 E6420 2.13GHz,1066FSB,L2:4MB,rev.B2 1202 2.00G HH80557PH0564M BX80557E6600 E6600 2.40GHz,1066FSB,L2:4MB,rev.B2 0901 2.00G HH80557PH0674M BX80557E6700 E6700 2.66GHz,1066FSB,L2:4MB,rev.B2
check the website given below for details :
http://www.cpu-upgrade.com/mb-ASUS/P5LD2-VM.html
thank you
rate my solution
Posted on Sep 10, 2008
wayneard
  • 1901 Answers
SOURCE: graphic card slot for asus p5ld2-vm/s
PCI Express X 16.
Here is a link to the user guide for additional info:
P5LD2-VM Manual
See page 1-20
Posted on Nov 24, 2008
leecom72
  • 4806 Answers
SOURCE: INSTALLING GRAPHIC CARD 9500GT ON ASUS P5LD2-VM R1
First of all is this a new graphics card? If it is take the card out of the PCI Express slot, get a clean, dry, soft paintbrush and clean the PCI Express slot, then blow on the slot to remove any residual dust.
Make sure the brass contacts on the card are clean and then reinsert the card, make sure it clips into place properly and you secure the card with the screw at the back of the computer, then try booting the machine.
If you bought the card second hand then there is a possibility that the card is faulty.
Luckily for you i now a way to bring a dead graphics card back to life but you do it at your own risk.
Let me know how you get on and good luck.
Posted on Aug 20, 2009
  • 979 Answers
SOURCE: IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Posted on Nov 10, 2009
Unable to use S-ATA on Asus P5LD2-VM
in the BIOS set the SATA controller to IDE this should fix the problem. And try with AHCI selected.
Apr 16, 2013 | ASUS P5LD2-VM Motherboard
P5ld2-vm always starts with 2002 date and usb 2 disconnected when previuslly unpluged from ac
The BIOS battery - the big round one - has aged and must be replaced. It's a CR2032. get it from a battery shop.
Jul 13, 2011 | ASUS P5LD2-VM Motherboard
Does p5ld2-vm support window 7, The install CD is unable to install on my brand new Seagate Barracuda ST3500641.
As long as you are using a decent video card there should be no problems in installing 7.
Check the BIOS settings for the hd's controller - something is wrong there.
May 25, 2010 | ASUS P5LD2-VM Motherboard
Hello - my ASUS P5LD2-VM restarting wen i working - were the problem?
this could be the power pact or the prossessor over heating,try and clean as mush dust out. go to bios settig and check do a health check. (switch on and press del to enter bios settings warning do not ajust anything).just see if prossessor is getting above the normal heat temprature of your system.
Dec 12, 2009 | ASUS P5LD2-VM Motherboard
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
Help find driver
hi! download you motherboard driver from here!
www.nodevice.com/driver/P5LD2-VM/get34084.html - 15k
drivers.softpedia.com/get/BIOS/Asus/Asus-P5LD2.shtml - 55k -
www.driverfiles.net/Bios/ASUS/P5LD2/download/page,sh,30052,172,6,.html - 60k -
Jul 18, 2008 | ASUS P5LD2 Motherboard
Slow data transfer rate
Do you have this Bios version? P5LD2-VM BIOS version 1303
Support new CPU's. Please refer to Asus website at: http://support.asus.com/cpusupport/cpusupport.aspx
Your board came out around June-2005 so improvements are here. I'm not saying its all about the CPU & FSB but it may help.
Jan 27, 2008 | ASUS P5LD2-VM Motherboard
Pc restart problem
Yes, your mobo Asus P5LD2-VM support CPUs with Conroe-core ("Core 2 Duo"). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5LD2-VM But for new CPUs strongly recommended use last BIOS version - 1401 from 2007/08/14. http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/P5LD2-VM-1401.rar
Oct 03, 2007 | ASUS P5LD2-VM Motherboard
Computers & Internet Logo
1,078 people viewed this question
Top Ld Computers & Internet Experts
David Payne
David Payne
Are you a Ld Computer and Internet Expert? Answer questions, earn points and help others
