Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My new Bravos dryer was working well and it suddenly stopped and acted as if it was getting no power. None of the lights come on. I checked the fuses and all are OK.
I put some rugs in my driver and after I notice the vents burnt and a few days later the dryer is no longer working
Posted on Apr 11, 2011
I have a Bravos XL dryer < than 1 year old. Suddenly it stopped running & the LEDs all went out. There is power at the 250 v outlet but no panel lights or drum light. I am not sure where to start.
Hi Larry
A small cheap MultiMeter would assist here
Allowing you to trouble shoot to where power is lost.
Probe & aligator clip to Neutral or ground
& probe for 240v ac
Caution is essential near we floors
Would also be nice to have a RCD in your meter box for shock protection (ground to active phase)
....unless you've got a heart like horse!
or a portable one plugged in at the wall.
It will only save you from ground to active phase shock
not phase to neutral.
Better safe than sorry
How to Use Multimeter
THE BEST Multimeter tutorial HD
http://www.jaycar.com.au/Test-%26-Measurement/Multimeters
Mar 13, 2016 | Maytag Bravos XL High-Efficiency Electric...
What can i check to see why my maytag bravos dryer isnt drying?
[Always disconnect the dryer from any power source before checking.] Dryer heating circuits have several parts in the series circuit that must all work (kind of like a string of Christmas tree lights) so you'll want to check each one in that series. These likely include the motor switch, timer switch, temperature selector switch, temperature controls/thermostats (usually three of these) and all connecting wiring plus the heating element. Of course, one should always make certain the dryer is receiving 220 volts power supply from the wall outlet before starting to troubleshoot the dryer. Most dryers operate with 110 volts, only using the 220 volts for the heater circuit. A dryer getting only 110 volts could run, but not heat. This doesn't happen often, but is always worth checking.
Aug 20, 2014 | Maytag Dryers
Maytag model# MED5700TQ0 Suddenly will not start. Light inside works, so electric power is on. Could the start button have gone ba
Yes it could have gone bad. Also you might be missing one of the 120 volt legs that the dryer needs to run. Try turning the Dryer circuit breaker all the way off then back on and see if it will work. It also could be that the belt that goes around the drum might have broken or come off the motor. If you can, open the top of the dryer and look for the belt to see if it is OK. Best of luck.
May 08, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag bravos electric dryer powers on but will not run no codes on it, just wont run
Check that door is fully closed. Or turn on dryer and manually press the door switch to see if that works. If not than it is that switch. A thermoswitch will also do that
Mar 30, 2014 | Dryers
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Bravos 400 series with steam Dryer
You might have a shot motor, or a fault in the wiring inside the dryer. Have a tech test both.
May 08, 2012 | Maytag Dryers
JUST MOVED TO A NEW LOCATION AND THE BRAVOS DRYER WONT WORK.POWER BUTTON WILL NOT POWER DOWN AND PAUSE START BUTTON WILL DO NOTHING.
Double check the power source, you may need to reset the breaker. It would be rare that the dryer would fault internally during transit because a gas ignitor you be the loss and you do not have one. Check the power supply and confirm you have at least 220 volt to wall and dryer. Get back to me if you need more help.
Thanks
Nov 20, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Bravos Dryer blinking start button
Manual says it could be a number of things, and you should have a copy of the manual since you've only had the dryer 3-4 months. If not, go to the Maytag website and download.
Some things to check -
1) Press Start/Cancel if dryer was stopped in a middle of the operating cycle.
2) Check that one of the two breakers has not tripped or fuses blown (if an electric dryer) in your breaker panel.
Please reply the flashing code number so that I may can help you further.
Jan 19, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
186 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
