Question about Admiral Refrigerators
I have a side by side refrigerator. The handle on the refrigirator door is somewhat loose. How can I tighten it? Thanks
  • 2,510 Answers
You have to remove the inside panel of the door. It is not a big job, just locate the screws and remove them, and remove the inside panel. Replacing them is a bit more tricky but not impossible to do,
Posted on Mar 21, 2011
Bosch refrigerator door handle is loose
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
Aug 03, 2014 | Bosch Evolution 800 B20CS80SNS Stainless...
Loose door handle thermador refrigerator
I'd appreciate thoughts on how to tighten THERMADOR not another brand refrigerator door handles. Model: KBUDT4860 A02 which is a stainless steel side by side 2 door freezer / refrigerator. Thanks.
tried the other suggestions above and damaged the surface.
Jan 16, 2013 | Thermador Refrigerators
The door handles are loose. I want to tighten them
Remove the door gasket - and you will find the handle screws.
CLICK HERE to see the diagram.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Loose door handle
If a tight place is worn out, then try warmer temperature and go to the tools store to place the door with your new tools.
Aug 08, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Freezer door handle loose
Use a 3/32 Allen wrench to tighten the screw on the side of the door handle
Jul 16, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Loose handle
Hi Thanks For The Question There Should Be An End Cap Which Can BE Removed And Tighten Screw .THanks The Appliance Doc
Jun 03, 2008 | Maytag MSD2656G Side by Side Refrigerator
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
175 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
