Question about Intel Motherboard
Re computer prob
Thank you for your quick reply :-) There are no lights at all when i try to power up the PC but i do get flashing lights on my keyboard, so i assume the power supply is working ok?!
  • Jodey Aug 03, 2008
    Thank you soo much :-)
    Here is comp info for you (to the best of my knowledge)!
    'HIPER' Power supply (220-240V) : HPU-4S425-PK 425 watts (NEW)
    'GIGABYTE' Motherboard : GA-K8NS Pro (AMD Athlon 64 processor - socket 754)
    'SEAGATE' Hard Drive : BARRACUDA 7200.10 250 Gbytes (only put into the machine 6 monts ago)
    'CRUCIAL TECHNOLOGY' RAM : 512MB, DDR, 400, CL3
    'NVIDIA' Graphics - FX5500 - TD256
    Sorry, i couldn't see much on the Graphics card, so i hope the info is ok!?
    I have disconnected all of the power supply leads again and tried just connecting the main power cable on the motherboard and also the lead for the led's on the front of the machine. For a couple of seconds, the fan on the CPU started spinning, but then just as quickly stopped again! I have tried again a few times and nothing is happening again, only the flashing lights on the keyboard!! Don't know if this will help at all? I have taken off some of the leads to the Motherboard (extra USB ports), so the only things connected to the motherboard now are: the Hard Drive(connected by the Red 'SATA' cable), 2 DVD's and 1 Floppy Drive and the Power switch and LED's for the front of the tower. PCI Slots: Modem (HP156A3) and the Graphics card.
    I hope this information helps and Thank You again for helping me :-)
  • 659 Answers
Yes but there is a error then somewhere, because the keyboard is displaying it as being a error I would assume.
now is it possible for you to take a picture inside you computer for me? just would like a nice picture to help you out a bit and if possible what you have in it,
power supply name ect
motherboard name ect
hard drive name ect
Ram installed
video card name and model
and maybe we can get the thing going quicker by cutting out a few steps.
I will help ya till it works.
Posted on Aug 03, 2008
  • Wesley Gardner
    Wesley Gardner Aug 03, 2008
    ok lets try this.
    1. Make sure all your wire connections inside you computer are tight and non of the wires are frayed or bent really bad.
    2. remove the video card, make sure that there is the 4 and 8x notches on the card if its a 2x card then its not supported by this motherboard.
    3. Refer to page 96 of you manual to make sure that your Fpanel is properly installed correctly. (you can remove all the wires from this for testing. and only have the pwr cable plugged into the board to make sure you have it in the right pins.) if you need the manual please go the following link. Click Here
    4. There is a ram LED on the right hand side of the motherboard this should be on while the computer is on if there is no power on that the the motherboard needs to be getting power. And currently is not receiveing power.
    5. There is also a small LED beside the video card as well when the video card is installed go 1/3 of the width of the card and look on the motherboard and it should be right there.
    • Turn off the power and unplug the AC power cable, then remove allof the add-on cards and cables from motherboard.
    • Please make sure all jumper settings (such as CPU system bus
      speed, frequency ratio, voltage and etc) are set properly.
    • Check if the CPU cooling fan attached to CPU properly. ls
      CPU cooling fan power connected to CPU_FAN
      properly?
    • Check if the memory install properly into the DIMM slot.
    • Insert the VGA card. Then plug in ATX power cable and
      turn on the system.
    1. Is memory LED on and CPU fan running? if you said no then
      The problem could be caused by power s u p p l y , C P U ,
      memory or CPU/memory socket itself.
    2. Check if there is display. if nothing there then Perhaps your VGA card / VGA slot or monitor is defective.
    3. Turn off the system and re-connect the IDE cable. Check
      if the system can reboot successfully.
    I hopeing to see inside your computer cause maybe just out of a shot in the dark I might be able to notice something out of the norm.
    Lets start with these steps and we will from there.
    let me know how the progress goes, nice power supply but ya if you can take the video card and shoot me the model ect on it then I can further find out more for you.
Single blue light flash then nothing
your computer power supply or motherboard is dead. I'd bring it in to a computer store for repairs/parts replacement. (if it's not under warranty, of course).
Jan 22, 2014 | Dell Vostro 420 Desktop Computer
Orange light flashing, no chargine
A replacement battery must be the EXACT same power spec as the original in DC volts and Milliamps, or you could damage the Mobo components. Some aftermarket batteries do not work well. The connections may be different.
Jan 31, 2013 | Dell Latitude E5500 Laptop
The computer won't boot Windows 7. It starts up fine, with the fans running with the LED lights on. Then I get an error message: "CD-ROM Boot Priority ..No Medium" I have checked the bios of...
It sounds like either Windows 7 did not install properly or you have a bad hard drive. I did some research on similar problems and most people have also tried to change the boot priority with no luck. If your are tech savvy I would try to run hard drive diagnostics and possibly reinstall Windows 7. If you are not very technical I would suggest taking it to a competent pc repair technician.
Apr 08, 2011 | Systemax SYX Crossfire X58 Gamer Intel...
When I turn on my pc i get a yellow flashing light
Hello Leaha_6, Unfortunately that flashing yellow light is the Dell indicator that there is an internal power problem, usually with the power supply. Before replacing anything you may want to unplug the computer, open the case, and re-seat all of the power cables inside. That might help. The next step would be to replace the power supply. Post a reply if you have any further questions. Thanks!! Edward
Aug 23, 2010 | Dell Dimension 4700 PC Desktop
Drivers side unlock button does not work. Also the inside lights stay on forever!!! I have to take the fuse out when I park in my garage so the battery does not run low. My sister's expedition has same...
So it's electric locks and the driver's door is the only one that will not unlock?And for the inside lights,is there a switch to brighten,lower and leave always on or always off,is it in the always on position?I realize you probably know about the adjustable inside switch but I want to make sure I have all the facts straight to figure it out.Thank you and please reply.I check messages before noon EST the next day so I can reply as quick as possible and try to resolve matters.Thanks
Jul 05, 2010 | 1998 Ford Expedition
Hi Charlie, Thank you for your quick reply, The problem is I do not know how to check to see if it is a problem with the battery or if it is with the power cord. Although I am going off of the assumption...
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Jul 18, 2009 | Acer Aspire 3690-2196 Notebook
Power light on front of computer is flashing - quick blinks
Most desktops require you to hold the off or power button down for at least 5 seconds, or more, before it will actually turn of the power. If you don't you won't get the desktop to turn off properly and when you try to turn it on again, you will get a message to the effect that the PC was not properly turned off last time, and it will give you the option to turn it on in Safe Mode, Safe with DOS prompt, or Safe with networking or ... finally, normal mode. If all you did was not turn the power off holding the button for a minimum of 5 seconds, then turning it on normaly is okay to do.
Jun 21, 2009 | Computers & Internet
Orange Light
you need to replace the motherboard lithium battery. Looks like a watch battery.
Sep 07, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Any Help?
repair of the board may run up to $150...instead, search ebay for another unit (AS-IS) and use it for part swapping
May 28, 2007 | Toshiba Satellite A20 Notebook
Intel Motherboard Logo
208 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
