Question about AEG B8871-4 Electric Single Oven
I've removed the door to clean it and whilst putting it back one of the hinges sprang back into place (as it should be when the door is attached). Can you explain how to open this hinge please? Thanks.
  • AEG Master
  • 3,361 Answers
Grasp the hinge with a pair of pliers and pull out and downward until it catches in the open position slot.
It will be hard to pull.
Posted on Mar 21, 2011
  • tiza2 Mar 21, 2011
    Thanks I'll try it!
I need to remove my jenn-air door to clean between the glass
Posted on Jun 05, 2011
OvenDoor came partly off hinges. One side only.
Most oven doors are made to be removed and on most, the hinges have locking clips which hold the hinge so you can remove the door. Have a close look at the hinge which is still in the door and see if the hinge that came out is the same. You may have to get someone to hold the hinge in place while you refit the door.
Jan 28, 2018 | Ovens
Putting door back on but hinge wont release to put back on
Hi Susan, this is AP! Thank you for your post.
I understand you are having trouble putting the door back on your Frigidaire wall oven. Without knowing exactly how you removed the door I cannot say with certainty how to reattach the door. However, when removing the door did you pull up the lock located on both hinge supports and engage it in the hinge lever hooks? You might have had to apply a little downward pressure on the door to pull the locks fully over the hinge lever hooks. Then grab the door by the sides and pull the bottom of the door up and toward you to disengage the hinge supports. If so, then to reattached the door grab the door by the sides; place the hinge supports in the hinge slots. Open the door to the fully opened position. Disengage the lock from the hinge lever hooks on both sides. Make sure the hinge supports are fully engaged before unlocking the hinge levers. Then close the oven door. There are instructions with images to remove and replace the oven door in the owner's manual. I hope this information proves helpful for you.
Mar 14, 2014 | Frigidaire FEB30S6D Electric Single Oven
Ignis AKL828 door hinges locked in shut position... door off oven!
Take a pair of pliers and pull the hinge out of the socket. This will take care of it. After doing this, then simply set te door back in place and shut.
Mar 06, 2013 | Ovens
Kenmore oven door fails to lock
1. Remove the pan drawer
2. With someone holding glass up, remove the four screws at the bottom of the door that hold the glass front to the door frame. Gently lower the panel about two inches until the side guides are below the door trim cap. Place out of the way so it doesn't fall over etc.
3. Keeping the door closed, use a spring puller to remove each spring from the hinge. (I made one out of a hanger and a screwdriver. Double thickness at the hook, wrapped and secured around the screwdriver to make a handle) If you do things this way be VERY careful. Be sure it is really strong and is not going to slip. The springs are really under tension and will shrink down about an inch from where they are hooked. (Be sure to support the door so it does not fall open when the springs are removed. It will just make things worse.)
4. After the springs are off gently open the door all of the way.
5. Pull down the hinge locks from the oven body and lift the base of the door up. This will lift the door hinges off of the mounts in the oven frame and allow you to pull the door away from the body.
6. Place the door on your box or workbench etc
7. Remove the two screws on each side of the door that hold the hinges in place. Remove the hinges.
Reinstallation is in reverse.
Hinge repair.
By placing the lower part of the hinge (by the axle) against a ruler I was able to see that the upper section was bent out on each hinge. To correct it I placed the hinge over a pair of 4x4 blocks so that it curved up in the center, and hit it a few times with a hammer. The metal was very responsive and quickly bent back into shape. Be careful here as you don't want to bend them too far. I actually went a little past true, wanting to get a little more push at the top of the door. I placed the hinges directly on the oven to see the difference and they looked good (Be sure to put a piece of cardboard or rag between them and the top to keep them from scratching the surface.
Put the hinges back in the door, screw it together and hang it back on the stove, replace the springs and the glass, and check your fit. Good luck.
Feb 01, 2013 | Kenmore Ovens
How do you put door back onto Electrolux wall oven......Been trying for hours, no success!
Hello paulascor549 - I completely understand that you took the oven door apart to clean it, therefore you must have took the following steps to do so. According from my research you would have to reassemble in reverse order. If you have already tried to do so and it proves to be ineffective, contact a professional to move forward accurately.
Door Removal and Cleaning of Interior Glass
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide? With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Nov 24, 2012 | Electrolux 30" Built-In Single Electric...
I need to replace the hinge receptacles on a Jenn-air wall oven (WW30430PC). How do I access those parts?
The only way to replace the hinge receptacles is to pull the oven out of the opening. If you need parts you can get them on the link below. Also if you call the link below they will walk you through on how to replace.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45883&diagram_id=28594572#d28594572
May 16, 2011 | Jenn-Air Ovens
I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
Ovens come in many varieties including freestanding units and stacked models that are inserted into a wall. Kitchen oven units that get a lot of use or are getting old may have problems develop, such as a loose or squeaky door which may require replacing the hinges. You can replace the hinges on the door to your oven by first removing the door from the rest of the oven.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions Things You'll Need:
  • Screwdriver
  1. Step 1 Open the oven door and examine the hinges to see how the they are secured to the door. Some oven doors slide into the hinge assembly or have a locking mechanism that secures the door to a latch on the main unit.
  2. Step 2 Remove the door from the oven by disengaging the locking mechanism and then pull the oven door out. You may need to release a catch on the door or remove a pin from a hole in the hinge.
  3. Step 3 Place the door on a flat surface such as a table or the floor.
  4. Step 4 Remove the screws that hold the sections of the door together to access the hinges.
  5. Step 5 Remove the hinges from the door. The hinges may be attached to the door with screws or they may be held in place when the door sections are tightened or secured.
  6. Step 6 Insert the new hinges into the door and secure them with the screwdriver or place the section of door back on. Tighten all of the screws securing the sections together.
  7. Step 7 Place the oven door back into place by sliding it on the same way that it came off.
Regards
Iversh
Jul 24, 2010 | Ovens
Took the door off my oven to clean it can't get it back on
I put something behind the hinges, usually screwdriver handles, to hold them open long enough to slide the door onto the hinges. If you have the style that has the hinge on the door, you usually have to stick a nail into a hole in the hinge (in the open position), that is designed to hold it in the open position. Install the door, and remove the nail. Another design has a lever that has to be rotated into the locked position on the hinge. You have to be pretty strong for some of these hinges to pull the hinge out enough to lock the lever in place. If this is your style make sure you lock the lever before you remove the door next time. Good Luck, Appliance Specialists
Jan 25, 2010 | GE Ovens
I removed the oven door and took out the hinge to clean. When I tried to put the hinge and oven door back the hinge will not close it is stuck. How do I unlock or hook the hinge so my oven door closesI
You will have to pull the oven dorr up and out again, it might be a little hard to pull but the door didn't went in straight and it's preventing the hinge from closing. go to repairclinic.com for an ilustration on how the door and hinges fit in place.
Jan 14, 2010 | Ovens
Whirlpool oven door
Push the hinges out till they click once. At this point, get your nails or screws ready. Use a screw driver and wedge the hinges further apart. When you see the hole in the hinge appear, put the nail in it to hold it open. With both done, drop door in place; open door slightly, and remove nails.
Oct 17, 2007 | Ovens
AEG B8871-4 Electric Single Oven Logo
531 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
