Having trouble with code on LG wm22 77hw washing machine
  • 1,998 Answers
What is the code that your unit is giving you? also if you can describe what the unit is doing as to not performing how it should it would also be a great help Thank you I await your reply Rick
Posted on Mar 21, 2011
Error Code PE
go to the manufactures website and download the user manual and check in trouble shooting guide eric
Jan 19, 2018 | LG Washing Machines
LG front loading washing machine Direct Drive 7 3.5KG Trouble shooting Error OE
go to lg.com, enter your model number and manual will show error codes and fixed for some including OE
Aug 29, 2015 | LG Washing Machines
How do I trouble shoot the error code on my LG Tromm WM0642HW, it is an upside down F and E.
could the upside down F be a lower case t. If so the error code is tE and you have a heating problem.
Jan 25, 2015 | LG Washing Machines
Kenmore front load model 40272900 e codes (control Error)
If the washer's full model number is 79640272900, then the unit was made by LG. Looking up LG front-load washing machine error codes will give the available codes. Here is one listing: http://www.appliancefactoryparts.com/blog/2010/02/washing-machine-fault-codes/#LG . Some of these codes are also available in the manual in the Trouble-shooting section. Manage My Life has the manual as a PDF here: http://www.managemylife.com/mmh/owner_manuals/17952/KENMORE-Residential-Washers-L0910072?brand_name_search=79640272900 .
I hope this helps.
Sep 21, 2013 | Computers & Internet
While using the machine and during spin operation, the machine dispays the error message OE : drainage trouble, how can i fix this issue
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | LG Washing Machines
On my LG W/M showed .... trouble code OE appeared I fixed the drain pipe. But could not located the drain filter. bobb283
Bottom left of the machine.  There is a square panel, take it off and underneath it is the drain filter.  you will have to unscrew it from the pump.
Dec 19, 2009 | LG WM2016C
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
Washing machine programme error
Hi, my LG manual for WD1238C says that OE is Drainage Trouble would imagine the Error codes are the same for all LG machines.
Jun 14, 2008 | LG Washing Machines
LE code on lg washmachine
The LE error code means that you have a motor problem.  The high pitched noise means that the motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to replace the sensor.
Jun 06, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
