Question about Whirlpool Dryers
Belt broke on dryer and cannot figure how to put back on pulley
  • 2,510 Answers
You give no information on your machine, but normally you need to obtain access to the complete circumference of the drum to fit the belt. Depending on your machine you can either remove the front of the dryer, or release the rear bearing support so that you can slide the new belt over the drum. The belt then just slips over the motor pulley and you need to check on the belt tension, usually done by adjusting the motor or the tensioner.
Posted on Mar 21, 2011
Kenmore elite front load dryer has power but won't turn on. It beeps once like OT is going to start but nothing
check to see if the belt broke,there's a switch on the belt pulley on some models,if the belt snaps from to large a load the pulley doesn't have any tension on it and the switch opens so the dryer won't run.when you put the belt back on the pulley sets the switch so power will go tough it again and the dryer will run,also check the door switch,if someone shut the door to hard and broke the switch the dryer won't run.these are the easy things to check without needing a meter.hopeit helps,if you're in mass. and need a tech you can call peter de's appliance 781-438-9442 very good techs
Jan 26, 2014 | Kenmore Dryers
I have an older kenmore 70 series dryer. the belt broke and im trying to figure out where the pulley is supposed to go and how the belt is supposed to go
If you are referring to the tension pulley that keeps the belt tight on the drum, it is common for it to come loose when the belt breaks because there is no longer any tension holding it in place. Just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place with your left hand, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 24, 2010 | Kenmore Dryers
GE model DQSR483EE1WW. This is what I know so far: the switch on the door works so it shouldnt be that safety, it is getting power because the light work and the timer at least buzzes like its working,...
Try looking for a broken belt. (electrical interlock prevents starting with broken belt) Disconnect power, open door, remove two phillips screws which go from top of door opening into dryer top. Swing top up and back. If belt not present going around drum, that's your problem. Remove one screw from side panel to front panel on each side (near top) and lift front panel forward and off the bottom pegs. Set the front panel to the side (leaving door switch wires attached) so you can slip new belt around drum. Reach under drum to put belt WE12M29 around drive pulley and around tensioning pulley. (grooved side of belt touches drum) Put front back on dryer and manually rotate drum a couple revolutions to make sure belt does not come off before closing up top and reconnecting power.
Dec 24, 2009 | Dryers
Amana electric dryer model #LE8217W2 belt replacement
This will help:
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 08, 2009 | Amana Dryers
Belt broke
Buy a new belt. Insert the idler pulley into the slots under the motor pulley. The wheel should be on the left side of the motor as you face it.
Put the belt around the drum, then through the idler roller. Then over the motor pulley.
Mar 11, 2009 | Kenmore 63942 Dryer
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
REMEMBER BELT GOES AROUND IDLER PULLEY AND ATTACHES TO MOTOR SHAFT ,PULL BELT W/ HANDRUN BETWEEN ROLLER, AND PULL BACK AND ATTACH ON MOTOR PULLEY AND THAT ITS
Jan 02, 2009 | Kenmore 64952 Electric Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer belt broke and the wheel tying the belt to the motor somehow come loose and was laying on bottom of dryer when I went to replace the belt, need schematics to figure out how to put wheel back in...
Below the motor pulley is two sets of parallel slots and some notches running perpendicular to them. Look at the tensioner, the piece that is laying on its side. Notice opposite of the roller is a flat surface with flanges that line up to the holes below the motor pulley. Ok? Alright now we want to scoop the front into one of those notches and it will hold. Now the belt goes over this roller on the tensioner first pushing slightly away from the motor pulley causing enough slack to loop it around the motor pulley so it goes over then around. Have someone hold the drum and steady so you can reach in, ps make sure the dryer is unplugged.:)
Ok here is a site I use to get illustrated, Look it over and punch in your model so you can see roughly how to get er done. Notice item 53 this is on my dryer, use www.apdepot.com.
Sep 29, 2008 | Dryers
Lse1000
The hard work is over! The old belt should pull out from the drum area if it is broken. There should be two ends to it now. Get a new belt and put it over the front of the tumbler. You should, (with a flashlight) be able to see where the old belt was running. Get the new belt close to that spot.. I believe your model ran with the smooth side of the belt to the drum.It will not look right to you, but the tensioner passes the belt through the pulley and motor pulley on the grooved side of the belt.Once the belt is on, reassemble the dryer front in reverse of disassembly.
Jun 13, 2008 | Maytag LSE7806A Top Load Stacked...
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
