Question about Hitachi (H2200U) 200 GB USB Hard Drive
I installed Windows 7 and it does not assign a drive letter to my Hitachi H2200U Portable External Hard Drive - 200GB, 2.5", USB 2.0 It does see the device but does not list it in a list of drives. It shiows enabled in device hardware list
  • jrgrigsby Mar 21, 2011
    Did as directed with no change. I also connected to an XP machine with the same result.
    It appears as tough the OS is expecting a master drive versus a "slave" under old IDE days. This is a USB 2.0 drive and the system reads it correctly as a Disk drive "Hitachi HTS542520K9SA00 USB Device" however it will not assign it a drive letter.
  • jrgrigsby Jun 12, 2011
    Had to Reformat!
  • 4,924 Answers
Try to install it ...Probably the installation will be automatically ...Just insert it ..and after that go to device manager if it do not start auto ..and in the device manager list click right on it ..and update driver...This will kick it to start the add new hardware wizard and install it ..This is a removable storage device ..and it should have been given a drive letter automatically in Computer folder..anyway ..Look again first maybe you missed it somehow ..and if it came with a driver install it ..or ..much more simpler is to get into control panel and start the add new hardware wizard directly and let it be installed ..if the computer do not sense it when you add it in usb ...
If it wont work ...let me know more..
Posted on Mar 22, 2011
  • 1 more comment
  • Catalin Turcu
    Catalin Turcu Mar 22, 2011
    By the way ..it is possible that in windows 7 to show you the device directly on the task bar ..in the left ...near the ones that are already open ...and minimized..
  • Catalin Turcu
    another thing you can do ..is to see if it is seen in control panel ..administrative tools/ computer management / disk management ...and if it seen as row ...just click on it to select ..and format it ..
  • Catalin Turcu
    the last comment is for the possibility it was used on Mac and it is formatted in another way which is not seen by windows...
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4.
Also start computer in safe mode for that when you power up the computer press F8 key 5 to 6 times then enter in safe mode .Then restart computer then it will be assigned drive letter.
Let me know if you need further assistance. Thanks for using FixYa
Posted on Mar 21, 2011
Windows 7 64 bit usb
Control Panel, Computer Management, Disk Management. Check that your Samsung disk is present. If it is present, does it have a drive letter assigned? If not Right Click and Assign Drive Letter.
If drive not present you should check power and data connections.
Jan 08, 2014 | Samsung G3 Station Desktop External Drive...
When i plugged my external hard drive, there's a
Hello there,
1. Is your Seagate portable external drive new? 2. Pug your external hard drive.
If it is follow instructions below. Guide is based on a Window7 operating system, you wont be having trouble if you're using Windows XP or Vista there will be a slight difference.
Note: you must be logged as an admin
a. Click start menu, right click-on Computer b. Left click on Manage. c. On Computer Management window. d. Left pane, Click Storage, Disk Management. you will see all available volume. e. If your Seagate is a new drive, it will appear as Un-allocated volume. f. Format the drive using NTFS file system before you can use it. you can also partition your new hard drive and assign a drive letter to the partition before you can use it.
Hopefully this guide helped. If you have questions feel free to ask me.
Thank you for using FixYa.
Aug 15, 2011 | Seagate 320GB Portable External Drive ...
My pc is not recocnizing the drive at all
you may have to assign a letter to the unseen drive manually: goto start menu and right click on my computer/ select manage/ select storage/ select disk management/ check to see if the drive has a letter assigned to it...if not right click on the drive in question and select change drive letter and paths/ then give it an unassigned letter and that should do it. if not just just text me back and w'ell investigate your power supply and/or the cable(s) and usb ports. hope this helps:)
Aug 05, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
I have a verbatim external hard drive, model usb500 and my computer does not recognize it. I have it plugged into a working usb port and the blue light on the drive is on, but my computer isn't...
You need to assign a drive letter for it to show up in Windows.
Right click on My Computer, click Properties. Then go to disc management, and right click on your external hard drive, and click Assign Drive Letter, and choose a letter and it will show up in My Computer.
May 08, 2011 | Computers & Internet
I have a iprodrive external hard drive and my laptop does not reconize it any more. the last time i used it i did not disconnect properly. is there a way to reset it
Here a step by step guide i found as i surf the net last week. Read along.
  1. Step 1 Log in to your computer as the administrator.
  2. Step 2 Install the external drive software from the CD that comes with your external hard drive.
  3. Step 3 Use the USB cable that came with your external hard drive and plug one end of the cable into your hard drive and the other into the USB port in your computer.
  4. Step 4 Give Windows a moment to recognize the external drive and to assign it a drive letter.
  5. Step 5 Go to the "My Computer" icon and double-click on it.
  6. Step 6 Choose the newly created external drive letter in the right-hand explorer window.
  7. Step 7 Right-click on the external drive letter and choose "format" from the drop-down box.
  8. Step 8 Choose "quick format" from the format options section from the next pop-up box.
  9. Step 9 Click the "Start" button.
  10. Step 10 Click the "OK" button in the Format warning box.
  11. Step 11 Click the "OK" button in the "format complete box" to finish the process.
Should you have any questions regarding this post feel free to post it here.
  • Step 2 Install the external drive software from the CD that comes with your external hard drive.
  • Step 3 Use the USB cable that came with your external hard drive and plug one end of the cable into your hard drive and the other into the USB port in your computer.
  • Step 4 Give Windows a moment to recognize the external drive and to assign it a drive letter.
  • Step 5 Go to the "My Computer" icon and double-click on it.
  • Step 6 Choose the newly created external drive letter in the right-hand explorer window.
  • Step 7 Right-click on the external drive letter and choose "format" from the drop-down box.
  • Step 8 Choose "quick format" from the format options section from the next pop-up box.
  • Step 9 Click the "Start" button.
  • Step 10 Click the "OK" button in the Format warning box.
  • Step 11 Click the "OK" button in the "format complete box" to finish the process.
  • Read more: How to Reset an External Hard Drive | eHow.com http://www.ehow.com/how_4840145_reset-external-hard-drive.html#ixzz0YYmAf0Ra
    Jul 24, 2010 | Computers & Internet
    Hitachi external hd 500G is not recognized by windows
    Are you running Windows 7? If so go to Start,R/Click computer,Click manage,In left pane click Disk management,Look for the new drive near the bottom of the screen.You'll need to format it and give it a drive letter,just left click it it'll move to the top portion of the window,left click in upper window and format.thats it your done,takes about 3 mins tops.
    Hope this helped
    May 27, 2010 | Hitachi 200GB External USB 2.0 Hard Drive
    Maxtor OneTouch 4 1000GB External USB 2.0 Hard Drive Problem on Windows 7: letter not assigned!
    adrianci
    Alot of times with the drive letter is not assigned this means that another device is already assigned to the drive letter that the drive wants to take.
    The below link will take you through changing your drive letter on your Maxtor drive.
    http://www.fixya.com/support/r4176803-change_drive_letter_in_windows_vista
    Let me know if you have any more problems or questions.
    Issken
    Jan 19, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
    How to use hitachi simpletouch external 320gb hard drive . i pluged in usb to computer and nothing happens. it should automatically open hard drive
    Hello
    If the HHD gets power and you can feel the drive spinning, you can try these steps and see if your problem is solved. Go to:
    control panel
    Administrative tools
    Computer management
    Storage
    Disc management
    Now you should see your drive in the schematic below. Right click on it and choose the option to change drive letter or paths. Now just assign a new drive letter to the drive, restart your computer and it should work fine.
    If you cannot see any power light flickering or feel movement on the drive when you power it up, then there is a other problem. Hope this can help you.
    Best regards
    Andrea
    Nov 03, 2009 | Hitachi 200GB External USB Drive 200 GB...
    Hitachi (H2200U) 200 GB USB Hard Drive Logo
    78 people viewed this question
    Top Hitachi Computers & Internet Experts
    Alun Cox
    Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
