There is no power going to the thirmistat - Heating & Cooling
Check to see if your getting 24v between red and com.if you got 24v there then you have a bad t-stat
Posted on Aug 03, 2008
06 Lincoln Navigator liftgate opens okay but need help to close why?
Power Liftgate
The power liftgate feature will allow the customer to automatically OPEN or CLOSE the liftgate by activating the interior open/close switch, the remote keyless entry transmitter or by manually initiating liftgate movement. The power liftgate uses a power cinch system to latch the liftgate.
The power liftgate system consists of the following:
  • Power liftgate control switch (located in the overhead console)
  • Power liftgate motors (located in the rear headliner area)
  • Optical sensor and power liftgate encoder wheel (located in the left power liftgate motor assembly)
  • Pinch strip switches (located on the body by the liftgate)
  • Home position switch (located on the cinch actuator)
  • Forkbolt switch (located on the cinching latch assembly)
  • Detent switch (located on the cinching latch assembly)
  • Liftgate close chime module (located in a unit external from the power liftgate module)
  • There are a lot of electrical switches an motors
  • Visual Inspection Chart Mechanical Electrical
    • Power cinching latch and linkage
    • Power liftgate pinch strip switches
    • Liftgate and liftgate hinges
    • Liftgate assist cylinders
    • Liftgate strikers
    • Exterior release handle and linkage
    • Liftgate weatherstrip
    • Liftgate alignment to body and striker
    • Central junction box (CJB) fuse:
      • 5 (7.5A)
      • 105 (30A)
    • Wiring harness
    • Connectors
    Are you willing to take the back hatch apart to test this ,to find a fix . But first have it check for DTC'S - diagnostic troulbe codes '
  • Power Liftgate Module Diagnostic Trouble Code (DTC) Index
    Power Liftgate Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU Is Defective Power Liftgate Module INSTALL a new power liftgate module. REFER to Power Liftgate Module in this section. B2477 Module Configuration Failure Power Liftgate Module REFER to Section 418-01 . B2522 Vbatt1 Circuit Failure Power Liftgate Module Go To Pinpoint Test B . B2552 Vbatt2 Circuit Open Power Liftgate Module Go To Pinpoint Test B . B2698 Vbatt2 Circuit Failure Power Liftgate Module Go To Pinpoint Test B . B2699 Left Pinch Strip Open or Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2700 Right Pinch Strip Open or Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2701 Left Pinch Strip Stuck Active Power Liftgate Module Go To Pinpoint Test B . B2702 Right Pinch Strip Stuck Active Power Liftgate Module Go To Pinpoint Test B . B2703 Open/Close Switch Stuck Active Power Liftgate Module Go To Pinpoint Test B . B2704 Optical Sensor Power Short to Ground Power Liftgate Module Go To Pinpoint Test B . B2705 Optical Sensor 1 Input Not Active During Powered Gate Movement Power Liftgate Module Go To Pinpoint Test B . B2706 Optical Sensor 2 Input Not Active During Powered Gate Movement Power Liftgate Module Go To Pinpoint Test B . B2709 Gate Open Output Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2710 Gate Close Output Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2711 Gate Open Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2712 Gate Close Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2713 Unlatch Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2714 Uncinch Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2715 Cinch Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2718 Gate Ajar Output Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2721 Gate Ajar Output Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2722 Open/Close Switch Active During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2723 Glass Position Switch Active During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2724 Forkbolt Switch Invalid During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2725 Detent Switch Invalid During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2726 Home Switch Invalid During Self-Test Power Liftgate Module Go To Pinpoint Test B . B2819 Gate Motor Circuit Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2820 Gate Motor Circuit Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2821 Cincher Motor/Unlatch Actuator Short to Ground or Open Power Liftgate Module Go To Pinpoint Test B . B2822 Cincher Motor/Unlatch Actuator Short to Battery Power Liftgate Module Go To Pinpoint Test B . B2825 Movement Ceased Due to Excess Speed Deviation Power Liftgate Module Go To Pinpoint Test B . B2903 Chime Output Circuit Short to Battery Power Liftgate Module/ Liftgate Chime Module Go To Pinpoint Test C . C1935 Chime Circuit Failure Power Liftgate Module/ Liftgate Chime Module Go To Pinpoint Test C . U1950 UBP Communication BUS Fault UBP Communi- cation REFER to Section 418-00 . U2338 Invalid ACM Message Data Power Liftgate Module REFER to Section 418-00 . U2242 Invalid 4WAS Message Data 4WAS Module REFER to Section 308-07A . U2403 Invalid CSM Message Data Vehicle Security Module REFER to Section 418-00 . U2406 Invalid IC Message Data Instrument Cluster Module REFER to Section 413-01 . U2469 Power Liftgate Disabled By Customer Interface Instrument Cluster Module Turn power liftgate on at message center. U2470 Unexpected Keyfob/Keypad Button Press Power Liftgate Module Go To Pinpoint Test A . U2471 Unexpected PRNDL State Power Liftgate Module REFER to Section 419-10 . U2472 Unexpected IGN State Power Liftgate Module REFER to Section 418-00 . U2473 Unexpected Vehicle Speed Instrument Cluster Module/ Powertrain Control Module REFER to Section 413-01 . U2528 PRNDL Data Mismatch Power Liftgate Module/ Instrument Cluster Module Go To Pinpoint Test D .
Feb 13, 2017 | 2006 Lincoln Navigator 4x4
2001 mazed tribute runs good no power to go up hills ?
Search Results
    Bogging - lack of power going up hills ' SHO Forum
    www.shoforum.com/index.php?threads/bogging-lack...power...up-hills...
    Oct 17, 2006 - I just ran into my first problem - The car runs fantastic on flats, going downhill,... ... No problem pulling up that hill at slow speed - plenty of power. It's only when out on a ... Anyone got a handle on a good used torque converter?
    why do i lose power on hills - CarGurus
    www.cargurus.com > Questions > GMC > Sierra 1500
    CarGurusOct 17, 2013 - I lose power on hills change the fuel pump and checked timing changed catalytic ... The TPS will make the ECU "go nuts" as it says...I'm here. ... has no power going up hill with small boat on, on flat ground runs good 1 answer.
    2000 toyota corolla lx aut. 4cyl. car looses power no power ...
    www.cargurus.com > Questions > Toyota > Corolla
    CarGurus
Mar 28, 2015 | 2001 Mazda Tribute
How do I reset lift gate on 2004 lincoln navigator. It doesn't open or close anymore with the remote
Maybe your key fob needs a new battery !
Power Liftgate Initialization
NOTE:If the power liftgate system is turned OFF in the message center, the system cannot be activated with any switches or with the liftgate handle. The system will need to be turned ON for any power operation to occur.
NOTE:The power liftgate may not operate under the following conditions:
  • a low voltage or dead battery.
  • a disconnected battery
  • a power liftgate that has been left open for more than six hours.
  • a power liftgate that has been manually closed and left ajar.
If any of these conditions has occurred, the power liftgate must be reset.
  1. Manually close and fully latch the power liftgate.
  1. NOTE:If the power liftgate does not open during this step, refer to the symptom chart to diagnose the power liftgate for no operation.
    Power open the power liftgate by using the keyfob or overhead console switch.
  1. Once the power liftgate is fully open, close the power liftgate by using the keyfob or overhead console switch.
    This system can also set DTC'S
  2. POWER LIFTGATE MODULE DIAGNOSTIC TROUBLE CODE (DTC) INDEX (BODY CLOSURES) 501-03 Body Closures 2004 Expedition/Navigator DIAGNOSIS AND TESTING Procedure revision date: 08/23/2004
    DTC Description Source Action B1342 ECU Is Defective Power Liftgate Module INSTALL a new power liftgate module. REFER to Power Liftgate Modulein this section. B2477 Module Configuration Failure Power Liftgate Module REFER to Section 418-01. B2522 Vbatt1 Circuit Failure Power Liftgate Module GO to Pinpoint Test B. B2552 Vbatt2 Circuit Open Power Liftgate Module GO to Pinpoint Test B. B2698 Vbatt2 Circuit Failure Power Liftgate Module GO to Pinpoint Test B. B2699 Left Pinch Strip Open Or Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2700 Right Pinch Strip Open Or Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2701 Left Pinch Strip Stuck Active Power Liftgate Module GO to Pinpoint Test B. B2702 Right Pinch Strip Stuck Active Power Liftgate Module GO to Pinpoint Test B. B2703 Open/Close Switch Stuck Active Power Liftgate Module GO to Pinpoint Test B. B2704 Optical Sensor Power Short To Ground Power Liftgate Module GO to Pinpoint Test B. B2705 Optical Sensor 1 Input Not Active During Powered Gate Movement Power Liftgate Module GO to Pinpoint Test B. B2706 Optical Sensor 2 Input Not Active During Powered Gate Movement Power Liftgate Module GO to Pinpoint Test B. B2709 Gate Open Output Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2710 Gate Close Output Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2711 Gate Open Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2712 Gate Close Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2713 Unlatch Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2714 Uncinch Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2715 Cinch Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2718 Gate Ajar Output Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2721 Gate Ajar Output Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2722 Open/Close Switch Active During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2723 Glass Position Switch Active During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2724 Forkbolt Switch Invalid During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2725 Detent Switch Invalid During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2726 Home Switch Invalid During Self-Test Power Liftgate Module GO to Pinpoint Test B. B2819 Gate Motor Circuit Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2820 Gate Motor Circuit Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2821 Cincher Motor/Unlatch Actuator Short To Ground Or Open Power Liftgate Module GO to Pinpoint Test B. B2822 Cincher Motor/Unlatch Actuator Short To Battery Power Liftgate Module GO to Pinpoint Test B. B2825 Movement Ceased Due To Excess Speed Deviation Power Liftgate Module GO to Pinpoint Test B. B2903 Chime Output Circuit Short To Battery Power Liftgate Module/ Liftgate Chime Module GO to Pinpoint Test C. C1935 Chime Circuit Failure Power Liftgate Module/ Liftgate Chime Module GO to Pinpoint Test C. U1950 UBP Communication BUS Fault UBP Communi cation REFER to Section 418-00. U2338 Invalid ACM Message Data Power Liftgate Module
Feb 05, 2015 | Lincoln Cars & Trucks
Online chat
test light ... power in to switch.. check power out. Then check power at relay... constant power large wire ..exciter power small wire..ground closes circuit.. sends power to motor. Check power at motor might work on reverse polarity... switch test first...if motor has onley two wires it reverses power for up down.
Oct 14, 2013 | Chevrolet Cars & Trucks
How can i move a power seat that wont move
On these case go with the solved problems related to these issue.
Click the link below and follow the procedure:-----
1994 Lexus GS300: Power seat will not go back? http://howtobyme.blogspot.in/2012/05/1994-lexus-gs300-power-seat-will-not-go.html
1997 Toyota Avalon: Power Seat will not Move back? http://whatisbyme.blogspot.in/2012/05/1997-toyota-avalon-power-seat-will-not.html
1998 Chevrolet Corvette: Power Seat Control Now Working? http://schematicsdiagram.blogspot.in/2012/04/1998-chevrolet-corvette-power-seat.html
Power seat will not go Forward http://repairhelpcenter.blogspot.com/2012/10/power-seat-will-not-go-forward.html
Replacing power adjustable bucket seats to both heated and cooled seats?
http://schematicsdiagram.blogspot.com/2011/12/replacing-power-adjustable-bucket-seats.html
Volvo Seat Removal with Heated Seats? http://schematicsdiagram.blogspot.in/2012/07/volvo-seat-removal-with-heated-seats.html
How to Remove Rear seat on Rover 600? http://repairhelpcenter.blogspot.com/2012/01/there-are-3-10mm-bolts-at-back-of-seats.html
How to remove Seat? http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-seat-on-acura-integra.html
These will help.
Thanks.
Nov 23, 2012 | 1998 GMC Jimmy
My computer is set to turn on when power goes off but the power will go off and my computer would not turn on its own
Need to how to correct this probnlem . my cuputer is set to turn on when when the power goes off. but the power will go off and then turn back on and my will not go on with my help.
answer:
sir all you have to do is go to bios setup. change the settings in power management menu. to go there restart your pc and press F2 or delete key before or after the power on self test. look for the words "power on after power failure", the statement may vary depending on the type of motherboard.
hope this helps. email me at tennisyman@yahoo.com
Sep 27, 2012 | Computers & Internet
Windows will not go up or down in 1997 grand marquis power windows
For all types of power window problem and power windows not working,i suggest you to go through the help links given below. Click the link to go through its procedure to troubleshoot the problem :------
Power window problem
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
Power windows not working after car wash?http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
power locks, power window and power mirror not working?
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove window motor and regulator on Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
Complete Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
-----------This will help.Thanks.
Feb 01, 2012 | 1997 Mercury Grand Marquis
I have a 06 trailblazer, and my drivers window will not go down. I had the motor cahnge it and is still not working. WE even took the switch out of the drivers door and connected it to the passenger door...
Are you aware of the fact that there are door modules ? Controlled electronically !
Power Window Inoperative - Driver Door
Operate the driver power window in the UP and DOWN directions.
Does the driver power window operate properly?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Install a scan tool.
Monitor the Driver Window Status Data parameter in the driver door inputs list.
Does the Driver Window Status Data parameter display an active state?
YES - Go to Step 11
NO - Go to Step 4
Monitor the Driver Window Status Data parameter in the driver door module (DDM) inputs list.
Activate the driver power window switch in the up and down positions.
Does the Driver Window Status Data parameter change accordingly?
YES - Go to Step 5
NO - Go to Step 11
5
Connect a test lamp to a good ground.
Backprobe the battery positive voltage circuit at connector C1 cavity D.
Does the test lamp illuminate?
YES - Go to Step 6
NO - Go to Step 13
6
Disconnect the driver power window motor.
Probe the power window motor up control circuit at the power window motor harness connector.
Activate the power window switch to the UP position.
Does the test illuminate?
YES - Go to Step 7
NO - Go to Step 9
7
With the test lamp still connected to a good ground, probe the power window motor down control circuit.
Activate the power window switch to the DOWN position.
YES - Go to Step 8
NO - Go to Step 10
You probably have a bad door module .
May 21, 2017 | Chevrolet TrailBlazer Cars & Trucks
Our computer is on but the screen says ''power save mode'' and then will go black. How do we fix this?
You will have to wake up the computer, right click on the main windows screen, go to properties, go to display,
Then go to screensaver, then go to power options.
Now that your hear, you can change any settings, power saving mode, Battery power mode, ac power mode, what happens when you close your lid, and more.
Mar 06, 2010 | Computers & Internet
Optiplex 755 flashing orange power button light only
Sounds like you only have power going to your motherboard.
The power supply might be bad on it, that or maybe the power cord is going bad and is only letting a small amount go through. I don't see why there should be a problem if you have even a little bit of power going though.
Jul 11, 2009 | Dell Optiplex 755 Minitower Desktop...
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
