Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Microwave JVM1842BD-001 and the turntable has stopped turning,I notice when I remove the glass tray the unit turns but very slow.
  • GE Master
  • 6,771 Answers
The problem is in the turntable motor it has become defective "common issue in a number of brands" the only solution is to have it replaced.
Posted on Mar 21, 2011
Oster microwave turntable will not turn, food on one side is hard as a rock
hi suzanne.
If the glass tray in your microwave doesn't turn, it may be due to a broken drive motor. Most units have a round glass turntable which has a motor driven coupler and roller guide turning the tray. To access the motor, first unplug the microwave and remove the bottom panel.
How to Repair a Microwave Tray That Will Not Turn - PartSelect
microwave turntable will not turn Google Search
Nov 07, 2017 | Oster Microwave Ovens
My ge micro will not stop turning
HELLO.
If by not turning mean turntable fault,the solution is given below in detail.
1 Press "Stop" to halt microwave operation.
2 Press the "Turntable" button once to turn off rotation.
3 Push the door-release button to open the microwave oven if you do not have a "Turntable" button on your control keypad.
4 Lift and remove the glass platter from the oven, then pick up the plastic track with three wheels below the platter. Set aside these parts.
5 Insert the elevated microwave cooking tray into the oven. The tray has three to four short legs that hold it above the bottom of the microwave, keeping it from interfering with the rotating bolt in the bottom center of the oven the drives the turntable. You can now place food on the elevated tray and cook normally without disrupting the drive bolt.
Thanks.
Sep 20, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The turntable doesnt turn. The clock, timer, start/stop and the heating do all work. How can I get this thing removed from the built in unit less than 4 years old
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.....
Mar 19, 2011 | Microwave Ovens
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable does not turn
Good luck.
Jan 13, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE PVM1870 turntable not working
The little brown thing is broken. I have several break or melt. Pull it out and look at it.
Nov 18, 2009 | General Electric PVM1870 Microwave Oven
The turntable has stopped turning. is there a
It could be the plastic coupler part #942560. Remove your glass tray and lift up the plastic piece in the middle. It slides off of the motor. If it is broken that is your problem.
Oct 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
200 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
