Question about Bosch Dishwashers
Loud noise is coming from my dishwasher and its not taking water...
  • Bosch Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Mar 21, 2011
Ignis dishwasher not working. When switched on a loud banging noise but there's no water?!
you need to take the drain pump off and clear whatever is in there. Pull the dishwasher out, remove the bottom cover or gain access to drain pump. Thats what it sounds like
Feb 14, 2013 | Dishwashers
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    My haier dishwasher is not filling with water just making a loud humming noise
    Here is a tip that will help you to find out why water will not come into the dishwasher...
    heatman101
    Nov 11, 2010 | Haier Dishwashers
    Loud noise starts as soon as water starts coming into dishwasher. Stops when water in or water draining. What could it be?
    This hammering is usually from restrictions in the water line or inside the valve on the machine itself.
    Try taking the water line off of the machine(with the water supply turned off) then disconnect the line from the dishwasher and flush water into a bucket from this line until it runs clean. Reconnect, if it still makes the noise you will need to replace the inlet valve on the dishwasher. Let me know if this was helpful or if you have questions please.
    Thank you
    Jun 14, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
    Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
    GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
    Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
    Loud clanking noise in dishwasher
    Most likely the motor as food caught in the sump would not make a noise you described.
    http://tclaundryrepair.com/home
    Feb 19, 2009 | Kenmore Dishwashers
    Water supply line vibrates making very loud noise.
    these vibration in water pipes or cooper lines come from air in thewater supply system..dont take your appliances apart...
    Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
    1 week after installation- is very loud
    dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
    Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
    Maytag dishwasher mdb56000aww
    It seems that your motor on the dishwasher is going out, like mine has just done. My explanation is that it sounds like something is grinding on glass or as if a bunch of mice are making noise. Eventually, the motor will not run any more. What will happen is that the dishwasher will fill up, then make a loud humming noise, while the heating element is making the water near the heating element sizzle. Now what you have is a possible fire hazard which compounds the problem with the dishwasher. Get rid of it, take the loss and live like my grandmother used to, without having a dishwasher. That is the best advice I can give you.
    May 08, 2008 | Maytag 24 in. MDB5600A Jetclean II...
    Dishwasher Making Loud High Pitched Noise.
    A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
    Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
    Dishwashers Logo
    67 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
