Question about Lands Phones
What are the holes on the back of the hand set for?
Riso CR1610 door was opened before letting down cylinder need to know how to reset and close door
if the drum is partly out and u cant get it to go in or out, u will need to open the top cover and reach in and manually turn the drum by hand until the white sticker on the front of the drum is at the top, at that point it should open. pull the drum all the way out at that point and look strait in the back of the machine where the drum sits, there is a big gear back there, there is a hole in the gear, and a little hole in the frame above the gear, make sure they are lined up, if not, reach back and turn gear by hand, this will set the timing back if it has jumped out
Dec 17, 2012 | Riso Office Equipment & Supplies
Need a diagram of fuel line routing
Right you have three hoses, there are two holes in the tank unit, the smaller of the two holes ( too the left hand side as you look down on top) this is the main fuel hose which has the fuel filter on the end in the tank, this then fits to the right hand connection on the carb, there is then a short hose which connects to the carb on the left hand side, and then goes to the shorter of the two connections on the back of the primer ( suction side ) there is then a hose from the longer connection on the primer( pressure side ) back to the hole to the right hand side of the tank , so to recap the primer pulss fuel from the carb, into the primer bulb, and dumps back to the tank.
Sep 09, 2012 | Poulan Pro 14" Gas Chainsaw 33CC P3314
My insignia hand brake has locked on how do i release rear offside only
you need to take off the rear wheel and there is a hand brake hole in the drum on the disc. you locate the hole with the adjuster.. make sure the hand brake is not on. the leaver for the hand brake take the cable off if the brake is locked the leave will let you take it off. then get a peace of wood and put it on the leaver and hit it back with hammer on the wood not the leaver. then take the screw out for the locator of the disc. and hit the disc with rubber or plastic hammer going round the disc. not to hard just to get it to move when of find out why the hand brake is locked in the first place. ( prob be the shoe's pins ) change the parts. while parts off give good clean and put some copper grease on the parts that move. huck back up the cable and check disc drum part for damage. screw the adjuster back down and refit. when disc back on adjust the brake with the hole lined up and move back and forth until the brake is locked then turn back one point on the adjuster check the disc turns and then use the hand brake. if still an bit hard to move after hand brake off nock the adjuster back down one more and test again. if all well put wheel back on.
Jun 04, 2012 | 2003 Vauxhall Vectra
Optiview
try the user as admin and the password as admin..
If my memory serves, there is also a master reset switch..
Look for a small hole in the rear of the case, power the unit off, press and hold a small pin into the hole to hold the switch in and then switch the power back on..
I know ya need three hands to do this...
If no hole is present, check inside the case on the board for the reset switch..
Feb 14, 2012 | Home Security
How do i set the engine to tdc
WHAT I USED TO DO IS REMOVE THE #1 CYLINDER SPARK PLUG, AND PLACE A SCREWDRIVER IN THE HOLE, THEN SLOWLY TURN THE CRANKSHAFT PULLEY BY HAND TILL THE SCREWDRIVER COMES OUT OF THE HOLE! AS THE PISTON RISES, THE SCREWDRIVER WILL COME OUT, WHEN YOU PASS TDC, THE SCREWDRIVER WILL START GOING BACK IN!
Feb 27, 2011 | Peugeot 405 Cars & Trucks
There is a very slow leak only at the weep hole site under the faucet, not at the main faucet outlet
The hole is designed to let water out instead of going back into your wall. The spout needs to be taken off (unscrewed usually by hand) and tephlon tape needs to be put on the threads coming out of the wall. After this is done, screw the spout back on. Should be all set.
Dec 31, 2009 | Delta RP17453SS Standard Diverter Tub...
Sony house phone model spp A940 rings in when i pick up cordless hand set no sound. shows a cl error. battery in hand set good.
Most likely if you remove the back of the handset case you will find inside the handset near the hole in the back of the handset some corrosion or rust on the circuit board from water getting inside the handset.
Saw it many times. No good fix for the problem.
AL
Dec 20, 2009 | Sony Lands Phones
Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
Password problem
Open out a paper clip, pull the power connection out of the back of the DLink.
On the back of the DLink is a tiny hole with "reset" written above it, poke the end of the paper clip into the hole untill you feel a tiny switch click down, hold the switch down and put the power plug back in (this takes three hands) hold the switch down for ten seconds and your modem/router will be set back to factory settings.
username Admin
password Admin
try admin and try with username only or with password only.
It's been a month or two since I did a DLink and I cant remember which it is.
Jul 22, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Luminox 3000/3900
I just fixed the same problem .There is a small arrow pointing to a small hole .insert a very thin screw driver or a pin and the stem will come out easily.
Jun 21, 2008 | Navy Seal Luminox Dive Watch
Lands Phones Logo
111 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
