I was just wondering if the EPA pellet stove needs a full chimney on the outside wall or if it is just vented l with a short chimney. It says is has an outdoor air kit. I'm not sure what that intails thank-you
    Brigadier General:
  • 4,736 Answers
The approved method of exhaust venting is a full Type L or PL Pipe chimney. The height of which must be a minimum of 3 feet higher the highest roof structure. The outdoor air kit is used to pull fresh combustion air into the system from the outside. The exhaust venting can go horizontally for no more than 2 ft and then must elbow up to what I stated above. OR if you have a single story home, it can go up through the ceiling, through the attic and terminate above the roof. Any time the vent pipe passes thru a combustible surface it must have a fire stop.
Keep in mind, this was just a brief overview of what is required. Each stove manufacturer as it's on guidelines for safe installation that will not only meet EPA Standards, but also your local Building Code Standards and NFPA Standards. Not installing it properly or not having it professionally installed, may void any claim you may have in the future with your homeowners insurance, that resulted as a loss, because of the stove and/or it's installation.
Hope this helps.
Posted on Mar 21, 2011
Pellet stove smokes after blower stops
This should not be happening, have somebody check the draft for you, smoke should be drawn out chimney, unless draft is no good.
press the helpful button
Feb 11, 2016 | Pool & Spa
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
WHAT DOES ER2 CODE MEAN ON PELLET STOVE
Which pellet stove do you have? A lot of pellet stoves have a part inside called a Draft Flow Switch the size of your palm and hook to the Draft Flow Switch is a Draft silicone hose and this will get clogged with debris you will need to look at your diagram to see if you have that on your stove. If you do you will need to "gingerly take off the hose and blow through it. and re connected to the draft flow Switch. After sometime the hoses become brittle. Another thing to look at is the exhaust at the back of the stove cleaned out and you are getting your pellet stove cleaned out by a chimney sweep.
Mar 03, 2014 | Us Stove Company Pellet Heater with...
Stove is shaking
I would suggest going to this website http://www.drolet.ca/en/installer-locator and you can find someone from Drolet who is authorized to diagnose your issue. If you can't find someone close by on the Drolet website then look for chimney sweeps through Angie's List preferably and they can help diagnose and determine the problem. First stop always default to an AUTHORIZED SERVICING DROLET service techinichian. Especially with pellet stoves, depending on the technology, these can be extremely technical with the exhaust and combustion blowers being off balance and causing the stove to shake. Without someone there to look at it and diagnose it hands on it is equivalent to when your car has a check engine light and you don't take it to a mechanic. Pellet stoves can be extremely tricky to work on. Good luck and try the manufacturer first.
Find an installer near you Drolet
Jan 11, 2014 | Drolet ECO-45 High Efficiency EPA Pellet...
Woodstove smokes into the house
I've never used a ceramic chimney, or seen one for that matter. I know that the dual walled vent pipe works better when warn/hot. Can't explain it real well but the inner pipe gets hot while venting the heat and smoke. And between the inner and outer wall is cooler air, which is drawn down towards the wood burner. Creates a suction by the exhaust out of the center pipe. Mine smokes up the house when I leave the doors open and when it's a low flame inside. I'm sure you've checked on the manufacturers' specs for venting but, if you don't already know, look into the thermal dynamics of a dual walled vent pipe. And also a ceramic as you have. Has to be something with your stove install or vent pipe. Hope this couch advise helps!
Apr 04, 2017 | Heating & Cooling
I have a 3 ft stainless double wall chimney that is going thru a ceiling/roof in my garage. there were no instructions on installation. how is this secured? Pls thx Jer
You can use metal strapping with short self-tapping sheet metal screws also where it penetrates roof a metal collar on inside should be used and a roof collar approved for B-wall vent pipe to keep water from leaking inside on outside on the roof.You can penetrate outside of B-wall vent pipe with short screws to secure the pipe just don't penetrate both pipes.this outside pipe is just a insulator to keep heat from transferring through pipe.
May 01, 2011 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
Have a pellet stove that has been working perfect for years, then last night it shut itself off and when I opened door there was this black tar on everything inside and the windows were also black. I had...
Several of things come to mind: Have you changed the type (Brand) of pellets, recently?
Have you had your chimney (stack) cleaned in the past year? Is the fresh air intake functioning properly? Is the auger feeding to much or to little pellets?
Changing brand of pellets - Not all wood pellets are made the same. If you recently changed brands, you will need to tweak your stove to handle this new brand. This will affect how the auger feeds.
If you chimney (stack) hasn't been cleaned in the past 12 months, it may be partially clogged with creosote and not drawing properly and it is liquefying and running back down the chimney and not allowing for a clean burn. And could cause a chimney fire.
Fresh air intake: If that's not functioning properly, you're getting incomplete combustion. Which will cause the black tar looking substance you described. Couple that with changing brands of pellets and you have a problem.
The above are the first things that came to mind. I hope it steers you in the right direction to troubleshoot the problem. Please let me know.
Mar 28, 2011 | Heating & Cooling
What do you need to do to put a woopellet stove pipe thru wall
I'm confused by your question. If you are asking what is involved in installing a pellet stove well it varies greatly from model to model. Generally speaking, most pellet stoves will horizontally terminate behind the stove itself as opposed to running thru the roof like a woodstove does. Pellet stoves require the use of electricity for numerous functions, one of which is power venting thru this rear terminated pipe. As far as clearances to combustables, you will find that pellet stoves are very forgiving in that department, with minimal clearances required. Once again all stoves are different and they all are rated indepentently so my best advice to you is find a quality pellet stove dealer and go in and see them. They will be more than happy to answer your questions. Avoid the big box stores as they have pellet stoves at a good price but offer NO service or installation and believe me, I am in the business, you will need professional service at some point during the life of your stove so don't save a couple bucks by going cheap. You will be happier for it down the road. Good luck.
Mar 12, 2009 | Napoleon Auburn Pellet Stove Heater
Offset of verticle stove pipe between stoveand chimney
use single wall pipe in the heated area.
Aug 19, 2008 | Grilling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
