Question about LG 42LC2D 42 in. LCD HDTV
It has what looks like line in the back ground of screen
    Scholar:
  • 126 Answers
Horizontal or vertical? how big is the line? a lot of lcd tv companies had a problem with the tab bonding on the actual lcd screen that may be causing this - you can also check the ribbon cables on the tcon board to make sure htey are seated properly that may clear up the issue.
thanks,
michael
Posted on Mar 21, 2011
My Sharp flat screen has verticle lines running down the screen in various colors and every once in a while a picture with pop up but then fade away. The capacitors all look fine and i have no idea wh
the lines is the screen its self there is a board that the screen fits to over time it heats up and comes away from the screen and you get lines, you can sometimes push on the screen top to get them back but its only a temp fix you will need to take the screen out and remove the cover and put some shims in place on the screen. this is not a job for the faint hearted as it is a delicate job.
Mar 28, 2014 | Sharp LC-32DV22U Widescreen 32-Inch Class...
2 wide vert line center of notebook screen,solved?
actually some of the panels of your laptop screen are damaged.only there is one way,you need to change the screen
Apr 03, 2012 | Computers & Internet
I have a insprion 1545 that half of the screen is white with vertical lines on a white back ground. The other half is fine but can only view the left half of the screen. I hooked it to an external monitor...
It is a screen problem. You have to replace the LCD. It is either cracked or the electronics of the LCD is faulty. Find the part number on the back of the LCD and look for it on ebay.
Aug 08, 2010 | Dell Inspiron 1545 Notebook
Buzzing and green line
A buzz in the sound usually indicates poor grounding somewhere or bad filter caps in the power supply. Lines moving up the screen used to be common in old tube sets, also indicates bad power. Have you opened up the back for a look?
Mar 31, 2010 | LG 42LC2D 42 in. LCD HDTV
LCD TV picture has vertical lines through picture equal spacing
Call 323-767-6030 and I will go through with you.
Dec 09, 2008 | Televison & Video
Fly back lines
Check the connector of the crt maybe got a resistor open or a transistor in short circuit.
Jul 06, 2008 | Televison & Video
Lines across the screen
the dark lines could be what is called hum bars these are caused by ground differences between cable and your AC ground. check to see if these lines appear using a dvd and removing the cable from the cable box. if the lines disappear then call the cable company and your electricain. in the mean time you can use a plug adaptor that is the 2 prong (ground less) until you can have the problem fixed. but don't use the adaptor as a fix, for your TV is a computer and needs proper grounds.
Apr 14, 2008 | Mitsubishi Diamond WD-65831 65" Projection...
Problem with display
Hello
If you only bought it 2 months ago it will be under warranty
You should send it back to be serviced as it sounds like a faulty LCD and it will need to be replaced
Dec 25, 2007 | Sony Ericsson W850i Cellular Phone
Green vertical lines on the screen
Sounds like you may have some bad filter capacitors in the convergence board. Better take a close look at them before they damage the chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 15, 2006 | Hitachi 42V710 42" Rear Projection HDTV
LG 42LC2D 42 in. LCD HDTV Logo
140 people viewed this question
Computer Repairing
Computer Repairing
