Question about Frigidaire ATF6000ES Front Load Washer
I have black mold on the rubber ring in the softener area that won't come out. Sometimes clothes smell
  • 4,350 Answers
Front load machines have smell issue. There is a cleaner made for this purpose, get some and run it through routinely. Apparently, all front loaders have this issue...
Posted on Mar 21, 2011
Gasket seems to have pulled away from "drum" side;
Front loaders are known for building up mold and the smell.
It's caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It's caused by using fabric softener. Dilute it 50/50 with water.
It's caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Jan 25, 2011 | LG WM-2277HW Front Load Washer
There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
Hi.
The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
The only way to remove is by replacing the door seal.
If you try bleach etc then it will cause the mold to get worse.
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer smells. After washing clothes the clothes smell and i always leave dorr open between washes
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Oct 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Water sitting and mold growing in the rubber gasket ring around the opening for the door
affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 09, 2009 | LG WM-2277HW Front Load Washer
My clothes smell mildewy. Why?
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Leaks water under unit and smells musty model# mah6500aww door boot was replaced and still looks fine doesnt allways leak just when it wants too also cloths smell like river water and sometimes still has...
Oct 07, 2009 | Maytag Neptune Washer
Clothes don't smell good after they have been washed.
Oct 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Foul odor
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%4
Aug 26, 2008 | Kenmore Elite 45986 Front Load Washer
The bin stinks like mold
Have had machine for 6 years.  Mold is an issue.  Occatioinally I clean out the drawer and behind the grey rubber seal with vinegar.  After a load is washed, I dry off seal and leave door slightly open.  Occationally I also wash a load of nothing but bleach.   Hope this helps.
Dec 30, 2007 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
138 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
