Dvd or cd does not play after i have formated and installed windows xp
  • Computers & ... Master
  • 27,725 Answers
Make sure that the cd/dvd is getting enough power test all leads that are attached to the cd/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Mar 21, 2011
How do I install my 22w2 to my Dell Computer with Windows XP 2002
Windows install first Available some points:-
A> Fresh Windows XP CD not damage cd, if cd damage may be some file miss and installation after problem show.
B> DVD Rom Drive.
C> You DELL pc support Windows XP.
Installation Process:-
> Insert CD to DVD ROM driver and boot CD.
> If CD not select first boot then open bios and select CD first boot.
> Then follow instruction step by step like language, which drive install windows (C Drive select), format option (select quick format), new user create etc.
Thanks..
Sep 06, 2013 | Westinghouse Electric LCM-22W2 Monitor
I HAVE THE LAPTOP ACER ASPIRE 5740G. I WANT TO FORMAT THE HARD DISC AND FIND THE DRIVERS FOR WINDOWS XP
You can format the hard drive using the Windows XP CD
  • Download the drivers from the Acer website and burn them to a CD or DVD
  • Make sure that the CD drive is the first drive to boot in the computer's BIOS
  • Press a key when the CD starts to boot
  • On the blue screen press Enter
  • Press F8 to agree to the license
  • Press Esc for a new copy of Windows
  • Press D to delete the partition on the drive
  • You may need to press Enter and L to confirm
  • Press enter to install Windows
  • Choose the appropriate format option
  • Windows will install
  • Insert your driver CD or DVD and install the drivers.
Jul 24, 2011 | Computers & Internet
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
I needed to format my harddisk. How do I get my windows XP reinstalled. I have windows product key number. I also have Compaq (pressario) product and serial numbers. Any hints?
Reinstall Windows XP loadTOCNode(2, 'moreinformation'); To reinstall Windows XP, try either of the following methods. If the first method does not work, try the second.
Note You may want to disconnect from the Internet during the installation. This helps protect you from malicious users. Start the reinstallation from Windows XP loadTOCNode(3, 'moreinformation'); To reinstall Windows XP by using Windows XP CD, follow these steps:
  1. Start your computer.
  2. Insert the Windows XP CD in your computer's CD drive or DVD drive.
  3. On the Welcome to Windows XP page, click Install Windows XP.
  4. On the Welcome to Windows Setup page, click Upgrade (Recommended) in the Installation Type box (if it is not already selected), and then click Next.
  5. On the License Agreement page, click I accept this agreement, and then click Next.
  6. On the Your Product Key page, type the 25-character product key in the Product key boxes, and then click Next.
  7. On the Get Updated Setup Files page, select the option that you want, and then click Next.
  8. Follow the instructions that appear on the screen to reinstall Windows XP.
If you successfully completed the reinstallation, congratulations. You are almost done. Please continue to the "After you reinstall Windows XP" section to finish.
Method 2: Repair install of Windows XP by starting your computer from the Windows XP CD loadTOCNode(3, 'moreinformation'); Note If Windows XP was preinstalled on your computer, you may need the installation CD to reinstall. Contact your computer manufacturer to make sure that you have the installation CD for a repair installation.
To reinstall Windows XP by starting your computer from the Windows XP CD, follow these steps:
  1. Insert the Windows XP CD into your computer's CD drive or DVD drive, and then restart your computer.
  2. When you receive the "Press any key to boot from CD" message on the screen, press a key to start your computer from the Windows XP CD.
  3. The following message on the Welcome to Setup screen will appear: This portion of the Setup program prepares Microsoft Windows XP to run on your computer: To setup Windows XP now, press ENTER. To repair a Windows XP installation by using Recovery Console, press R. To quit Setup without installing Windows XP, press F3.
  4. Press ENTER to set up Windows XP.
  5. On the Windows XP Licensing Agreement screen, press F8 to agree to the license agreement.
  6. Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
  7. Follow the instructions that appear on the screen to reinstall Windows XP. After you repair Windows XP, you may have to reactivate your copy of Windows XP. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 310064 (http://support.microsoft.com/kb/310064/ ) How to troubleshoot Windows XP Setup problems when you upgrade from Windows 98 or Windows Millennium Edition.
Hope this helps.
Dec 28, 2010 | HP Computers & Internet
How to format my compaq pressario cq40 604tx laptop with xp
hi
Boot from your XP install CD and select the option to format the C:
drive. If you don't have an install CD, use the "System Restore" CD or
DVD that came with your system. These restore your system to factory
settings. There're still other ways to format your C: drive, but
without either an install CD or restore one, you'll end up with an
unusable system after formatting the C: drive.
If you use the XP install CD, you'll need to be SURE you have all the
drivers for things like your DVD/CD drive, NIC, video, audio, modem, etc.
Jul 02, 2010 | Microsoft Windows XP Professional With...
How to reformat my windows xp computer
OK get into system BIOS, prees DEL. F2, or whatever your key is. Set in the BIOS to Boot the DVD FIRST, Then insert you DVD, Boot off your Windows DVD, & install from, the DVD, go through the setup to where it asks you if you wish to FORMAT, choose FULL NTFS Format and let it complete, then proceed with the install, done.
Feb 21, 2010 | Microsoft Windows XP Professional SP2
How to format os in compaq cq40-616tu os is windows xp sp3
If you not a professional, don't worry about it.
Follow these steps;
  1. Insert the Windows XP CD in CD-ROM/ DVD-ROM etc.
  2. Boot from CD-ROM and press any key when it required.
  3. Now press enter
  4. Press F8 when it will be required.
  5. Now select the drive C for installaiton of OS XP.
  6. Now choose format option FORMAT with NTFS or FORMAT with FAT (its your own choice)
  7. Now press F
  8. After formatting the files will be installed to copy on the disk and now in the end follow the instructions to installing windows.
Good Luck
Jan 26, 2010 | Microsoft Windows XP Professional With...
How do I format a disc (DVD or CD) on Windows XP?
You only format a CD/RW or a DVD/RW, which are re-writeable.
Regular discs do not need to be formatted (CD-R or DVD+R, DVD-R, DVD+R DL, etc.).
To format the DVD/RW idisc, use the "burner" software ( Sonic?, Nero?) and choose [Tools] [Erase Disc] (erase is the same as format)
Oct 13, 2009 | Microsoft Windows XP Professional for PC
DVD RW DVR-K16 does not recognize blank DVD-R
I have a Pioneer DVDRW DVR-K16, in a sony dv81114Notebook. Running Windows XP. It cannot play dvd's and cd's, It will recognize blank CD-R's but when I insert a DVD-R it say's no disc installed. I have firmware version 1.15.
Nov 26, 2008 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Resource cd for aspire 4315 laptop PC
Some Vista driver may work on XP, however, to avoid any risk of getting in troubles with your Windows xp installation, you can download drivers and utilities for XP starting from this page.
Regards
Jun 08, 2008 | Acer Aspire 4315 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
