Question about Car Audio & Video
Has a '99 Buick Regal GSE; Needs the "Service Engine Soon" warning light reset code and method.
  • smwade886 Mar 21, 2011
    I made a mistake, my error is "Service Vehicle Soon", my mechanic said there are no codes
    associated with this warning light on the console, it says it usually is a sequence of things
    you do to reset it,he says the little computer that you attached to your car does not work with
    this warning light. He said it would be in my owners manual but unfortunately I do not have one,
    Check with Buick dealer where I live , they do not have one
  • 3,289 Answers
If you drive your car to an AutoZone Auto Parts store, they will retrieve the codes and reset the computer for you free of charge. You should locate a store close to you and make sure that your store provides this service. Most all stores provide this service and do not require an appointment.
If there are no stores near you, please provide the city, state and zip code you live in for help in your area.
I hope this helps & good luck! Please rate my reply - thank you.
Posted on Mar 21, 2011
  • Steve Mar 21, 2011
    Ok - here's a link to a free download of your 1999 Buick Regal Owner's Manual The only mention of it however, is on page 2-73. There is no detail about how to reset it.
    I did find a "Service Vehicle Soon" reset procedure for a 1999 Buick Century - and it will likely have the same procedure for your Regal:
    1) Put the key into the ignition and turn it to "Run." Don't start the engine
    2) Press down slowly and fully on the gas pedal, then release it. Do this three times in five seconds.
    3) Watch for the "Service Engine Soon" light to start blinking. This
    indicates that the system is resetting itself. Turn the ignition to
    "Off" and wait one minute.
    4) Start the Century's engine. The Service Engine Soon light will flash for
    a moment, then turn off. If it doesn't do this, repeat the process.
2002 Buick Regal Service Engine Soon light PO442 diagnostic code
That is an emissions code. It means you have a small leak in one of the lines. Most likely it the line that goes from the engine to the evap canister in the drivers side rear inner fender well.
Mar 01, 2015 | 2002 Buick Regal
How to reset Service Engine Soon light after replacing gas cap? Took to AutoZone when the Service Engine Soon light came on Error code P0440.
Disconnect the negative battery cable for 30 minutes. Reconnect after and the code will clear. However if the problem persists, the code will come back with in 20 miles or 30 minutes.
Aug 02, 2014 | 2000 Buick Regal LS
How do you reset the service engine soon lights on a 2001 Buick regal
with a scanner buttttt,,, if the light is on theres a problem that needs to be addressed
May 27, 2012 | 2001 Buick Regal
I own a 1999 Buick Regal GSE with 94K miles. I recently noticed that my dashboard lights sometimes come on, and sometimes don't. Sometimes, during the day, if my dashboard lights are on, and I pull out...
In the 99 Regal, the headlamp switch is also the dimmer switch for the instrument cluster.
With the headlights on, try rotating the switch to bring up the "nighttime" intensity.
If the headlight switch has a pre-set dimming function for the instrument cluster lighting (in other words, not adjustible by rotating the knob), then
replacement of the headlight switch would be the only way to fix the instrument cluster lighting problem.
See Wiring Schematic below.
Fig.1 - 99 Regal Headlamp switc & Instrument Cluster Lighting
This small GIF image can be captured by Right-clicking on it to "Save Image As...",
Then viewed/enlarged in Microsoft Windows Media Player or RealNetworks RealPlayer.
Sep 05, 2011 | 2002 Buick Century
How do you reset the "service vehicle soon" light on a 1999 buick LeSabre?
Service Soon just is some warning about time to change fluids and maintenance; this is diferent at Check Engine (means fault code stored in the computer).
Good luck.
May 10, 2011 | 1999 Buick LeSabre
How can I reset the "service vehicle soon" light for a 1999 buick regal. NOT the "sevrice egine soon light". thank you
Hello
Most of time the service vehicle soon light is on is because a bulb of some sort is out headlight, foglight, taillight or brakelight replaced whatever bulb is out and the light should reset itself
Good luck
Chris
Mar 31, 2011 | 1999 Buick Regal
My 99 buick regal 's service engine light flashes going up a hill and the car starts shaking?
the light is flashing to tell u that the engione has one or more engine cylinders misfiring, have the trouble codes tested to find out which cylinder(ws) is he problem.
Apr 30, 2009 | 1999 Buick Regal
99 buick regal 3.8 starts for 3 seconds and shuts down,
Had the same problem drove me nuts until I tried disconnecting Mass Air Flow Sensor, the car should drive normally but with a "Service Engine Soon Light" on. Mass air flow can run from $140 up, picked one up at recycler for $40.
Worth a try.
Mar 01, 2009 | 1999 Buick Regal
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
