Question about KitchenAid 31 in. KECS100 Electric Cooktop
Electric schott ceran stove, one burner does not work and power light stays one
4 Suggested Answers
SOURCE: I cracked my Schott Ceran Cooktop glass
I located a company that supplies a new top but only to find that the tops are 400.00 anyway. I ended up purchasing a new stove to solve the problem.
Posted on Nov 19, 2008
SOURCE: Ceran stove top will not unlock.
Unlock Kitchenaide Caren stove top
Posted on Feb 18, 2010
espressonist
  • 1711 Answers
SOURCE: My schott ceran class top stove keeps saying F1 on
Here below we have aprocedure to try to see if you can save the ERC.
F1 touch pad / ERC test
This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models
incorporate the touch pad in to the ERC as a single assembly, in which case this
test is not necessary. Simply replace the ERC (Clock).
Warning: If
you feel in any way uncomfortable performing this test or making this repair,
please contact a qualified appliance repair technician.
1. Disconnect
power to the range (unplug the range power cord or turn the power off to the
range at the circuit breaker). It is very important that the power to the range
has been disconnected, so please double check before continuing.
2. Gain
access inside the control panel.
3. Disconnect the touch pad (also called
keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no
lose wires, or anything else that may cause a short when power is turned back
on. Assemble the control panel back the way it was.
5. Turn the power back
on.
6. Wait for at least one hour to see if the F1 code comes back (usually
accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it
does not, replace the touch pad.
Posted on Dec 19, 2010
My electric cooktop is not working.there is red light on near lock.it is Schott Ceran[eco friendly. and Gold series
On mine it meant that one of the electric elements has burned out. Try the burners and see if they all work. If not, the element is bad.
May 02, 2018 | Cooktops
My Schott Ceran cooktop will only work on full heat and will not simmer at all. why?
usually there are 2 elements a smal and a large the small one possibly burnt out .
Apr 20, 2015 | Whirlpool 30" Schott Ceran Surface...
Whirlpool How To
so sorry for the way late reply!
if the knob does not fit you'll need a new one...
i found them here....
https://www.repairclinic.com/Shop-For-Parts/c31-x72636333303234/Rcc3024-Knob-Dial-Button-Parts
not sure which is yours as the model # should have a few more # or letters. Take a look at them and see if one matches.
best to you.
Jan 26, 2018 | Whirlpool 30-inch Electric Ceramic Glass...
Schott ceran touch
might be transformer noise? try turning the cooktop circuit off at the electrical main switchboard.
or get your wife to stop singing opera!!
Oct 22, 2013 | Kuppersbusch Cooktops
Maytag schott ceran front eye wont get hot
I navigated the SCHOTT website to find a solution and was able to find out how to properly clean my SCHOTT stove top. I would check the Ceran FAQ list to see if your question is answered before anything else.
Nov 19, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
I just moved to a fully furnished apartment. How do I turn off the schott ceran cooktop. Both knobs are already pointing to zero but one of the lights is still on.
This cook top light may stay on until the heating element has cooled down,
This is a warning that the top is still hot to warn you so you do not get burnt.
Feb 05, 2012 | Cooktops
My miele induction schott ceran is being locked, and I can not open it to cook??
If you have an illuminated red key symbol on the cooktop, press down where the illuminated red key is, for about 5 seconds. This method works on many Schott Ceran / Miele cooktops including the KM443 listed above.
If this doesn't work, please let me know the correct model number.
Hope this helps.
Regards,
BElectric
Apr 25, 2011 | Miele 30 in. KM443 Electric Cooktop
Constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
Dec 26, 2009 | Jenn-Air JED8230 Electric Cooktop
Whirlpool Oven, Ceran stove top
I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
Nov 20, 2007 | Cooktops
KitchenAid 31 in. KECS100 Electric Cooktop Logo
227 people viewed this question
Top KitchenAid Cooktops Experts
vince
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
