Question about Black & Decker Garden
How do I change the spool on strimmer GL652 - Black & Decker Garden
2 Suggested Answers
robin_hackne
SOURCE: purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
It's a ryobi strimmer re-badged- check ebay...
Posted on Oct 09, 2012
Restring a pgt300 performance power strimmer, it has a white casing which does not come off preventing me from adding more line
There should be 2 plastic tabs which you have to push in, this removes the wider outer base cover of the strimmer spool, giving you access to the bump cap and line spool.
Depending on the style you have, one looks to be a whole replaceable spool unit, one looks like a re-threadable spool.
If you find this useful, please click the 'helpful' tab. Thank you
May 14, 2016 | Garden
Strimmer instructions
some strimmers have two tabs on either side of the spool which yousqueeze while pulling up.
Sep 07, 2014 | Garden
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
Why is a replacement spool and line not available for Qualcast GGT4502? Its only 7 months old (from Homebase) !!!
I think it's because Homebase no longer sell them. It's really annoying - I bought the last replacement spool that they had a couple of weeks ago for the strimmer I bought last summer.
After this is used, I'll have to buy a new strimmer. Bad judgement there, Homebase.
Apr 15, 2011 | Garden
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
How do you change the cord on a b and d strimmer
Hi, W/D here.
Pull the spool straight off, out of the head. Look at the bottom of the spool, you'll see arrows indicating the direction that the line should be wound. Now, look at the spool. You'll see that there are actually two spools, made together. In the middle part of each spool, you'll see a small hole. There should also be a notch in between the two spools.
OK. Starting with the inner spool, insert your line into the hole about 1/8", and wind in the direction of the arrows. When you have wound the line to the diameter of the divider between the spools, stop. There is a very small notch on the bottom of the spools that is 180 degrees from the notch in between the spools, and at the bottom edge of the spool that you are winding. Click your line into that notch. Leave about 6" of line out past the notch, and cut it off from the pack of line that you are winding from. Now, wind the outer spool the same way. When full, you'll guide your line thru the notch between the spools and into the small notch at the bottom of the inner spool. Leave another 6" tail, and cut it off.
Take the two tails of line while holding the spool,and insert one into each grommet on the machine head. Align the line notches with the grommets, and press the spool into place. You should feel it click into place. Now, you want to tug on the line tails to pull them out of the notches. You're done!
I have one final bit of advice, and you don't have to do it this time...just keep it in mind... The head will sometimes be stubborn in dispensing the line. I find that occasionally putting a little graphite into the hole where tha spool fits onto the machine helps the line advance part work much smoother, and it keeps the head from sticking.
Best regards, --W/D--
Aug 14, 2009 | Black & Decker Garden
How do i change the line on my bosch garden strimmer, as it has broken
As it was impossible for me to get cap off spool I used a screw driver to prize off lid. If i ever need a new garden strimmer I will never ever buy this model again. It was so frustrating I felt like throwing it over the fence and buying a black and decker one.
Aug 03, 2009 | Garden
Mc Culloch Grass strimmer ( trim mac T 161) Spool stuck on ?
the spool should have a bolt or a black knob in the middle of spool it thread are backword
Jul 21, 2009 | Garden
GL 315 strimmer chops the line up into small pieces and goes through a reel in minutes
the spool control teeth have worn out and is continuesly feeding line take out spool look at teeth in head if good replace spool if not need new head and spool
Jul 07, 2009 | Garden
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
Garden Logo
328 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
