Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
I have a Bissell Proheat Turbo and the brush isn't spinning although the belts are fine.
reddevil6
  • 1673 Answers
SOURCE: Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Posted on Jan 22, 2008
SOURCE: Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Posted on Jul 14, 2008
scrodamoon
  • 659 Answers
SOURCE: no instruction book
http://www.bissell.com/images/UserGuides/1400_206.pdf
try that see if that manual matches up for you.
Posted on Aug 11, 2008
  • 389 Answers
SOURCE: Proheat brushes won't work - belts are fine - ARRRRGGGHHH!!!
The direct answer to your question is: you don't. These machines are OK while they're working, but they are not easy to repair, and professional repair is likely to be uneconomical because of the labour involved. As to the cause: of course I don't know without seeing the machine, but I do know that the brush motor is located in a position where it quite easily gets wet and eventually fails (possibly causing damage to the machine's electronic circuit board as well).  My best advice: before you buy your 4th Bissell, read what you yourself have written...! And consider saving money by hiring a professional machine occasionally.
I value your feedback. Please remember to rate this response. Thanks, and good luck!
Posted on Jul 18, 2009
SOURCE: Anyone know why my Bissell Proheat 2X Turbo Model
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Posted on Feb 27, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
I have a bissell 9200 proheat X2 wont **** up water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
r
Aug 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
The brushes on my Bissell Proheat 2x shampooer won't turn.
You need to replace the belts on the roller brush. Here are the belts you need:
Bissell Proheat 2X Belts
May 24, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Brushes aren't turning on Bissell Proheat 2X and it is almost new.
New or old,flip the vacumm over,and remove the long hair and debris from the roller brushes. If they don't spin after removing any debris,the
belt,that turns the brushes has come off,or the motor is bad. You wil
have to take the bottom section apart,to see what's going on,then.
Good luck.
Apr 01, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Brushes don't spin and not picking up water
Depending on your model, the belts may be worn or broken. You can get replacements here:
ProHeat Replacement Belts
Nov 07, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat, Brush won't turn, belt fine.
heatman101
dh
Jul 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell proheat perfect pass
Manuals for all Bissell machines can be downloaded from www.bissell.com.
Mar 12, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
470 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
