Question about Miele 30 in. KM443 Electric Cooktop
Can't turn it "ON"
Cannot get my Miele KM443 Smoothtop to come ON. There is no response when i push any of the buttons.
  • fiercechild Aug 04, 2008
    I have the same problem. i'm trying to get Miele to send out a tech person to have a look at it.
  • kmtaylor Apr 05, 2009
    yesterday touch lights came on for 15 secs then went off, today nothing !!
    any ideas ?
Seeming like you forget how to lock off.
keep the lock icon pressed stronger and longer,until will hear a beep,then turn it on
Posted on Oct 02, 2008
No, the problem was the internal computer board was broken. luckily, under warranty, it was replaced.
My miele induction schott ceran is being locked, and I can not open it to cook??
If you have an illuminated red key symbol on the cooktop, press down where the illuminated red key is, for about 5 seconds. This method works on many Schott Ceran / Miele cooktops including the KM443 listed above.
If this doesn't work, please let me know the correct model number.
Hope this helps.
Regards,
BElectric
Apr 25, 2011 | Miele 30 in. KM443 Electric Cooktop
Stove wont do anyhing but beep every other minute
Sorry to read about your problem, I hope this helps you out.
try to reset, by turning off and on your circuit breaker, if that does not help, you have a defective main control card. contact http://mieleusa.com/
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 03, 2011 | Miele 30 in. KM443 Electric Cooktop
Miele LP cooktop: we turned the power to the range off. when we turned on again it didn't ignite (it has power!)
Hello
Keep the air holes around the burners free of debris and grease by clearing out the holes with a thin piece of wire or a toothpick. Cleaning out the holes helps the ignitor light the cooktop
Listen for the clicking sound of the ignitor, then turn off the burner if you don't hear the clicking.
Turn the burner to the "Off" position, if you continue to hear the ignitor tick after you've lit the burner. Turn the burner back on to relight it. Ignitors normally make a brief series of electrical clicking sounds when you turn on the ignitors.
Let the ceramic igniter dry out if it has gotten wet and the burner won't ignite. If the igniter isn't wet, clear out the little holes in the burner by chipping out any blockage with a straightened paper clip.
Clean the electrodes if the burners still don't light. The electrode is in the burner base. Clean the metal part with a soft cloth. You can use emery board on the metal part but not the white ceramic part.
Nov 03, 2010 | Miele 30 in. KM443 Electric Cooktop
The electonic part need to be changed, I WOULD LIKE TO KNOW IF IT IS POSSIBLE AND HOW MUCH WILL COST?
its very expensive...much better to but a new one...ceramic hob with knob control not the touch control...
Jan 17, 2010 | Miele 30 in. KM443 Electric Cooktop
My right front burner only has heat on the inner circle. what do i do.
It could be the switch. I have a handy video that shows what to check: HERE
Jan 14, 2010 | Miele 30 in. KM443 Electric Cooktop
Amps
60 amps and 220 volts
Jun 17, 2009 | Miele 30 in. KM443 Electric Cooktop
One surface element went dead.
Make sure that element didnt come unplugged. Just push it in firmly and it should be fine.
Mar 18, 2009 | Cooktops
Miele KM443. Elements switching on and off every 5 to 7 seconds.
as far i know it is normal if u put at high control after a sec,the sencor control is turn off then a sec again it open coz of the sensor, design the sensor for not overheating the hob.it is normal try to position the control in in not a max position.or the pot u use is exactly in the circle or bigger dont put a small one in the bigger hole of ur elctric hob.tnx
Nov 23, 2008 | Miele 30 in. KM443 Electric Cooktop
Amana Electric Smoothtop Cooktop heat control knob.
1st remove the control knob by off position & pull it one by one then clean it by using vacium.tnx
Nov 16, 2008 | Amana Cooktops
Display blinks and then lights go out
I have the same problem. i've been on the phone with Miele tech support. i'll let you know if i have any luck.
Mar 26, 2008 | Miele 30 in. KM443 Electric Cooktop
Miele 30 in. KM443 Electric Cooktop Logo
923 people viewed this question
Top Miele Cooktops Experts
mpservices
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
