Question about Furuno GP31 GPS Receiver
Gps How to connect the furuno gp-31 modet to a serial port on pc needs wiring diagram.
  • 4 Answers
Hi fire1961,
Downloading data from my FURUNO GP-30 gave me no problems. But it took me long time to figure out why I coudn't upload waypoints and routes to the GP-30 via the serial port in my ThinkPad T30.
I tried nearly everything tested the cable, tested a lot of different software and even wrote a little c-program to communicate with the serial port. I also tried a serial-to-usb converter with no results. Then I stumbled over this RS232 Tutorial. According to this - serial ports are not just serial port but can be divided into three general categories:
The types of driver ICs used in serial ports can be divided into three general categories:
* Drivers which require plus (+) and minus (-) voltage power supplies such as the 1488 series of interface integrated circuits. (Most desktop and tower PCs use this type of driver.)
* Low power drivers which require one +5 volt power supply. This type of driver has an internal charge pump for voltage conversion. (Many industrial microprocessor controls use this type of driver.)
* Low voltage (3.3 v) and low power drivers which meet the EIA-562 Standard. (Used on notebooks and laptops.)
Then I installed the waypoint upload software to my ten years old Compaq Presario and suddenly I could upload routes and waypoints but only via the on board serial port. The serial-to-usb converter didn't still work.
So if people experience no result trying to upload data to these old GP-30's from their notebooks and laptops. Then I think it could be a matter of these Low voltage ports not are able to provide the FURUNO device with enough voltage. See the above RS232 Tutorial.
Best Regards
Lars Erting
Posted on Sep 01, 2008
Connection to PC for Nav software
Assuming you have GPS input to your 1732 (i.e. GP310/320 sensor), you'll need a 7 pin NMEA data cable (000-154-028) wired to a D-sub 9 pin (serial) plug. The shield goes to pin 5, blue to #3, & white to #2. Jumper pins 7 & 8 together. The 7 pin cable goes to Data port 3 of the 1732.
Jul 12, 2010 | Furuno Navnet 1732 GPS Receiver
I have bought a ICOM VHF m601 and I want to connect the furuno gps 31 to the VHF. Is this possible ?
Using the nmea output from your GP-31 to the nmea input on the VHF. Enable the GLL Sentence and make sure the port is set for nmea0183. Remember hooking nmea up it's positive to positive and neg to neg. Once that is done and you have a fix you should have lat and long on your vhf.
Mar 09, 2010 | Furuno GP31 GPS Receiver
How to interface a furuno 1833c navnet to a usb port and how to download waypoints to my pc.I have the older 9 pin pc cable and a usb adapter cable.Looking for usb drivers and software to make it work.
The display uses a serial interface, otherwise known as a comm port. You can get a USB to DB9 adaptor practically anywhere. Once you have a serial connection, you will need software such as MaxSea to send the waypoint with.
Jan 11, 2010 | Furuno 1833C/NT GPS Receiver
Cables for gp-270
try ebay or www.iconcables.net or
www.iconcable.com
Sep 10, 2009 | ICOM Informatique GP-270ML GPS Receiver
Manual
http://www.mapsunique.com/ev/special-inst/furuno-30.htm
Here is a site that knows something about it. and to find where to buy one google it.
Sep 07, 2009 | Furuno GP31 GPS Receiver
Furuno gps wiring diagram for usb
Hello!
I have the connection diagram for the GPS unit below.  It should be simple to wire up.  You will need a USB to RS-232 converter, which is available in a number of computer shops/Radio Shack.
Hope this helps you out,
Jan 06, 2009 | Furuno GP31 GPS Receiver
I've just bought a boat with a furuno gp 31 , no user manual .is there somewhere I can download one thanks.
Hello!
You can download one here:
http://www.furunousa.com/Furuno/Doc/0/5OS1KKAL2OP434ND790LNUEPEB/GP31-GP36%20Operator%27s%20Manual%20%20k.pdf
Copy the entire link into your browser and you should have it.  It is in PDF format, so if you need a PDF reader, go to www.adobe.com and get one for free.
Hope this helps,
Ken
Dec 06, 2008 | Furuno GP31 GPS Receiver
How to connect furuno marine gps model-31 to a pc using serial port
Connecting cable to PC - see
http://furuno.inforce.dk/graphics/14_Softwares/09_gps/FURUNO_GP-32_pc_connect.pdf
Jul 26, 2008 | Furuno GP31 GPS Receiver
Don't have wiring diagram
This was taken from the manual that I have.
Yellow - Serial data 1 output
Green - Serial data 1 input
Red - Batt (+)
White - Serial port Ground
Black - Batt (-)
Grey - Serial port Data output
Jul 15, 2008 | ICOM Informatique GP-270ML GPS Receiver
Furuno GP31 GPS Receiver Logo
700 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
