Question about liftmaster 373lm Liftmaster Craftsman Opener Remote Transmitter
The garage door doesnt open or close with the remote . it works with the console inside the garage or with the code activated device outside . what should i do ? Norbert
  • 59 Answers
Try changing the battery, if that does not work its time to look for a replacement.
Posted on Mar 23, 2011
I have a SecuraLift Garage door open. The door will not open with the remote or on hte wall device and the status light is flashing... Can I fix this or do I have to call for the door to be serviced? AND...
Many of these devices use a code that changes each time the door is opened and closed. This feature is used to keep potential bad people from learning your operational code and entering your garage. You may have a communication problem whereby the Garage Opener needs to be reset. You may try to change the settings. If you have dip switches on the main unit in the garage, change the dip switches to another setting and write down the numbers in the order that you have the set them, Then go to the remotes, hand held and hardware placed on the outside door, and change the settings on these devices to MATCH up with the inside unit. This is a good time to REPLACE the batteries also.
Feb 20, 2018 | Chamberlain Powerdrive PD422D 1/2 HP...
Changing PIN on Key Pad
can you please provide the exact model number of your Security device...
Thanks
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Raynor garage opener-remote only works close up sometimes
check to seee if the little wire that hangs out of the operator is hanging out. This wire is the ant. if this is not the problem replace the 12volt battery you can buy them anywhere. make sure you didn't cut off the ant. wire (I have seen customers cut thios wire thinking its an extra and not needed or place the wire inside the box very little signal that way have to be very close)
Jun 05, 2009 | Building Materials
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door shuts down, need to press reset to get it to work
On the side of the opener you will find the down limit control. Turn this a bit in the opposite direction of the arrow printed on the cover. You will probably have to tweak it a bit to get it just right.
May 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote will not open or close door when temperature is cold.
if this is an outside remote the best you could do is maybe put someting to insulate the remote if it is in your car don't leave it on the visor put it in the glove box or maybe the center console it is obvious that expansion/contraction physics are playing a part
Apr 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote won't work outside of garage it works up close
doesnt work at all or only close. if not at all, recode remote. if short distance, try reaiming antenna wire.
Dec 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster 373lm Liftmaster Craftsman Opener Remote Transmitter Logo
266 people viewed this question
Top liftmaster Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Jean DeLauche
Jean DeLauche
Are you a liftmaster Home Security Expert? Answer questions, earn points and help others
