Question about Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G R Motherboard
Changed MSI MB to Gigabyte. I get bios and even the windows recovery window but every time it just restarts and wants to do a start up and repair that always fails. Help.
  • 961 Answers
Http://www.gigabyte.us/support-downloads/download-center.aspx
This is Gigabytes link to downloads. Did you uninstall software from MSI? Try to shut down, unplug system, and restart. You might want to consider a "system restore" back to when it did work. Did it work at all with new board?
Posted on Mar 21, 2011
My satellite Toshiba L875D-s7230 says bootmgr is missing press ctrl alt and delete to restart and does nothing
Which operating you are using?
Method 1: Run Startup Repair from Windows Recovery Environment (WinRE) To run Startup Repair from the Windows Recovery Environment (WinRE), follow these steps:
  1. Insert the Windows installation disc into the disc drive, and then start the computer.
  2. Press a key when the messagePress any key to boot from CD or DVDappears.
    If your PC does not detect the media automatically
    1. During the restart process, read the screen for any instructions that explain how to interrupt normal startup and enter the basic input/output system (BIOS) setup utility. Most PCs use the F2, F10, ESC, or DEL key to begin the BIOS Setup.
    2. Look for a tab in the BIOS Setup Utility that is labeledBoot Order,Boot Options, orBoot. Following the directions on the screen, use the arrow keys to go to theBoot Order, then press Enter.
    3. Locate the CD, DVD, or USB flash drive (this might be called Removable Device) in the Boot list. Following the directions on the screen, use the arrow keys to move the drive up so that it appears first in the Boot list. Press Enter. The boot order sequence is now changed to boot from the CD, DVD, or USB flash drive.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYes in the confirmation window. The PC will restart.
  3. Select a language, a time and a currency, a keyboard or input method, and then clickNext.
  4. ClickRepair your computer.
  5. In theSystem Recovery Optionsdialog box, select the drive of your Windows installation, and then clickNext.
  6. At theSystem Recovery Optionsdialog box, clickRepair your computer.
  7. Click the operating system that you want to repair, and then clickNext.
  8. In theSystem Recovery Optionsdialog box, clickStartup Repair.
Method 2: Rebuild the boot configuration data (BCD) from Windows Recovery Environment (WinRE)
  1. Put the Windows installation disc in the disc drive, and then start the computer.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYesin the confirmation window. The PC will restart. Allow the PC to restart normally. The scan will take a few minutes and remove any malware that may be infecting your computer.
  3. Select a language, a time, a currency, a keyboard or another input method, and then clickNext.
  5. Click the operating system that you want to repair, and then clickNext.
  6. In theSystem Recovery Optionsdialog box, clickCommand Prompt.
  7. TypeBootrec /RebuildBcd, and then pressENTER.
Jan 20, 2017 | Toshiba Computers & Internet
I got an MS 7390 and lately I updated to the latest BIOS version which is 1.20. I normally use a USB keyboard but when I start up the computer it asks me to press DEL to enter setup. The problem is that...
Hello download a manual here at MSI:
http://www.msi.com/product/mb/K9N-SLI-V2.html#/?div=Manual
You need to unzip the file when downloaded.
I guess the bios upgrade set the usb function off
You have to enter the bios and set it on again.
Look in the manual how you do that.
You need a PDF reader to read content.
Good luck
Jan 03, 2011 | MSI K8N Neo4-F Motherboard
My netbook says "Operating System Not Found" every time I turn it on.
What were you doing prior to this error message ?
Did you try to install another OS or During installation did you abort the process
A clean installation of windows will resolve the issue
Or Try this
If you were able to start the computer prior to the issue, then try startup repair and check the result. To do this, try these steps.
Step 1: Perform startup repair using Vista DVD
a. Insert the Windows DVD.
b. Restart your computer.
c. Let the computer restart (boot) from the DVD.
d. If prompted, press any key to continue.
e. When you reach the Install Windows screen, select your preferences in the Language to install, Time and currency format, and Keyboard or input method boxes, and then click Next.
f. Do not click Install now. Instead, click Repair your computer. The System Recovery Options dialog box appears.
g. Make sure the correct operating system is selected, and then click Next.
h. After you click Next, the System Recovery Options menu appears.
i. Click Startup repair. Once the startup repair completes, click Finish to restart the computer.
j. Remove the DVD and restart the computer to see if the system starts fine. See Make system repairs from the Windows Recovery Environment
Also see http://support.microsoft.com/kb/932932 Go to BIOS (basic input/outputsystem (BIOS) and make hard disk as first bootable device. See BIOS: frequently asked questions
http://windows.microsoft.com/en-US/windows7/BIOS-frequently-asked-questions Important: Modifying BIOS incorrectly will cause serious damage.
Hope this helps
Sep 05, 2010 | Dell Inspiron Mini 10v Netbook Computer
Gigabyte ga-p35-ds3l (2.0) will not flash bios from usb. don't have floppy. can save current bios to usb, and will read new bios however I get no prompt to replace current bios. what should I do?
first never flash your bois in windows it is not good for the mb, restart floppy is the best way, so get a stiffy drive and do it the pc, hope u downlaoded the never bois, at the post screen check to c if there is a flash option f8 or sumthing then from ther u will be directed
Oct 07, 2009 | Gigabyte GA-P35-DS3L Motherboard
Tesco Philips Iqon PC No sound after installing my copy of XP
I had the same issue with a iQon Tesco3 - i got all the drivers i needed directly from the MSI website. Link below for Tesco3 model
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=228
Mar 28, 2009 | Computers & Internet
MY msi 7082 cant read HDD 40GB and above whY>?
Your board specifications are here - http://www.msicomputer.com/product/p_spec.asp?model=661FM3-L&class=mb
This sounds like a memory timing issue based on the caution from the MSI page. There is no reason the board itself should have a problem with that size hard drive. Have you reset the bios to factory default and tried the various compatibility settings available in the bios?
Dec 26, 2008 | MSI 7082-010 (661FM3-V) P4 LGA775/SiS...
My windows alwyas restart & recovery bios
orangmedn
pc r restart for several reason like power supply problem, over heated, os problem. if ur pc restart when u try to access any drive or insart cd or dvd in drive means ur power supply is faulty. and if it restart after a fixed time (approximately) means over heated. (u reinstall xp so operating system is not infected.) if one of above symptom r their then no need to update bios.
2nd if some problem heppen during ur bios update and it not wirte properly and u restart ur pc in this situation the ur pc can not start and result is no display condition. if it happen then contact with any mother board repear centre or mother board service centre. (because if bios program r corrupt it need to repalce or rewite).
(**2nd time if u update any BIOS be Cautious. at first take backup then update. if any problem happen then restor with backup copy, then restart ur pc. until u sure update successfully do not restart ur pc).
Jul 10, 2008 | MSI PM8M-V Motherboard
Windows booting problem
hi sunnyh, when you start up the PC start pressing the F8 key every 2 seconds. A dos like window will load. At the bottom of the list choose, last known good configuration. (win might load the last good configuration) it's worth the try.
If your PC still does not load windows than repeat the above, this time choose, Disable automatic restart on system failure.
This also might allow windows to load (hopefully).
A system that starts going into this restart loop happens for many different reasons. Most common reason was a program that was last installed just before PC was restarted. Second most common reason for restart loop. Added new hardware, bios changes & windows boot files corrupted. If you did install a program, uninstall it. If you were in your bios & made changes, reset the bios. If you flashed the bios, go back to the old bios version. If you added new hardware replace with older hardware.
To fix Windows you may have to reinstall it. Do not run format or you will loose all your data. Even system restore CD's allow for a win reinstall without a format, however if the cd does not allow you to reinstall win unless you do a format. Than windows startup files are too screwed up & you'll have no choice but to format.
All you can do is try the above & cross your fingers.
Mike
Mar 22, 2008 | Gigabyte GA-8SR533 Motherboard
Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G R Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
