Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
DRIVERS FOR IOMAGIC 250GB (WIN XP)
I got this 250gb IOMagic external HD about a year ago. It was running well. Recently I have to re-install win xp and after that my notebook detects it also and says new hardware found, but tries to find drivers and finally can't install it. Does any body has drivers for win xp for IOMagic 250gb HD. Help appreciated.
Thanks
PKS
    Problem Solver:
  • 8 Answers
The I250HD35 is plug-and-play with Windows XP. That means that all of the drivers needed to run your hard drive are included in Windows.
If your computer is asking for drivers when you plug in your drive, one of two things is probably happening:
1) Windows XP doesn't know where to look for the right drivers
2) Your drive has malfunctioned
The easiest way to assess which of these is happening is to take your drive and plug it into another computer that is running Windows XP. If it is detected properly on the other machine, then your computer doesn't have the right drivers or is looking in the wrong place for them. If it doesn't, then I/O Magic will be happy to replace your drive if it is still within the warranty period
If it is detected properly on another Windows XP machine, then when it asks for drivers, make sure to point it to the WindowsINF directory. This is where the default drivers are located.
If your drive is not detected properly on the other computer, your drive is probably experiencing a hardware malfunction. Please visit the I/O Magic website at www.iomagic.com and click on Support for specific return information.
Have a nice day,
I/O Magic Technical Support
Posted on Sep 10, 2008
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
How to change transcend external harddisc fat32 to NTSC
HI you mean NTFS if YES, then there is step for xp or win 7
1. click Start, click Run, type cmd, and then press ENTER.
2.In the command prompt window, type: convert drive_letter: /fs:ntfs
Regards,
Chandrakanth
Oct 07, 2012 | Buffalo Technology 250GB USB SATA 2.0 HD...
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
Simple Tech HD failing- takes 4 hours to tranfer 512 MB!?
Not exactly a solution but I have had the same problem with one of these Simple Tech Signature Mini 320's for a while. Real finicky. Will only be recognized on direct connected to MB USB ports and even then with Win 7 or XP I get the "This USB device can perform faster if you connect it to a Hi-Speed USB 2.0 port." no matter what ports I connect it to. While having this issue on this "main" computer I have previously connected it to some other computer (don't remember which, now) and it connected at 2.0 speed. What's going on??
Jul 16, 2010 | SimpleTech Signature Mini 250GB External...
Hardrive light flashing iomagic 250gb
try disconnect your hard drive and then connect it again,start your cpu,if that don't work i thing your hdd is near end.....
Apr 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Recently purchased eGo Helium 500 GB USB Drive. During installing on Win XP SP3 system it fails the USB to ATA/ATAPI Bridge portion of the installation and reports a problem in the balloon.
I have this external hard drive myself although mine is a 25gb drive. When you first tried to install it did you insert the disk that came with it first? You may need to do this if your system isn't recognising the drive. According to the system requirements it should be compatible with your system. Good luck. Andrew
Jan 18, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
250 GB Western Digital external HD not detected by Win 98 SE
If you installed SE on Win 98, then here is a link to a generic USB driver that should work with your HD. If at some point you decide to install a newer OS or go dual-boot, you can always partition the HD so you don't lose any storage. Best of luck.
Greg
http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
Jun 14, 2009 | Western Digital WD Passport 250GB Portable...
I/O Magic databank 250Gb External Drive
just installed 250g iomagic. getting runtime error when clicking on create vault- c:\programfiles(x86)\iomagic\databank\databank.exe any help would be great
Feb 22, 2009 | IO Magic Corporation GigaBank (I250HD35)...
Partition external 250gb drive
why would you want partition it??? XP will recognise the 250. Partition was useful for win 98, but pointless excercise with XP.
Aug 07, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
486 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Falling star
nuhu ibrahim
nuhu ibrahim
Level 1 Expert
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
