Question about Whirlpool RY160LXTS Stainless Steel Electric Range
I have the RY160LXTS Stainless Steel Electric Range. The burners, and oven light work but the oven display light doesn't. The oven doesn't heat up. Also the oven fan is continuously running.
3 Suggested Answers
SOURCE: I have a Whirlpool GS563LXSS
Hold the night light button for @ 3 seconds. It works for me.
Posted on Oct 21, 2009
  • 6 Answers
SOURCE: Ancient (1971) Frigidaire Cookmaster electric
The stove has 4 burner switches with a # 2 terminal on each switch. This contact is similiar on all four switches. One of the switches # 2 contact is stuck. The burner switch should disconnect both legs of the 240 volt circuit, one leg through the # 2 terminal and one leg through the thermostat built into the burner switch. Disconnect the pilot lamp wire on each switch unti the light goes off and then replace that burner switch. This should correct the problem
phucks001@horrycountyschools.net
Posted on Jan 25, 2011
Getting an F15 error code when trying to start Oven.
Error code f15 'Frigidaire FEB30T7FC Stainless Steel ...
www.faqqq.com/.../error-code-f15-frigidaire-feb30t7fc-stainless-steel-ele...
Error code f15 'Frigidaire FEB30T7FC Stainless Steel Electric Double Oven ... I'mtrying to open up a Unity3D game.exe that is on a remote computer through my main desktop. ... How 2016 will be the start of your virtual reality future - CNET.
Kenmore range shows f15 error code - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Range, Oven & Cooktop Repair
Oct 31, 2010 - 10 posts - ‎5 authors
Kenmore range suddenly started flashing f15 error code. With Thanksgiving just around the corner, i need help with this repair. Thanks.
Dec 30, 2015 | KitchenAid Kitchen Ranges
Elite dual fuel range/oven. Why isn't it heating past 100 deg and burner igniters do not spark?
sadly it sounds like you need to call a service repairman . being an appliance that can explode I do not suggest you try and fix it yourself .
Oct 27, 2015 | Kenmore 30" Slide-In Dual Fuel Range...
I have a whirlpool gold electric range,accubake model gy397lxus.oven not heating and range top not heating,digital control blank unless i rotate a heat selector for range top to on,the light indicators for...
I have look up your unit, I found the thermostat located inside the back panel the would only take out the function to your elements in your oven.
High limit thermostat
This link shows its location and price of the part. Now for you display issue, before continuing, push and hold the clock button on the panel until you hear a beep, if the unit is set to Sabbath mode this will clear that. If not I will continue, by the way missing a version number to model number, like a number (0 or 02). Have you have a power outage recently? I am not locating any line fuses the would take the display out. If the clock doesn't reset then I would think about checking warranty or can your dealer to inquire on your warranty.
Control Unit
Good Luck and I hope this helps.
Aug 17, 2011 | Whirlpool GY397LXUS Stainless Steel...
I have a 30" stainless steel cand black gas range with electronic oven control and self ignited burners. For some reason the burners won't self ignite they don't even spark but the gas is comin out. What...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 21, 2010 | Frigidaire FGF337EC Stainless Steel Gas...
The burners are not lighting Frigidaire Gas Range only 8 months
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler not working and stains around gas burners
use a stain remover like hapic, or gbc and the stain will go off.
Aug 03, 2009 | Siemens HD2515U Stainless Steel Dual Fuel...
PRD486EDG doesn t heat up Oven light blinks once
PRD486EDG Oven doesn't heat up. Oven light blinks twice, then the heat light blinks twice. Tried reseting the power
Mar 18, 2009 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
Display not working
The display needs to be replace. Check all the wiring also to make sure nothing over heated
Feb 14, 2009 | GE Profile 30" Self-Cleaning Freestanding...
Whirlpool RY160LXTS Stainless Steel Electric Range Logo
42 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
